One Button Config
Hello, What does the top and bottom config look like for a one button setup? I just changed the top to this, “#define NUM_BUTTONS 1”. The bottom to this, “#ifdef CONFIG_BUTTONS
#endif.”
The saber will not react to button push of any kind.
did you wire it to button1 or button2 pin?
if you wired it to button 2 then change powerButtonPin to auxPin
Let me check that out, I did not think of that.
The configuration generator can generate the typical configuration for 1 and 2 button setups:
https://fredrik.hubbe.net/lightsaber/v5/
Thanks DudeFromOz, it always the simple things I miss. Fixed. This is my first one button setup.
Thankyou profezzorn, I should have checked that out first. Working ok now. I will get accustomed to one button gestures.
thats good it was an easy fix. ive had to double check a few times switching back and forward between v2 and v3 boards as the button 1 and 2 pins are reversed.
are you using fett263s prop? Fett263 ProffieOS6 Prop File (Buttons and Controls) has the run through for all the controls
Yes, I will have to review them for sure, cannot even change fonts. just getting going on one button.
