OS 5.9 - Ghost of Tapal (Fallen Order) Revised - Revo
ADVISORY TO THOSE WHO ARE PHOTOSENSITIVE: This bladestlye relies heavily on strobe/pulsing and rapidly changing color effects.
I changed where the Force Ladder (Jacob’s Ladder) sits in the bladestyle so when ForceEffect is used it disappears and then when the effect ends it reappears. It’s also a bit more blended into the bladestyle itself so as to better the visual of the Master’s now damaged lightsaber being on it’s last legs before catastrophic failure.
{ "fontnamehere;common","tracks/none.wav",
StylePtr<
Layers<
  RotateColorsX<Variation,Black>,
  AudioFlickerL<RotateColorsX<Variation,Rgb<108,108,108>>>,
  AudioFlickerL<RotateColorsX<Variation,Rgb<0,0,158>>>,
  AlphaL<Stripes<10000,-2000,HumpFlicker<Rgb<0,0,40>,Rgb<20,30,0>,50>,HumpFlicker<Blue,NavajoWhite,50>,HumpFlicker<Rgb<0,0,80>,Rgb<40,60,0>,50>>,SwingSpeed<600>>,
  TransitionLoopL<TrConcat<TrDelayX<Scale<Sin<Int<12>>,Int<400>,Int<100>>>,AlphaL<Black,Int<0>>,TrWaveX<BrownNoiseFlicker<White,Rgb<50,50,255>,50>,Scale<Sin<Int<10>>,Int<500>,Int<1500>>,Int<100>,Scale<SlowNoise<Int<1200>>,Int<600>,Int<1200>>,Int<0>>>>,
  TransitionEffectL<TrConcat<TrFade<600>,Pulsing<ColorChange<TrInstant,Rgb<0,0,150>>,ColorChange<TrInstant,Rgb<0,40,250>>,800>,TrDelay<30000>>,EFFECT_FORCE>,
  TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,
  LockupTrL<Layers<
    AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<90,890>,Int<25>,Int<8000>>,Int<800>>,Scale<SwingSpeed<100>,Int<8>,Int<100>>>>,
    AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<40>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,Red,TrFade<400>>,TrConcat<TrInstant,Red,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
  ResponsiveStabL<Red>,
  ResponsiveBlastL<TransitionEffect<Azure,White,TrInstant,TrFade<100>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
  ResponsiveClashL<TransitionEffect<Azure,White,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
  LockupTrL<AlphaL<Mix<TwistAngle<>,Stripes<1000,3000,Cyan,White,Rgb<0,50,50>,Rgb<75,75,75>>,Stripes<2000,3000,Rgb<75,75,75>,Rgb<75,75,75>,Rgb<100,100,100>,Rgb<60,60,60>>>,SmoothStep<Scale<TwistAngle<>,Int<29000>,Int<26000>>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
  LockupTrL<AlphaL<Mix<TwistAngle<>,Stripes<1000,3000,Red,Black,Rgb<200,0,0>,Rgb<90,0,0>>,Stripes<2000,3000,Rgb<255,200,0>,Rgb<100,75,0>,Rgb<200,160,0>,Rgb<60,40,0>>>,SmoothStep<Scale<TwistAngle<>,Int<29000>,Int<26000>>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,
  InOutTrL<TrWipe<300>,TrWipeIn<500>>,
  TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Int<4000>,Int<-4000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Int<4000>,Int<4000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>,AlphaL<Black,Scale<IsLessThan<BatteryLevel,Int<11000>>,Int<0>,Int<11000>>>>>(), "GhostOfTapalBladestyle"},
