Contrary to what people have reported about false clashes, I actually have the opposite problem where clashes are hard to trigger after the initial clash.
List of issues I’m noticing:
Consecutive clashes are hard to trigger after the initial clash without doing a pause between each clash.
Consecutive blaster effects are not as responsive to my button press as they were in OS 5.9 when using the Fett263 prop file. For example, if I quickly press the aux button a few times, some of the blaster animations don’t play the sound effect but the blade still does the animation.
When I’m using the FETT263_HOLD_BUTTON_LOCKUP define, there is a noticeable delay from when I press/hold my button to when the sound/animation begins. This does not happen when I’m on the SA22C prop file on OS 6.7. Fett263 merged SA22C’s prop into his for 6.7 so theoretically there shouldn’t be a difference of how this operates between the 2 prop files.
The delayed effects could be because my SD card is too slow, but I’ve tested my SD card in the Serial Monitor and the result is: Average speed: 1100.61 kb/s, 12.48 simultaneous audio streams, which according to the Proffie manual isn’t bad. I could get a new SD card to test though…
I’ve posted a video of the issue on the Open Source Sabers FB group here: Video of Fett263 prop file on OS 6.7
For comparison I loaded up the SA22C prop file on 6.7 as well. The video is here: Video of SA22C prop file on OS 6.7
I also did some testing, here are my steps and results:
- Switching between SA22C prop and Fett263 prop on OS 6.7 - I’m consistently getting the same result where clashes are hard to trigger/delayed after the first clash unless I pause in between clashes while on the Fett263 file, but the issue is not present when I’m on the SA22C file
- Reverted to OS 5.9 and ran both Fett263 prop and SA22C prop files - No issues, clashes/blaster effects are very responsive
- Updated back to OS 6.7 - Same issues persists while on the Fett263 prop file
Here is my full test config (my volume and clash threshold were at 1000 and 3.5 respectively in all my tests between 6.7 and 5.9):
#define VOLUME 1000
#define CLASH_THRESHOLD_G 3.5
#define SAVE_STATE
// #define DISABLE_DIAGNOSTIC_COMMANDS
// #define ENABLE_SPINS
// #define FILTER_CUTOFF_FREQUENCY 100
// #define FILTER_ORDER 8
// #define SA22C_SWING_ON
// #define SA22C_SWING_ON_SPEED 400
// #define SA22C_THRUST_ON
// #define SA22C_TWIST_OFF
#define FETT263_SWING_ON
#define FETT263_SWING_ON_SPEED 400
#define FETT263_THRUST_ON
#define FETT263_EFFECT_BATTERY_LEVEL
// #define FETT263_HOLD_BUTTON_OFF
// #define FETT263_HOLD_BUTTON_LOCKUP
// #include "../props/saber_sa22c_buttons.h"
"Ascension_Starkiller;common",
"common/tracks/TFU_theme_enhanced.wav",
StylePtr<Layers<Layers<RotateColorsX<Variation,DeepSkyBlue>,HumpFlickerL<RotateColorsX<Variation,Rgb<0,68,128>>,50>>,TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<5000>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>,LockupTrL<Layers<AlphaL<TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<3000>>,Int<30>,Int<800>>>,Mix<SlowNoise<Int<1000>>,Black,Black,White,Black>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<10>,Int<30>>>>>,Int<32768>>,AlphaL<Blinking<Tomato,Strobe<Yellow,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<8000>,Int<18000>>>>,AlphaL<Blinking<BrownNoiseFlicker<White,Black,50>,BrownNoiseFlicker<Yellow,Tomato,50>,100,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<9000>>>>,TrConcat<TrInstant,AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,TrSmoothFade<900>,SaberBase::LOCKUP_NORMAL>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Strobe<GreenYellow,Black,20,30>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<15000>>>,TrFade<600>>,EFFECT_LOCKUP_BEGIN>,TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<225>>,EFFECT_LOCKUP_BEGIN>,LockupTrL<Layers<AlphaL<White,StrobeF<Scale<SlowNoise<Int<1000>>,Int<1>,Int<6>>,Scale<SlowNoise<Int<1000>>,Int<10>,Int<50>>>>,AlphaL<RandomFlicker<Strobe<White,Rgb<83,0,255>,50,10>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>>,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<100>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<150>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<400>>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,ResponsiveStabL<RandomPerLEDFlicker<NavajoWhite,Rgb<255,187,78>>>,ResponsiveBlastL<TransitionEffect<Rgb<255,150,0>,White,TrInstant,TrFade<80>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,White,TrInstant,TrDelay<120>,EFFECT_CLASH>,TrConcat<TrInstant,AlphaL<GreenYellow,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<18000>>>,TrDelay<65>>,TrFade<280>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<18000>>,LockupTrL<AlphaL<AudioFlicker<BrownNoiseFlicker<Strobe<Black,OrangeRed,20,25>,Yellow,200>,White>,SmoothStep<Int<30000>,Int<2000>>>,TrWipeIn<400>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_DRAG>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<400>>,EFFECT_DRAG_BEGIN>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<700>>,EFFECT_DRAG_END>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,RandomPerLEDFlicker<Orange,OrangeRed>,BrownNoiseFlicker<Rgb16<20095,128,128>,Rgb16<35103,8175,298>,150>,StyleFire<Rgb16<20393,93,93>,Red,0,4,FireConfig<0,2000,5>,FireConfig<3000,0,0>,FireConfig<0,4000,0>>>,SmoothStep<Scale<TwistAngle<>,Int<27000>,Int<29000>>,Int<2000>>>,TrWipeIn<600>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>>>>(),
"DeepSkyBlue Humpflicker"
"TheChosenOne_Hero;common",
"TheChosenOne_Hero/tracks/Anakin_vs_Obi.wav",
StylePtr<Layers<Layers<RotateColorsX<Variation,Blue>,HumpFlickerL<RotateColorsX<Variation,Rgb<0,0,128>>,50>>,TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<5000>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>,LockupTrL<Layers<AlphaL<TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<3000>>,Int<30>,Int<800>>>,Mix<SlowNoise<Int<1000>>,Black,Black,White,Black>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<10>,Int<30>>>>>,Int<32768>>,AlphaL<Blinking<Tomato,Strobe<Yellow,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<8000>,Int<18000>>>>,AlphaL<Blinking<BrownNoiseFlicker<White,Black,50>,BrownNoiseFlicker<Yellow,Tomato,50>,100,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<9000>>>>,TrConcat<TrInstant,AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,TrSmoothFade<900>,SaberBase::LOCKUP_NORMAL>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Strobe<GreenYellow,Black,20,30>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<15000>>>,TrFade<600>>,EFFECT_LOCKUP_BEGIN>,TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<225>>,EFFECT_LOCKUP_BEGIN>,LockupTrL<Layers<AlphaL<White,StrobeF<Scale<SlowNoise<Int<1000>>,Int<1>,Int<6>>,Scale<SlowNoise<Int<1000>>,Int<10>,Int<50>>>>,AlphaL<RandomFlicker<Strobe<White,Rgb<83,0,255>,50,10>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>>,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<100>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<150>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<400>>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,ResponsiveStabL<RandomPerLEDFlicker<NavajoWhite,Rgb<255,187,78>>>,ResponsiveBlastL<TransitionEffect<Rgb<255,150,0>,White,TrInstant,TrFade<80>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,White,TrInstant,TrDelay<120>,EFFECT_CLASH>,TrConcat<TrInstant,AlphaL<GreenYellow,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<18000>>>,TrDelay<65>>,TrFade<280>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<18000>>,LockupTrL<AlphaL<AudioFlicker<BrownNoiseFlicker<Strobe<Black,OrangeRed,20,25>,Yellow,200>,White>,SmoothStep<Int<30000>,Int<2000>>>,TrWipeIn<400>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_DRAG>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<400>>,EFFECT_DRAG_BEGIN>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<700>>,EFFECT_DRAG_END>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,RandomPerLEDFlicker<Orange,OrangeRed>,BrownNoiseFlicker<Rgb16<20095,128,128>,Rgb16<35103,8175,298>,150>,StyleFire<Rgb16<20393,93,93>,Red,0,4,FireConfig<0,2000,5>,FireConfig<3000,0,0>,FireConfig<0,4000,0>>>,SmoothStep<Scale<TwistAngle<>,Int<27000>,Int<29000>>,Int<2000>>>,TrWipeIn<600>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>>>>(),
"Blue Humpflicker"
"TheChosenOne_Villian;common",
"TheChosenOne_Villian/tracks/Anakin's_Dark_Deeds.wav",
"Blue Humpflicker"
"TheChosenOne_Younglings;common",
"TheChosenOne_Younglings/tracks/Order66.wav",
"Blue Humpflicker"
"BLUE;common",
"common/tracks/GESW.wav",
StylePtr<Layers<Layers<RotateColorsX<Variation,Cyan>,HumpFlickerL<RotateColorsX<Variation,Rgb<0,128,128>>,50>>,TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<5000>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>,LockupTrL<Layers<AlphaL<TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<3000>>,Int<30>,Int<800>>>,Mix<SlowNoise<Int<1000>>,Black,Black,White,Black>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<10>,Int<30>>>>>,Int<32768>>,AlphaL<Blinking<Tomato,Strobe<Yellow,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<8000>,Int<18000>>>>,AlphaL<Blinking<BrownNoiseFlicker<White,Black,50>,BrownNoiseFlicker<Yellow,Tomato,50>,100,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<9000>>>>,TrConcat<TrInstant,AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,TrSmoothFade<900>,SaberBase::LOCKUP_NORMAL>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Strobe<GreenYellow,Black,20,30>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<15000>>>,TrFade<600>>,EFFECT_LOCKUP_BEGIN>,TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<225>>,EFFECT_LOCKUP_BEGIN>,LockupTrL<Layers<AlphaL<White,StrobeF<Scale<SlowNoise<Int<1000>>,Int<1>,Int<6>>,Scale<SlowNoise<Int<1000>>,Int<10>,Int<50>>>>,AlphaL<RandomFlicker<Strobe<White,Rgb<83,0,255>,50,10>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>>,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<100>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<150>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<400>>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,ResponsiveStabL<RandomPerLEDFlicker<NavajoWhite,Rgb<255,187,78>>>,ResponsiveBlastL<TransitionEffect<Rgb<255,150,0>,White,TrInstant,TrFade<80>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,White,TrInstant,TrDelay<120>,EFFECT_CLASH>,TrConcat<TrInstant,AlphaL<GreenYellow,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<18000>>>,TrDelay<65>>,TrFade<280>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<18000>>,LockupTrL<AlphaL<AudioFlicker<BrownNoiseFlicker<Strobe<Black,OrangeRed,20,25>,Yellow,200>,White>,SmoothStep<Int<30000>,Int<2000>>>,TrWipeIn<400>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_DRAG>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<400>>,EFFECT_DRAG_BEGIN>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<700>>,EFFECT_DRAG_END>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,RandomPerLEDFlicker<Orange,OrangeRed>,BrownNoiseFlicker<Rgb16<20095,128,128>,Rgb16<35103,8175,298>,150>,StyleFire<Rgb16<20393,93,93>,Red,0,4,FireConfig<0,2000,5>,FireConfig<3000,0,0>,FireConfig<0,4000,0>>>,SmoothStep<Scale<TwistAngle<>,Int<27000>,Int<29000>>,Int<2000>>>,TrWipeIn<600>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>>>>(),
"Cyan Humpflicker"
"RED;common",
StylePtr<Layers<Layers<RotateColorsX<Variation,Red>,HumpFlickerL<RotateColorsX<Variation,Rgb<128,0,0>>,50>>,TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<5000>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>,LockupTrL<Layers<AlphaL<TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<3000>>,Int<30>,Int<800>>>,Mix<SlowNoise<Int<1000>>,Black,Black,White,Black>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<10>,Int<30>>>>>,Int<32768>>,AlphaL<Blinking<Tomato,Strobe<Yellow,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<8000>,Int<18000>>>>,AlphaL<Blinking<BrownNoiseFlicker<White,Black,50>,BrownNoiseFlicker<Yellow,Tomato,50>,100,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<9000>>>>,TrConcat<TrInstant,AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,TrSmoothFade<900>,SaberBase::LOCKUP_NORMAL>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Strobe<GreenYellow,Black,20,30>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<15000>>>,TrFade<600>>,EFFECT_LOCKUP_BEGIN>,TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<225>>,EFFECT_LOCKUP_BEGIN>,LockupTrL<Layers<AlphaL<White,StrobeF<Scale<SlowNoise<Int<1000>>,Int<1>,Int<6>>,Scale<SlowNoise<Int<1000>>,Int<10>,Int<50>>>>,AlphaL<RandomFlicker<Strobe<White,Rgb<83,0,255>,50,10>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>>,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<100>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<150>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<400>>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,ResponsiveStabL<RandomPerLEDFlicker<NavajoWhite,Rgb<255,187,78>>>,ResponsiveBlastL<TransitionEffect<Rgb<255,150,0>,White,TrInstant,TrFade<80>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,White,TrInstant,TrDelay<120>,EFFECT_CLASH>,TrConcat<TrInstant,AlphaL<GreenYellow,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<18000>>>,TrDelay<65>>,TrFade<280>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<18000>>,LockupTrL<AlphaL<AudioFlicker<BrownNoiseFlicker<Strobe<Black,OrangeRed,20,25>,Yellow,200>,White>,SmoothStep<Int<30000>,Int<2000>>>,TrWipeIn<400>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_DRAG>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<400>>,EFFECT_DRAG_BEGIN>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<700>>,EFFECT_DRAG_END>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,RandomPerLEDFlicker<Orange,OrangeRed>,BrownNoiseFlicker<Rgb16<20095,128,128>,Rgb16<35103,8175,298>,150>,StyleFire<Rgb16<20393,93,93>,Red,0,4,FireConfig<0,2000,5>,FireConfig<3000,0,0>,FireConfig<0,4000,0>>>,SmoothStep<Scale<TwistAngle<>,Int<27000>,Int<29000>>,Int<2000>>>,TrWipeIn<600>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<800>>,TrWipeInX<RetractionTime<0>>>>>(),
"Red Humpflicker"
"GREEN;common",
StylePtr<Layers<Layers<RotateColorsX<Variation,Green>,HumpFlickerL<RotateColorsX<Variation,Rgb<0,128,0>>,50>>,TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<5000>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>,LockupTrL<Layers<AlphaL<TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<3000>>,Int<30>,Int<800>>>,Mix<SlowNoise<Int<1000>>,Black,Black,White,Black>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<10>,Int<30>>>>>,Int<32768>>,AlphaL<Blinking<Tomato,Strobe<Yellow,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<8000>,Int<18000>>>>,AlphaL<Blinking<BrownNoiseFlicker<White,Black,50>,BrownNoiseFlicker<Yellow,Tomato,50>,100,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<9000>>>>,TrConcat<TrInstant,AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,TrSmoothFade<900>,SaberBase::LOCKUP_NORMAL>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Strobe<GreenYellow,Black,20,30>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<15000>>>,TrFade<600>>,EFFECT_LOCKUP_BEGIN>,TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<225>>,EFFECT_LOCKUP_BEGIN>,LockupTrL<Layers<AlphaL<White,StrobeF<Scale<SlowNoise<Int<1000>>,Int<1>,Int<6>>,Scale<SlowNoise<Int<1000>>,Int<10>,Int<50>>>>,AlphaL<RandomFlicker<Strobe<White,Rgb<83,0,255>,50,10>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>>,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<100>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<150>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<400>>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,ResponsiveStabL<RandomPerLEDFlicker<NavajoWhite,Rgb<255,187,78>>>,ResponsiveBlastL<TransitionEffect<Rgb<255,150,0>,White,TrInstant,TrFade<80>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,White,TrInstant,TrDelay<120>,EFFECT_CLASH>,TrConcat<TrInstant,AlphaL<GreenYellow,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<18000>>>,TrDelay<65>>,TrFade<280>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<18000>>,LockupTrL<AlphaL<AudioFlicker<BrownNoiseFlicker<Strobe<Black,OrangeRed,20,25>,Yellow,200>,White>,SmoothStep<Int<30000>,Int<2000>>>,TrWipeIn<400>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_DRAG>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<400>>,EFFECT_DRAG_BEGIN>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<700>>,EFFECT_DRAG_END>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,RandomPerLEDFlicker<Orange,OrangeRed>,BrownNoiseFlicker<Rgb16<20095,128,128>,Rgb16<35103,8175,298>,150>,StyleFire<Rgb16<20393,93,93>,Red,0,4,FireConfig<0,2000,5>,FireConfig<3000,0,0>,FireConfig<0,4000,0>>>,SmoothStep<Scale<TwistAngle<>,Int<27000>,Int<29000>>,Int<2000>>>,TrWipeIn<600>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>>>>(),
"Green Humpflicker"
"PURPLE;common",
StylePtr<Layers<Layers<RotateColorsX<Variation,Rgb<95,0,210>>,HumpFlickerL<RotateColorsX<Variation,Rgb<48,0,105>>,50>>,TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<5000>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>,LockupTrL<Layers<AlphaL<TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<3000>>,Int<30>,Int<800>>>,Mix<SlowNoise<Int<1000>>,Black,Black,White,Black>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<10>,Int<30>>>>>,Int<32768>>,AlphaL<Blinking<Tomato,Strobe<Yellow,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<8000>,Int<18000>>>>,AlphaL<Blinking<BrownNoiseFlicker<White,Black,50>,BrownNoiseFlicker<Yellow,Tomato,50>,100,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<9000>>>>,TrConcat<TrInstant,AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,TrSmoothFade<900>,SaberBase::LOCKUP_NORMAL>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Strobe<GreenYellow,Black,20,30>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<15000>>>,TrFade<600>>,EFFECT_LOCKUP_BEGIN>,TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<225>>,EFFECT_LOCKUP_BEGIN>,LockupTrL<Layers<AlphaL<White,StrobeF<Scale<SlowNoise<Int<1000>>,Int<1>,Int<6>>,Scale<SlowNoise<Int<1000>>,Int<10>,Int<50>>>>,AlphaL<RandomFlicker<Strobe<White,Rgb<83,0,255>,50,10>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>>,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<100>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<150>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<400>>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,ResponsiveStabL<RandomPerLEDFlicker<NavajoWhite,Rgb<255,187,78>>>,ResponsiveBlastL<TransitionEffect<Rgb<255,150,0>,White,TrInstant,TrFade<80>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,White,TrInstant,TrDelay<120>,EFFECT_CLASH>,TrConcat<TrInstant,AlphaL<GreenYellow,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<18000>>>,TrDelay<65>>,TrFade<280>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<18000>>,LockupTrL<AlphaL<AudioFlicker<BrownNoiseFlicker<Strobe<Black,OrangeRed,20,25>,Yellow,200>,White>,SmoothStep<Int<30000>,Int<2000>>>,TrWipeIn<400>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_DRAG>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<400>>,EFFECT_DRAG_BEGIN>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<700>>,EFFECT_DRAG_END>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,RandomPerLEDFlicker<Orange,OrangeRed>,BrownNoiseFlicker<Rgb16<20095,128,128>,Rgb16<35103,8175,298>,150>,StyleFire<Rgb16<20393,93,93>,Red,0,4,FireConfig<0,2000,5>,FireConfig<3000,0,0>,FireConfig<0,4000,0>>>,SmoothStep<Scale<TwistAngle<>,Int<27000>,Int<29000>>,Int<2000>>>,TrWipeIn<600>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>>>>(),
"Purple Humpflicker"
"YELLOW;common",
StylePtr<Layers<Layers<RotateColorsX<Variation,Rgb<180,130,0>>,HumpFlickerL<RotateColorsX<Variation,Rgb<90,65,0>>,50>>,TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<5000>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>,LockupTrL<Layers<AlphaL<TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<3000>>,Int<30>,Int<800>>>,Mix<SlowNoise<Int<1000>>,Black,Black,White,Black>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<10>,Int<30>>>>>,Int<32768>>,AlphaL<Blinking<Tomato,Strobe<Yellow,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<8000>,Int<18000>>>>,AlphaL<Blinking<BrownNoiseFlicker<White,Black,50>,BrownNoiseFlicker<Yellow,Tomato,50>,100,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<9000>>>>,TrConcat<TrInstant,AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,TrSmoothFade<900>,SaberBase::LOCKUP_NORMAL>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Strobe<GreenYellow,Black,20,30>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<15000>>>,TrFade<600>>,EFFECT_LOCKUP_BEGIN>,TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<225>>,EFFECT_LOCKUP_BEGIN>,LockupTrL<Layers<AlphaL<White,StrobeF<Scale<SlowNoise<Int<1000>>,Int<1>,Int<6>>,Scale<SlowNoise<Int<1000>>,Int<10>,Int<50>>>>,AlphaL<RandomFlicker<Strobe<White,Rgb<83,0,255>,50,10>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>>,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<100>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<150>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<400>>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,ResponsiveStabL<RandomPerLEDFlicker<NavajoWhite,Rgb<255,187,78>>>,ResponsiveBlastL<TransitionEffect<Rgb<255,150,0>,White,TrInstant,TrFade<80>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,White,TrInstant,TrDelay<120>,EFFECT_CLASH>,TrConcat<TrInstant,AlphaL<GreenYellow,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<18000>>>,TrDelay<65>>,TrFade<280>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<18000>>,LockupTrL<AlphaL<AudioFlicker<BrownNoiseFlicker<Strobe<Black,OrangeRed,20,25>,Yellow,200>,White>,SmoothStep<Int<30000>,Int<2000>>>,TrWipeIn<400>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_DRAG>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<400>>,EFFECT_DRAG_BEGIN>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<700>>,EFFECT_DRAG_END>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,RandomPerLEDFlicker<Orange,OrangeRed>,BrownNoiseFlicker<Rgb16<20095,128,128>,Rgb16<35103,8175,298>,150>,StyleFire<Rgb16<20393,93,93>,Red,0,4,FireConfig<0,2000,5>,FireConfig<3000,0,0>,FireConfig<0,4000,0>>>,SmoothStep<Scale<TwistAngle<>,Int<27000>,Int<29000>>,Int<2000>>>,TrWipeIn<600>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>>>>(),
"Yellow Humpflicker"
"WHITE;common",
StylePtr<Layers<Layers<RotateColorsX<Variation,Rgb<100,100,150>>,HumpFlickerL<RotateColorsX<Variation,Rgb<50,50,75>>,50>>,TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<5000>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>,LockupTrL<Layers<AlphaL<TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<3000>>,Int<30>,Int<800>>>,Mix<SlowNoise<Int<1000>>,Black,Black,White,Black>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<10>,Int<30>>>>>,Int<32768>>,AlphaL<Blinking<Tomato,Strobe<Yellow,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<8000>,Int<18000>>>>,AlphaL<Blinking<BrownNoiseFlicker<White,Black,50>,BrownNoiseFlicker<Yellow,Tomato,50>,100,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<9000>>>>,TrConcat<TrInstant,AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,TrSmoothFade<900>,SaberBase::LOCKUP_NORMAL>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Strobe<GreenYellow,Black,20,30>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<15000>>>,TrFade<600>>,EFFECT_LOCKUP_BEGIN>,TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<225>>,EFFECT_LOCKUP_BEGIN>,LockupTrL<Layers<AlphaL<White,StrobeF<Scale<SlowNoise<Int<1000>>,Int<1>,Int<6>>,Scale<SlowNoise<Int<1000>>,Int<10>,Int<50>>>>,AlphaL<RandomFlicker<Strobe<White,Rgb<83,0,255>,50,10>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>>,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<100>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<150>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<400>>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,ResponsiveStabL<RandomPerLEDFlicker<NavajoWhite,Rgb<255,187,78>>>,ResponsiveBlastL<TransitionEffect<Rgb<255,150,0>,White,TrInstant,TrFade<80>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,White,TrInstant,TrDelay<120>,EFFECT_CLASH>,TrConcat<TrInstant,AlphaL<GreenYellow,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<18000>>>,TrDelay<65>>,TrFade<280>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<18000>>,LockupTrL<AlphaL<AudioFlicker<BrownNoiseFlicker<Strobe<Black,OrangeRed,20,25>,Yellow,200>,White>,SmoothStep<Int<30000>,Int<2000>>>,TrWipeIn<400>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_DRAG>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<400>>,EFFECT_DRAG_BEGIN>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<700>>,EFFECT_DRAG_END>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,RandomPerLEDFlicker<Orange,OrangeRed>,BrownNoiseFlicker<Rgb16<20095,128,128>,Rgb16<35103,8175,298>,150>,StyleFire<Rgb16<20393,93,93>,Red,0,4,FireConfig<0,2000,5>,FireConfig<3000,0,0>,FireConfig<0,4000,0>>>,SmoothStep<Scale<TwistAngle<>,Int<27000>,Int<29000>>,Int<2000>>>,TrWipeIn<600>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>>>>(),
"White Humpflicker"
"Darksaber_Mando;common",
"common/tracks/Mando_Theme.wav",
StylePtr<Layers<AudioFlicker<BrownNoiseFlicker<Mix<SwingSpeed<400>,RotateColorsX<Variation,Rgb<100,100,150>>,RotateColorsX<Variation,Rgb<150,150,225>>>,Stripes<5000,-300,RotateColorsX<Variation,Rgb<25,25,55>>,RotateColorsX<Variation,Rgb<75,75,120>>,RotateColorsX<Variation,Rgb<10,10,20>>,RotateColorsX<Variation,Rgb<50,50,75>>>,300>,RotateColorsX<Variation,Rgb<35,35,75>>>,TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<5000>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>,LockupTrL<Layers<AlphaL<TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<3000>>,Int<30>,Int<800>>>,Mix<SlowNoise<Int<1000>>,Black,Black,White,Black>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<10>,Int<30>>>>>,Int<32768>>,AlphaL<Blinking<Tomato,Strobe<Yellow,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<8000>,Int<18000>>>>,AlphaL<Blinking<BrownNoiseFlicker<White,Black,50>,BrownNoiseFlicker<Yellow,Tomato,50>,100,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<9000>>>>,TrConcat<TrInstant,AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,TrSmoothFade<900>,SaberBase::LOCKUP_NORMAL>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Strobe<GreenYellow,Black,20,30>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<15000>>>,TrFade<600>>,EFFECT_LOCKUP_BEGIN>,TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<225>>,EFFECT_LOCKUP_BEGIN>,LockupTrL<Layers<AlphaL<White,StrobeF<Scale<SlowNoise<Int<1000>>,Int<1>,Int<6>>,Scale<SlowNoise<Int<1000>>,Int<10>,Int<50>>>>,AlphaL<RandomFlicker<Strobe<White,Rgb<83,0,255>,50,10>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>>,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<100>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<150>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<400>>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,ResponsiveStabL<RandomPerLEDFlicker<NavajoWhite,Rgb<255,187,78>>>,ResponsiveBlastL<TransitionEffect<Rgb<255,150,0>,White,TrInstant,TrFade<80>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,White,TrInstant,TrDelay<120>,EFFECT_CLASH>,TrConcat<TrInstant,AlphaL<GreenYellow,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<18000>>>,TrDelay<65>>,TrFade<280>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<18000>>,LockupTrL<AlphaL<AudioFlicker<BrownNoiseFlicker<Strobe<Black,OrangeRed,20,25>,Yellow,200>,White>,SmoothStep<Int<30000>,Int<2000>>>,TrWipeIn<400>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_DRAG>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<400>>,EFFECT_DRAG_BEGIN>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<700>>,EFFECT_DRAG_END>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,RandomPerLEDFlicker<Orange,OrangeRed>,BrownNoiseFlicker<Rgb16<20095,128,128>,Rgb16<35103,8175,298>,150>,StyleFire<Rgb16<20393,93,93>,Red,0,4,FireConfig<0,2000,5>,FireConfig<3000,0,0>,FireConfig<0,4000,0>>>,SmoothStep<Scale<TwistAngle<>,Int<27000>,Int<29000>>,Int<2000>>>,TrWipeIn<600>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<500>>,TrWipeInX<RetractionTime<0>>>>>(),
"Darksaber"
"Darksaber_TCW;common",
"common/tracks/Maul_vs_Vizsla.wav",
StylePtr<Layers<AudioFlicker<BrownNoiseFlicker<Mix<SwingSpeed<400>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,Mix<Int<6425>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,White>>,Stripes<5000,-300,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>,Mix<Int<25700>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>,Mix<Int<1285>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,300>,Mix<Int<6425>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,White>>,TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<5000>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>,LockupTrL<Layers<AlphaL<TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<3000>>,Int<30>,Int<800>>>,Mix<SlowNoise<Int<1000>>,Black,Black,White,Black>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<10>,Int<30>>>>>,Int<32768>>,AlphaL<Blinking<Tomato,Strobe<Yellow,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<8000>,Int<18000>>>>,AlphaL<Blinking<BrownNoiseFlicker<White,Black,50>,BrownNoiseFlicker<Yellow,Tomato,50>,100,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<9000>>>>,TrConcat<TrInstant,AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,TrSmoothFade<900>,SaberBase::LOCKUP_NORMAL>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Strobe<GreenYellow,Black,20,30>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<15000>>>,TrFade<600>>,EFFECT_LOCKUP_BEGIN>,TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<225>>,EFFECT_LOCKUP_BEGIN>,LockupTrL<Layers<AlphaL<White,StrobeF<Scale<SlowNoise<Int<1000>>,Int<1>,Int<6>>,Scale<SlowNoise<Int<1000>>,Int<10>,Int<50>>>>,AlphaL<RandomFlicker<Strobe<White,Rgb<83,0,255>,50,10>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>>,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<100>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<150>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<400>>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,ResponsiveStabL<RandomPerLEDFlicker<NavajoWhite,Rgb<255,187,78>>>,ResponsiveBlastL<TransitionEffect<Rgb<255,150,0>,White,TrInstant,TrFade<80>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,White,TrInstant,TrDelay<120>,EFFECT_CLASH>,TrConcat<TrInstant,AlphaL<GreenYellow,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<18000>>>,TrDelay<65>>,TrFade<280>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<18000>>,LockupTrL<AlphaL<AudioFlicker<BrownNoiseFlicker<Strobe<Black,OrangeRed,20,25>,Yellow,200>,White>,SmoothStep<Int<30000>,Int<2000>>>,TrWipeIn<400>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_DRAG>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<400>>,EFFECT_DRAG_BEGIN>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<700>>,EFFECT_DRAG_END>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,RandomPerLEDFlicker<Orange,OrangeRed>,BrownNoiseFlicker<Rgb16<20095,128,128>,Rgb16<35103,8175,298>,150>,StyleFire<Rgb16<20393,93,93>,Red,0,4,FireConfig<0,2000,5>,FireConfig<3000,0,0>,FireConfig<0,4000,0>>>,SmoothStep<Scale<TwistAngle<>,Int<27000>,Int<29000>>,Int<2000>>>,TrWipeIn<600>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>>>>(),
"Darksaber"
"KRossguard_TFA;common",
"common/tracks/Kylo_Theme.wav",
StylePtr<Layers<Stripes<3000,-3500,RotateColorsX<Variation,Red>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<60,0,0>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<30,0,0>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<80,0,0>>,RotateColorsX<Variation,Rgb<30,0,0>>>>,TransitionLoopL<TrConcat<TrWaveX<AudioFlicker<RotateColorsX<Variation,Red>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<80,0,0>>,Black,200>>,Int<400>,Int<100>,Int<200>,Int<0>>,AlphaL<Red,Int<0>>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<100>,Int<1000>>>>>,TransitionLoopL<TrConcat<TrWaveX<AudioFlicker<RotateColorsX<Variation,Red>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<60,0,0>>,300>>,Int<400>,Int<100>,Int<200>,Int<0>>,AlphaL<Red,Int<0>>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<200>,Int<1500>>>>>,TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<5000>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>,LockupTrL<Layers<AlphaL<TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<3000>>,Int<30>,Int<800>>>,Mix<SlowNoise<Int<1000>>,Black,Black,White,Black>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<10>,Int<30>>>>>,Int<32768>>,AlphaL<Blinking<Tomato,Strobe<Yellow,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<8000>,Int<18000>>>>,AlphaL<Blinking<BrownNoiseFlicker<White,Black,50>,BrownNoiseFlicker<Yellow,Tomato,50>,100,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<9000>>>>,TrConcat<TrInstant,AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,TrSmoothFade<900>,SaberBase::LOCKUP_NORMAL>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Strobe<GreenYellow,Black,20,30>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<15000>>>,TrFade<600>>,EFFECT_LOCKUP_BEGIN>,TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<225>>,EFFECT_LOCKUP_BEGIN>,LockupTrL<Layers<AlphaL<White,StrobeF<Scale<SlowNoise<Int<1000>>,Int<1>,Int<6>>,Scale<SlowNoise<Int<1000>>,Int<10>,Int<50>>>>,AlphaL<RandomFlicker<Strobe<White,Rgb<83,0,255>,50,10>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>>,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<100>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<150>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<400>>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,ResponsiveStabL<RandomPerLEDFlicker<NavajoWhite,Rgb<255,187,78>>>,ResponsiveBlastL<TransitionEffect<Rgb<255,150,0>,White,TrInstant,TrFade<80>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,White,TrInstant,TrDelay<120>,EFFECT_CLASH>,TrConcat<TrInstant,AlphaL<GreenYellow,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<18000>>>,TrDelay<65>>,TrFade<280>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<18000>>,LockupTrL<AlphaL<AudioFlicker<BrownNoiseFlicker<Strobe<Black,OrangeRed,20,25>,Yellow,200>,White>,SmoothStep<Int<30000>,Int<2000>>>,TrWipeIn<400>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_DRAG>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<400>>,EFFECT_DRAG_BEGIN>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<700>>,EFFECT_DRAG_END>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,RandomPerLEDFlicker<Orange,OrangeRed>,BrownNoiseFlicker<Rgb16<20095,128,128>,Rgb16<35103,8175,298>,150>,StyleFire<Rgb16<20393,93,93>,Red,0,4,FireConfig<0,2000,5>,FireConfig<3000,0,0>,FireConfig<0,4000,0>>>,SmoothStep<Scale<TwistAngle<>,Int<27000>,Int<29000>>,Int<2000>>>,TrWipeIn<600>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>>>>(),
"Unstable Rage"
"KRossguard_TROS;common",
"common/tracks/TROS_Trailer.wav",
StylePtr<Layers<StyleFire<Gradient<RotateColorsX<Variation,Orange>,RotateColorsX<Variation,OrangeRed>,RotateColorsX<Variation,Red>>,RotateColorsX<Variation,Yellow>,0,3,FireConfig<0,2000,5>,FireConfig<0,1500,5>,FireConfig<0,1500,5>,FireConfig<0,1500,5>>,TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<5000>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>,LockupTrL<Layers<AlphaL<TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<3000>>,Int<30>,Int<800>>>,Mix<SlowNoise<Int<1000>>,Black,Black,White,Black>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<10>,Int<30>>>>>,Int<32768>>,AlphaL<Blinking<Tomato,Strobe<Yellow,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<8000>,Int<18000>>>>,AlphaL<Blinking<BrownNoiseFlicker<White,Black,50>,BrownNoiseFlicker<Yellow,Tomato,50>,100,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<9000>>>>,TrConcat<TrInstant,AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,TrSmoothFade<900>,SaberBase::LOCKUP_NORMAL>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Strobe<GreenYellow,Black,20,30>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<15000>>>,TrFade<600>>,EFFECT_LOCKUP_BEGIN>,TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<225>>,EFFECT_LOCKUP_BEGIN>,LockupTrL<Layers<AlphaL<White,StrobeF<Scale<SlowNoise<Int<1000>>,Int<1>,Int<6>>,Scale<SlowNoise<Int<1000>>,Int<10>,Int<50>>>>,AlphaL<RandomFlicker<Strobe<White,Rgb<83,0,255>,50,10>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>>,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<100>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<150>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<400>>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,ResponsiveStabL<RandomPerLEDFlicker<NavajoWhite,Rgb<255,187,78>>>,ResponsiveBlastL<TransitionEffect<Rgb<255,150,0>,White,TrInstant,TrFade<80>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,White,TrInstant,TrDelay<120>,EFFECT_CLASH>,TrConcat<TrInstant,AlphaL<GreenYellow,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<18000>>>,TrDelay<65>>,TrFade<280>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<18000>>,LockupTrL<AlphaL<AudioFlicker<BrownNoiseFlicker<Strobe<Black,OrangeRed,20,25>,Yellow,200>,White>,SmoothStep<Int<30000>,Int<2000>>>,TrWipeIn<400>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_DRAG>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<400>>,EFFECT_DRAG_BEGIN>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<700>>,EFFECT_DRAG_END>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,RandomPerLEDFlicker<Orange,OrangeRed>,BrownNoiseFlicker<Rgb16<20095,128,128>,Rgb16<35103,8175,298>,150>,StyleFire<Rgb16<20393,93,93>,Red,0,4,FireConfig<0,2000,5>,FireConfig<3000,0,0>,FireConfig<0,4000,0>>>,SmoothStep<Scale<TwistAngle<>,Int<27000>,Int<29000>>,Int<2000>>>,TrWipeIn<600>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<>>>>>(),
"Fire"
"Senate_Majority;common",
"common/tracks/Duel_of_the_Fates.wav",
StylePtr<Layers<Mix<SwingSpeed<500>,AudioFlicker<Gradient<Gradient<BrownNoiseFlicker<Black,Orange,400>,Red>,Red,Red,Red,Red,Red,Red,Red>,Rgb<120,0,0>>,Gradient<BrownNoiseFlicker<Black,DarkOrange,400>,BrownNoiseFlicker<Black,Rgb<128,0,0>,400>,BrownNoiseFlicker<Black,Rgb<128,0,0>,400>,BrownNoiseFlicker<Black,Rgb<128,0,0>,400>>>,TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<5000>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>,LockupTrL<Layers<AlphaL<TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<3000>>,Int<30>,Int<800>>>,Mix<SlowNoise<Int<1000>>,Black,Black,White,Black>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<10>,Int<30>>>>>,Int<32768>>,AlphaL<Blinking<Tomato,Strobe<Yellow,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<8000>,Int<18000>>>>,AlphaL<Blinking<BrownNoiseFlicker<White,Black,50>,BrownNoiseFlicker<Yellow,Tomato,50>,100,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<9000>>>>,TrConcat<TrInstant,AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,TrSmoothFade<900>,SaberBase::LOCKUP_NORMAL>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Strobe<GreenYellow,Black,20,30>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<15000>>>,TrFade<600>>,EFFECT_LOCKUP_BEGIN>,TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<225>>,EFFECT_LOCKUP_BEGIN>,LockupTrL<Layers<AlphaL<White,StrobeF<Scale<SlowNoise<Int<1000>>,Int<1>,Int<6>>,Scale<SlowNoise<Int<1000>>,Int<10>,Int<50>>>>,AlphaL<RandomFlicker<Strobe<White,Rgb<83,0,255>,50,10>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>>,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<100>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<150>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<400>>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,ResponsiveStabL<RandomPerLEDFlicker<NavajoWhite,Rgb<255,187,78>>>,ResponsiveBlastL<TransitionEffect<Rgb<255,150,0>,White,TrInstant,TrFade<80>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,White,TrInstant,TrDelay<120>,EFFECT_CLASH>,TrConcat<TrInstant,AlphaL<GreenYellow,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<18000>>>,TrDelay<65>>,TrFade<280>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<18000>>,LockupTrL<AlphaL<AudioFlicker<BrownNoiseFlicker<Strobe<Black,OrangeRed,20,25>,Yellow,200>,White>,SmoothStep<Int<30000>,Int<2000>>>,TrWipeIn<400>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_DRAG>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<400>>,EFFECT_DRAG_BEGIN>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<700>>,EFFECT_DRAG_END>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,RandomPerLEDFlicker<Orange,OrangeRed>,BrownNoiseFlicker<Rgb16<20095,128,128>,Rgb16<35103,8175,298>,150>,StyleFire<Rgb16<20393,93,93>,Red,0,4,FireConfig<0,2000,5>,FireConfig<3000,0,0>,FireConfig<0,4000,0>>>,SmoothStep<Scale<TwistAngle<>,Int<27000>,Int<29000>>,Int<2000>>>,TrWipeIn<600>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_MELT>,InOutTrL<TrConcat<TrColorCycle<80,-400>,White,TrWipeIn<50>,Black,TrDelay<450>,Strobe<Black,White,45,60>,TrJoinR<TrSmoothFade<190>,TrWipe<200>>>,TrConcat<TrInstant,White,TrJoin<TrJoin<TrJoin<TrColorCycle<2050,-1500>,TrBoing<2050,15>>,TrBoing<2050,18>>,TrSmoothFade<2050>>>>>>(),
"Senate Majority"
"Godzilla;common",
StylePtr<Layers<StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Blue>,Black,20>,RotateColorsX<Variation,Rgb<0,0,10>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<25,25,255>>,70>,RotateColorsX<Variation,Rgb<0,0,128>>>,RotateColorsX<Variation,Rgb<0,0,80>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,AlphaL<BrownNoiseFlicker<RotateColorsX<Variation,Blue>,Black,300>,SwingSpeed<400>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<16000>>>,TrFade<400>>,EFFECT_LOCKUP_END>,AlphaL<TransitionEffect<White,Rgb<128,0,0>,TrInstant,TrConcat<TrFade<1500>,Blue,TrFade<2000>,Orange,TrFade<2500>>,EFFECT_IGNITION>,Bump<Int<0>,Int<6000>>>,TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<Cyan,40>,TrFade<1000>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<5000>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>,LockupTrL<Layers<AlphaL<TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<3000>>,Int<30>,Int<800>>>,Mix<SlowNoise<Int<1000>>,Black,Black,White,Black>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<10>,Int<30>>>>>,Int<32768>>,AlphaL<Blinking<Tomato,Strobe<Yellow,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<8000>,Int<18000>>>>,AlphaL<Blinking<BrownNoiseFlicker<White,Black,50>,BrownNoiseFlicker<Yellow,Tomato,50>,100,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<9000>>>>,TrConcat<TrInstant,AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,TrSmoothFade<900>,SaberBase::LOCKUP_NORMAL>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Strobe<GreenYellow,Black,20,30>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<15000>>>,TrFade<600>>,EFFECT_LOCKUP_BEGIN>,TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<225>>,EFFECT_LOCKUP_BEGIN>,LockupTrL<Layers<AlphaL<White,StrobeF<Scale<SlowNoise<Int<1000>>,Int<1>,Int<6>>,Scale<SlowNoise<Int<1000>>,Int<10>,Int<50>>>>,AlphaL<RandomFlicker<Strobe<White,Rgb<83,0,255>,50,10>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>>,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<100>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<150>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<400>>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,ResponsiveStabL<RandomPerLEDFlicker<NavajoWhite,Rgb<255,187,78>>>,ResponsiveBlastL<TransitionEffect<Rgb<255,150,0>,White,TrInstant,TrFade<80>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,White,TrInstant,TrDelay<120>,EFFECT_CLASH>,TrConcat<TrInstant,AlphaL<GreenYellow,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<18000>>>,TrDelay<65>>,TrFade<280>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<18000>>,LockupTrL<AlphaL<AudioFlicker<BrownNoiseFlicker<Strobe<Black,OrangeRed,20,25>,Yellow,200>,White>,SmoothStep<Int<30000>,Int<2000>>>,TrWipeIn<400>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_DRAG>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<400>>,EFFECT_DRAG_BEGIN>,TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<Rgb<255,220,28>,40>,Bump<Int<32768>,Int<24000>>>,TrSmoothFade<700>>,EFFECT_DRAG_END>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,RandomPerLEDFlicker<Orange,OrangeRed>,BrownNoiseFlicker<Rgb16<20095,128,128>,Rgb16<35103,8175,298>,150>,StyleFire<Rgb16<20393,93,93>,Red,0,4,FireConfig<0,2000,5>,FireConfig<3000,0,0>,FireConfig<0,4000,0>>>,SmoothStep<Scale<TwistAngle<>,Int<27000>,Int<29000>>,Int<2000>>>,TrWipeIn<600>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<Cyan,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,TrDelay<2000>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrWaveX<Blue,Int<400>,Int<400>,Int<400>,Int<32768>>,AlphaL<PulsingL<Blue,Int<1000>>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<1000>,AlphaL<PulsingL<Blue,Int<1000>>,SmoothStep<Int<2000>,Int<-3000>>>,TrWaveX<Cyan,Int<400>,Int<400>,Int<400>,Int<32768>>,AlphaL<PulsingL<ColorSequence<400,Blue,Cyan>,Int<1000>>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<800>,AlphaL<PulsingL<ColorSequence<400,Cyan,Blue>,Int<1000>>,SmoothStep<Int<2000>,Int<-3000>>>,TrWaveX<Cyan,Int<350>,Int<200>,Int<350>,Int<32768>>,AlphaL<PulsingL<ColorSequence<350,DeepSkyBlue,Cyan,White>,Int<800>>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<800>,AlphaL<PulsingL<ColorSequence<350,DodgerBlue,DeepSkyBlue,Blue>,Int<800>>,SmoothStep<Int<2000>,Int<-3000>>>,TrWaveX<Cyan,Int<350>,Int<400>,Int<350>,Int<32768>>,AlphaL<PulsingL<ColorSequence<350,Blue,Cyan,DodgerBlue,Cyan>,Int<700>>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<700>,AlphaL<PulsingL<ColorSequence<350,Blue,DodgerBlue,Cyan,Cyan>,Int<700>>,SmoothStep<Int<2000>,Int<-3000>>>,TrWaveX<Cyan,Int<300>,Int<400>,Int<300>,Int<32768>>,AlphaL<PulsingL<ColorSequence<300,Blue,DodgerBlue,Cyan,Cyan,Cyan>,Int<600>>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<700>,AlphaL<PulsingL<ColorSequence<300,Cyan,Blue,DodgerBlue,Cyan,Cyan>,Int<600>>,SmoothStep<Int<2000>,Int<-3000>>>,TrWaveX<Blue,Int<300>,Int<400>,Int<300>,Int<32768>>,AlphaL<PulsingL<ColorSequence<250,Cyan,Blue,DodgerBlue,Cyan,Cyan,White>,Int<400>>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<600>,AlphaL<PulsingL<ColorSequence<200,Blue,Cyan,Blue,DodgerBlue,Cyan,Cyan>,Int<500>>,SmoothStep<Int<2000>,Int<-3000>>>,TrWaveX<Cyan,Int<250>,Int<300>,Int<250>,Int<32768>>,AlphaL<PulsingL<ColorSequence<100,Blue,Cyan,White,DodgerBlue,Cyan,Cyan>,Int<300>>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<600>,AlphaL<ColorSequence<200,White,Blue,Cyan,Blue,DodgerBlue,Cyan,Cyan>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<1050>>,EFFECT_PREON>>>(),
"Godzilla"
"BLUE;common",
StylePtr<LengthFinder<>>(),
"Pixel Counter"
{ 0, WS281XBladePtr<122, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3>>(), CONFIGARRAY(presets) },
Button PowerButton(BUTTON_POWER, auxPin, "aux");
Button AuxButton(BUTTON_AUX, powerButtonPin, "pow");
