Ok, so I have a weird little puzzle occurring that I haven’t been able to solve.
I recently changed fonts and styles to match the Cal Kestis Multi-phase styles in Fett’s library.
With previous styles, #define ORIENTATION ORIENTATION_USB_TOWARDS_BLADE worked to have everything function correctly. In particular Melt and Drag. Now for some reason, drag only works on the ceiling. Mind you that with previous styles, I added the orientation define because without it Drag was on the ceiling. So with this style, I removed it and Melt and Drag stopped working altogether. Any tip poke would just make a clash. I then tried each of these one at a time and had the same issue. No Melt and Drag.
#define ORIENTATION ORIENTATION_NORMAL
#define ORIENTATION ORIENTATION_FETS_TOWARDS_BLADE
#define ORIENTATION ORIENTATION_SDA_TOWARDS_BLADE
So my question is, what the hell is going on? What would be the opposite orientation of USB TOWARDS BLADE? Is it one of the ones I haven’t tried yet or is something else going on?
Also, why would USB_TOWARDS_BLADE function one way on one config and a different way on another?
Appreciate any assistance!
rory
Is the USB port actually pointing to the emitter?
Post your config and specify the preset you’re having an issue with.
hi!
the issue is present with every preset.
thanks!
#define NUM_BLADES 2
#define VOLUME 1550
const unsigned int maxLedsPerStrip = 128;
#define CLASH_THRESHOLD_G 3.0
#define ENABLE_SERIAL
#define SAVE-STATE
#define FETT263_SWING_ON
#define FETT263_FORCE_PUSH_LENGTH 3
#define FETT263_TWIST_ON
#define IDLE_OFF_TIME 5 * 60 * 1000
#define FETT263_MULTI_PHASE
#define FETT263_THRUST_ON
#define FETT263_EFFECT_BATTERY_LEVEL
{ “Blue;common”, “tracks/JFO1.wav”,
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,Blue>,Pulsing<RotateColorsX<Variation,Rgb<0,0,90>>,RotateColorsX<Variation,Blue>,800>,RotateColorsX<Variation,Blue>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,160>>>,TrDelay<30000>,RotateColorsX<Variation,Blue>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,Blue>,Pulsing<RotateColorsX<Variation,Rgb<0,0,90>>,RotateColorsX<Variation,Blue>,800>,RotateColorsX<Variation,Blue>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,160>>>,TrDelay<30000>,RotateColorsX<Variation,Blue>,TrFade<800>>,EFFECT_FORCE>,InOutTrL<TrInstant,TrFade<300>,Mix<IsLessThan<SlowNoise<Int<3000>>,Int<10000>>,RandomFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,90>>>,Black>>>>(), “0”},
{ “Cyan;common”, “tracks/JFO2.wav”,
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,Rgb<30,120,150>>,Pulsing<RotateColorsX<Variation,Rgb<11,42,53>>,RotateColorsX<Variation,Rgb<30,120,150>>,800>,RotateColorsX<Variation,Rgb<30,120,150>>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Rgb<30,120,150>>,RotateColorsX<Variation,Rgb<19,75,94>>>,TrDelay<30000>,RotateColorsX<Variation,Rgb<30,120,150>>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,Rgb<30,120,150>>,Pulsing<RotateColorsX<Variation,Rgb<11,42,53>>,RotateColorsX<Variation,Rgb<30,120,150>>,800>,RotateColorsX<Variation,Rgb<30,120,150>>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Rgb<30,120,150>>,RotateColorsX<Variation,Rgb<19,75,94>>>,TrDelay<30000>,RotateColorsX<Variation,Rgb<30,120,150>>,TrFade<800>>,EFFECT_FORCE>,InOutTrL<TrInstant,TrFade<300>,Mix<IsLessThan<SlowNoise<Int<3000>>,Int<10000>>,RandomFlicker<RotateColorsX<Variation,Rgb<30,120,150>>,RotateColorsX<Variation,Rgb<11,42,53>>>,Black>>>>(), “0”},
{ “Green;common”, “tracks/JFO3.wav”,
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,Green>,Pulsing<RotateColorsX<Variation,Rgb<0,90,0>>,RotateColorsX<Variation,Green>,800>,RotateColorsX<Variation,Green>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,160,0>>>,TrDelay<30000>,RotateColorsX<Variation,Green>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,Green>,Pulsing<RotateColorsX<Variation,Rgb<0,90,0>>,RotateColorsX<Variation,Green>,800>,RotateColorsX<Variation,Green>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,160,0>>>,TrDelay<30000>,RotateColorsX<Variation,Green>,TrFade<800>>,EFFECT_FORCE>,InOutTrL<TrInstant,TrFade<300>,Mix<IsLessThan<SlowNoise<Int<3000>>,Int<10000>>,RandomFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,90,0>>>,Black>>>>(), “0”},
{ “Indigo;common”, “tracks/JFO4.wav”,
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,Rgb<80,50,200>>,Pulsing<RotateColorsX<Variation,Rgb<28,18,71>>,RotateColorsX<Variation,Rgb<80,50,200>>,800>,RotateColorsX<Variation,Rgb<80,50,200>>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Rgb<80,50,200>>,RotateColorsX<Variation,Rgb<50,31,125>>>,TrDelay<30000>,RotateColorsX<Variation,Rgb<80,50,200>>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,Rgb<80,50,200>>,Pulsing<RotateColorsX<Variation,Rgb<28,18,71>>,RotateColorsX<Variation,Rgb<80,50,200>>,800>,RotateColorsX<Variation,Rgb<80,50,200>>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Rgb<80,50,200>>,RotateColorsX<Variation,Rgb<50,31,125>>>,TrDelay<30000>,RotateColorsX<Variation,Rgb<80,50,200>>,TrFade<800>>,EFFECT_FORCE>,InOutTrL<TrInstant,TrFade<300>,Mix<IsLessThan<SlowNoise<Int<3000>>,Int<10000>>,RandomFlicker<RotateColorsX<Variation,Rgb<80,50,200>>,RotateColorsX<Variation,Rgb<28,18,71>>>,Black>>>>(), “0”},
{ “Magenta;common”, “tracks/JFO5.wav”,
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,Rgb<180,30,140>>,Pulsing<RotateColorsX<Variation,Rgb<64,11,49>>,RotateColorsX<Variation,Rgb<180,30,140>>,800>,RotateColorsX<Variation,Rgb<180,30,140>>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Rgb<180,30,140>>,RotateColorsX<Variation,Rgb<113,19,88>>>,TrDelay<30000>,RotateColorsX<Variation,Rgb<180,30,140>>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,Rgb<180,30,140>>,Pulsing<RotateColorsX<Variation,Rgb<64,11,49>>,RotateColorsX<Variation,Rgb<180,30,140>>,800>,RotateColorsX<Variation,Rgb<180,30,140>>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Rgb<180,30,140>>,RotateColorsX<Variation,Rgb<113,19,88>>>,TrDelay<30000>,RotateColorsX<Variation,Rgb<180,30,140>>,TrFade<800>>,EFFECT_FORCE>,InOutTrL<TrInstant,TrFade<300>,Mix<IsLessThan<SlowNoise<Int<3000>>,Int<10000>>,RandomFlicker<RotateColorsX<Variation,Rgb<180,30,140>>,RotateColorsX<Variation,Rgb<64,11,49>>>,Black>>>>(), “0”},
{ “Orange;common”, “tracks/JFO6.wav”,
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,DarkOrange>,Pulsing<RotateColorsX<Variation,Rgb<90,24,0>>,RotateColorsX<Variation,DarkOrange>,800>,RotateColorsX<Variation,DarkOrange>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<160,43,0>>>,TrDelay<30000>,RotateColorsX<Variation,DarkOrange>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Blue,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,DarkOrange>,Pulsing<RotateColorsX<Variation,Rgb<90,24,0>>,RotateColorsX<Variation,DarkOrange>,800>,RotateColorsX<Variation,DarkOrange>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<160,43,0>>>,TrDelay<30000>,RotateColorsX<Variation,DarkOrange>,TrFade<800>>,EFFECT_FORCE>,InOutTrL<TrInstant,TrFade<300>,Mix<IsLessThan<SlowNoise<Int<3000>>,Int<10000>>,RandomFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<90,24,0>>>,Black>>>>(), “0”},
{ “Purple;common”, “tracks/JFO7.wav”,
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,Rgb<110,15,200>>,Pulsing<RotateColorsX<Variation,Rgb<39,5,71>>,RotateColorsX<Variation,Rgb<110,15,200>>,800>,RotateColorsX<Variation,Rgb<110,15,200>>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Rgb<110,15,200>>,RotateColorsX<Variation,Rgb<69,9,125>>>,TrDelay<30000>,RotateColorsX<Variation,Rgb<110,15,200>>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,Rgb<110,15,200>>,Pulsing<RotateColorsX<Variation,Rgb<39,5,71>>,RotateColorsX<Variation,Rgb<110,15,200>>,800>,RotateColorsX<Variation,Rgb<110,15,200>>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Rgb<110,15,200>>,RotateColorsX<Variation,Rgb<69,9,125>>>,TrDelay<30000>,RotateColorsX<Variation,Rgb<110,15,200>>,TrFade<800>>,EFFECT_FORCE>,InOutTrL<TrInstant,TrFade<300>,Mix<IsLessThan<SlowNoise<Int<3000>>,Int<10000>>,RandomFlicker<RotateColorsX<Variation,Rgb<110,15,200>>,RotateColorsX<Variation,Rgb<39,5,71>>>,Black>>>>(), “0”},
{ “Red (Bonus);common”, “tracks/JFO8.wav”,
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,Red>,Pulsing<RotateColorsX<Variation,Rgb<90,0,0>>,RotateColorsX<Variation,Red>,800>,RotateColorsX<Variation,Red>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<160,0,0>>>,TrDelay<30000>,RotateColorsX<Variation,Red>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Blue,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,Red>,Pulsing<RotateColorsX<Variation,Rgb<90,0,0>>,RotateColorsX<Variation,Red>,800>,RotateColorsX<Variation,Red>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<160,0,0>>>,TrDelay<30000>,RotateColorsX<Variation,Red>,TrFade<800>>,EFFECT_FORCE>,InOutTrL<TrInstant,TrFade<300>,Mix<IsLessThan<SlowNoise<Int<3000>>,Int<10000>>,RandomFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<90,0,0>>>,Black>>>>(), “0”},
{ “Yellow;common”, “tracks/JFO9.wav”,
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,Rgb<180,180,0>>,Pulsing<RotateColorsX<Variation,Rgb<64,64,0>>,RotateColorsX<Variation,Rgb<180,180,0>>,800>,RotateColorsX<Variation,Rgb<180,180,0>>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Rgb<180,180,0>>,RotateColorsX<Variation,Rgb<113,113,0>>>,TrDelay<30000>,RotateColorsX<Variation,Rgb<180,180,0>>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,Rgb<180,180,0>>,Pulsing<RotateColorsX<Variation,Rgb<64,64,0>>,RotateColorsX<Variation,Rgb<180,180,0>>,800>,RotateColorsX<Variation,Rgb<180,180,0>>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Rgb<180,180,0>>,RotateColorsX<Variation,Rgb<113,113,0>>>,TrDelay<30000>,RotateColorsX<Variation,Rgb<180,180,0>>,TrFade<800>>,EFFECT_FORCE>,InOutTrL<TrInstant,TrFade<300>,Mix<IsLessThan<SlowNoise<Int<3000>>,Int<10000>>,RandomFlicker<RotateColorsX<Variation,Rgb<180,180,0>>,RotateColorsX<Variation,Rgb<64,64,0>>>,Black>>>>(), “0”},
{ “Batt00;common”, “tracks/JF10.wav”,
&style_charging,
&style_charging, “Battery\nLevel”}
{ 0, WS281XBladePtr<128, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
WS281XBladePtr<128, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4, bladePowerPin5> >(),
CONFIGARRAY(presets) },
this should be 144
this should be SAVE_STATE
Get rid of this define, it makes lockup only trigger by holding the button, not clashing
This appears twice
I corrected these issues. Many thanks! Unfortunately, none of them solved the ceiling drag orientation issue, though.
Then get rid of this and test.
Removed and tested. It functions the same as before. Melt on wall and Drag on floor elicit a clash lockup effect at roughly the blade’s midpoint. Dragging on ceiling seems to make the dragging sound, but no visual drag tip or clash effect.
Then you may not be uploading the config you think you are.
Introduce a typo and see if you get an error.
In your first preset delete the “S” in “StylePtr”, save and try to upload. If it doesn’t generate an error then you’re uploading a different config than you’re editing.
If it does generate an error than you may not actually be uploading correctly. Copy the message in Arduino after you try to upload.
will do. thanks! it did just dawn on me that melt works by stabbing a wall OR the ceiling, so it may not be that my drag was oriented wrong. it may just be that melt is working properly and only the drag isn’t working.
i will run your test and report back, but thought i should mention that.
Here is the upload error. I can send the entire error if you like.
Compilation error: ‘tylePtr’ was not declared in this scope; did you mean ‘StylePtr’?
given my previous comment, is it possible that it’s just an issue with the number of LEDs i have assigned in the footer? i’m not sure which config was loaded on my 89saber out of the box and there were several configs on the SD Card it came with, all with different LED numbers, so i went with the 128 because its a 32" blade. maybe the drag is actually working, but the light up effect isn’t displaying because it’s occurring on LEDs it thinks are there but aren’t?
Possibly, try lowering the number of pixels or you can use LengthFinder.
That LengthFinder is super cool! Totally did the trick. There are only 110 diodes in my blade! Everything works as intended and the melt is way more bad ass than it looked before. I am really, really sorry to wild goose chase everyone and THANK YOU as always for your assistance. Time to duel!!
No worries, glad you got it sorted.
