so i’m having a similar issue but i’m using a neopixal crystal chamber. red works perfectly, but blue does not light, and green hardly lights up, even flickers… so idk
Probably low voltage.
Red doesn’t need as much voltage as the other colors.
(I moved this to a new thread, because I don’t think it’s related to the one you posted in.)
thank you and sorry for that. i have been able to get the green and the red to work on pixel chamber… only one not working now is blue.
in order to get the red and green to work I had to remove the resistor for the pixel chamber. the pixel has a 75 ohm already on it… everything works except the blue now… i been doing this all day trying to trouble shoot, look for posts and videos…
Did you put the resistor on the data line, or one of the other lines??
What does your config look like?
Post some pictures of your wiring?
i did put the 470 ohm on the data line… no lights came on with that resistor on, once i took it off, then the red and green work.
heres my config
// ProffieOS7 Config File
#define NUM_BLADES 2
#define VOLUME 2500
#define CLASH_THRESHOLD_G 3
#define SAVE_VOLUME
#define SAVE_COLOR_CHANGE
#define SAVE_PRESET
#define FETT263_THRUST_ON
{ "Reaper;common", "Reaper/tracks/Reap.wav",
/* copyright Fett263 Simple (Primary Blade) OS6 Style
https://fett263.com/fett263-proffieOS6-style-library.html#Simple
OS6.7 v4.021
Base Style: RandomFlicker (Single Color (50%))
Base Color: Rgb<255,0,0> (0)
Melt Effect: Intensity Melt
Blast Effect: Blast Fade (Random)
Clash Effect: Real Clash V3
StylePtr<Layers<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,TransitionEffectL<TrConcat<TrInstant,AlphaMixL<Bump<EffectPosition<EFFECT_BLAST>,Scale<EffectPosition<EFFECT_BLAST>,Int<9000>,Int<12000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,0>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,0>>>>,TrFade<300>>,EFFECT_BLAST>,AlphaL<TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<115,15,240>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<115,15,240>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,Rgb<115,15,240>>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<115,15,240>>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<115,15,240>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<115,15,240>>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,Scale<ClashImpactF<>,Int<24000>,Int<32768>>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,31310>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,31310>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,31310>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,31310>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,31310>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<200>>,TrWipeInX<RetractionTime<0>>,Black>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>>>(),
/* copyright Fett263 Simple (Crystal Chamber) OS7 Style
https://fett263.com/fett263-proffieOS7-style-library.html#Simple
OS7.12 v1.017-p
Off Behavior: Unstable Flicker (Single Color) [Color: Match ON Color]
Base Color: BaseColorArg (0)
StylePtr<Layers<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,InOutTrL<TrInstant,TrInstant,RandomPerLEDFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<10560>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>>>>(),
"Reaper"
{ "Prequals;common", "Prequals/tracks/Preq.wav",
OS6.7 v4.021
Base Color: Rgb<0,0,255> (0)
StylePtr<Layers<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,TransitionEffectL<TrConcat<TrInstant,AlphaMixL<Bump<EffectPosition<EFFECT_BLAST>,Scale<EffectPosition<EFFECT_BLAST>,Int<9000>,Int<12000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,0>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,0>>>>,TrFade<300>>,EFFECT_BLAST>,AlphaL<TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<115,15,240>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<115,15,240>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,Rgb<115,15,240>>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<115,15,240>>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<115,15,240>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<115,15,240>>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,Scale<ClashImpactF<>,Int<24000>,Int<32768>>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,31310>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,31310>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,31310>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,31310>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,31310>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<200>>,TrWipeInX<RetractionTime<0>>,Black>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>>>(),
OS7.12 v1.017-p
StylePtr<Layers<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,InOutTrL<TrInstant,TrInstant,RandomPerLEDFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<10560>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>>>>(),
"Prequals"
{ "GhostS;common", "GhostS/tracks/GhostS.wav",
/* copyright Fett263 UnstableBlades (Primary Blade) OS7 Style
https://fett263.com/fett263-proffieOS7-style-library.html#UnstableBlades
OS7.12 v1.017-p
Base Style: Unstable Anger
Preon Effect: Erratic (Apocalypse Version) [Color: EmitterColorArg]
StylePtr<Layers<Layers<Stripes<2000,-2500,RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>>,Black>,BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>>,200>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>>>>,TransitionLoopL<TrJoin<TrDelayX<Scale<SlowNoise<Int<1500>>,Int<200>,Int<1200>>>,TrWaveX<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>,BrownNoiseFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>>,Black,300>>,Int<400>,Int<100>,Int<200>,Int<0>>>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrExtendX<Mult<WavLen<EFFECT_PREON>,Int<16384>>,TrInstant>,Layers<AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RgbArg<EMITTER_COLOR_ARG,Rgb<225,229,11>>,100>,RandomPerLEDFlicker<RgbArg<EMITTER_COLOR_ARG,Rgb<225,229,11>>,Mix<Int<8192>,Black,RgbArg<EMITTER_COLOR_ARG,Rgb<225,229,11>>>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RgbArg<EMITTER_COLOR_ARG,Rgb<225,229,11>>,RotateColorsX<Int<4000>,RgbArg<EMITTER_COLOR_ARG,Rgb<225,229,11>>>>,RotateColorsX<Int<1200>,RgbArg<EMITTER_COLOR_ARG,Rgb<225,229,11>>>,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-1000>,Int<25000>>,Int<-4000>>>,AlphaL<HumpFlickerL<AlphaL<White,Trigger<EFFECT_PREON,Mult<WavLen<EFFECT_PREON>,Int<8176>>,WavLen<EFFECT_PREON>,Mult<WavLen<EFFECT_PREON>,Int<16384>>>>,40>,SmoothStep<IntArg<PREON_SIZE_ARG,3882>,Int<-4000>>>>,TrLoopN<10,TrWaveX<RgbArg<EMITTER_COLOR_ARG,Rgb<225,229,11>>,Int<200>,Int<200>,Scale<Trigger<EFFECT_PREON,Int<0>,Mult<WavLen<EFFECT_PREON>,Int<24576>>,Mult<WavLen<EFFECT_PREON>,Int<8192>>>,Int<400>,Int<100>>,Int<0>>>>,EFFECT_PREON>>>(),
/* copyright Fett263 UnstableBlades (Crystal Chamber) OS7 Style
OS7.12 v1.017-p
Off Behavior: Solid Color [Color: OffColorArg]
StylePtr<Layers<Layers<Stripes<2000,-2500,RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>>,Black>,BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>>,200>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>>>>,TransitionLoopL<TrJoin<TrDelayX<Scale<SlowNoise<Int<1500>>,Int<200>,Int<1200>>>,TrWaveX<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>,BrownNoiseFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>>,Black,300>>,Int<400>,Int<100>,Int<200>,Int<0>>>>>,InOutTrL<TrInstant,TrInstant,Layers<Stripes<2000,-2500,RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>>,Black>,BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>>,200>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>>>>,TransitionLoopL<TrJoin<TrDelayX<Scale<SlowNoise<Int<1500>>,Int<200>,Int<1200>>>,TrWaveX<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>,BrownNoiseFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<187,0,255>>>,Black,300>>,Int<400>,Int<100>,Int<200>,Int<0>>>>>>>>(),
"preset2"
{ "BrokenOne;common", "BrokenOne/tracks/BrokenOne.wav",
OS7.12 v1.017-p
StylePtr<Layers<Layers<Stripes<2000,-2500,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Black>,BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,200>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>>,TransitionLoopL<TrJoin<TrDelayX<Scale<SlowNoise<Int<1500>>,Int<200>,Int<1200>>>,TrWaveX<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,BrownNoiseFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Black,300>>,Int<400>,Int<100>,Int<200>,Int<0>>>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrExtendX<Mult<WavLen<EFFECT_PREON>,Int<16384>>,TrInstant>,Layers<AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RgbArg<EMITTER_COLOR_ARG,Rgb<225,229,11>>,100>,RandomPerLEDFlicker<RgbArg<EMITTER_COLOR_ARG,Rgb<225,229,11>>,Mix<Int<8192>,Black,RgbArg<EMITTER_COLOR_ARG,Rgb<225,229,11>>>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RgbArg<EMITTER_COLOR_ARG,Rgb<225,229,11>>,RotateColorsX<Int<4000>,RgbArg<EMITTER_COLOR_ARG,Rgb<225,229,11>>>>,RotateColorsX<Int<1200>,RgbArg<EMITTER_COLOR_ARG,Rgb<225,229,11>>>,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-1000>,Int<25000>>,Int<-4000>>>,AlphaL<HumpFlickerL<AlphaL<White,Trigger<EFFECT_PREON,Mult<WavLen<EFFECT_PREON>,Int<8176>>,WavLen<EFFECT_PREON>,Mult<WavLen<EFFECT_PREON>,Int<16384>>>>,40>,SmoothStep<IntArg<PREON_SIZE_ARG,3882>,Int<-4000>>>>,TrLoopN<10,TrWaveX<RgbArg<EMITTER_COLOR_ARG,Rgb<225,229,11>>,Int<200>,Int<200>,Scale<Trigger<EFFECT_PREON,Int<0>,Mult<WavLen<EFFECT_PREON>,Int<24576>>,Mult<WavLen<EFFECT_PREON>,Int<8192>>>,Int<400>,Int<100>>,Int<0>>>>,EFFECT_PREON>>>(),
OS7.12 v1.017-p
StylePtr<Layers<Layers<Stripes<2000,-2500,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Black>,BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,200>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>>,TransitionLoopL<TrJoin<TrDelayX<Scale<SlowNoise<Int<1500>>,Int<200>,Int<1200>>>,TrWaveX<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,BrownNoiseFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Black,300>>,Int<400>,Int<100>,Int<200>,Int<0>>>>>,InOutTrL<TrInstant,TrInstant,Layers<Stripes<2000,-2500,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Black>,BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,200>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>>,TransitionLoopL<TrJoin<TrDelayX<Scale<SlowNoise<Int<1500>>,Int<200>,Int<1200>>>,TrWaveX<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,BrownNoiseFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Black,300>>,Int<400>,Int<100>,Int<200>,Int<0>>>>>>>>(),
"preset3"
{ "Afterlife;common", "Afterlife/tracks/Afterlife.wav",
/* copyright Fett263 Simple (Primary Blade) OS7 Style
OS7.12 v1.017-p
Base Style: RandomFlicker (Single Color (25%))
StylePtr<Layers<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>,Mix<Int<8192>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrExtendX<Mult<WavLen<EFFECT_PREON>,Int<16384>>,TrInstant>,Layers<AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RgbArg<EMITTER_COLOR_ARG,Rgb<225,229,11>>,100>,RandomPerLEDFlicker<RgbArg<EMITTER_COLOR_ARG,Rgb<225,229,11>>,Mix<Int<8192>,Black,RgbArg<EMITTER_COLOR_ARG,Rgb<225,229,11>>>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RgbArg<EMITTER_COLOR_ARG,Rgb<225,229,11>>,RotateColorsX<Int<4000>,RgbArg<EMITTER_COLOR_ARG,Rgb<225,229,11>>>>,RotateColorsX<Int<1200>,RgbArg<EMITTER_COLOR_ARG,Rgb<225,229,11>>>,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-1000>,Int<25000>>,Int<-4000>>>,AlphaL<HumpFlickerL<AlphaL<White,Trigger<EFFECT_PREON,Mult<WavLen<EFFECT_PREON>,Int<8176>>,WavLen<EFFECT_PREON>,Mult<WavLen<EFFECT_PREON>,Int<16384>>>>,40>,SmoothStep<IntArg<PREON_SIZE_ARG,3882>,Int<-4000>>>>,TrLoopN<10,TrWaveX<RgbArg<EMITTER_COLOR_ARG,Rgb<225,229,11>>,Int<200>,Int<200>,Scale<Trigger<EFFECT_PREON,Int<0>,Mult<WavLen<EFFECT_PREON>,Int<24576>>,Mult<WavLen<EFFECT_PREON>,Int<8192>>>,Int<400>,Int<100>>,Int<0>>>>,EFFECT_PREON>>>(),
OS7.12 v1.017-p
StylePtr<Layers<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>,Mix<Int<8192>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>>>,InOutTrL<TrInstant,TrInstant,RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>,Mix<Int<8192>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>>>>>>(),
"preset4"
{ "Hero;common", "Hero/tracks/Hero.wav",
OS7.12 v1.017-p
Base Style: Static
StylePtr<Layers<RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,0>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<0,0,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<0,0,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<0,0,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<0,0,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
OS7.12 v1.017-p
Base Style: Static
StylePtr<Layers<RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,InOutTrL<TrInstant,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>>(),
"preset5"
WS281XBladePtr<1, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin1> >()
, CONFIGARRAY(presets) },
/* Generated with Fett263 Config Helper v3.05 */
as far as pics of the wiring, its not in the saber yet… its all over the place and looks terrible, but its just like the diagram, minus the resistor on the data line.
My guess is that your led is stealing power from the data line, but not enough to work properly. That means that either the + or the - line are not hooked up properly.
ill give another look
i’m going to buy another pixel just to make sure it’s not the pixel.
