OS 6.7 Delayed Clashes and Effects with Fett263 Prop File
The delayed clash was already determined to be caused by prop_base adding a 400ms delay when the Clash EVENT occurs, the fix will be implemented soon and I can have you test, I’m waiting for profezzorn to get back from vacation and caught up.
See here:
Delays for other effects are most likely SD speed. Run ‘sdtest’ in Serial Monitor and post results.
