Just finished editing my config to have an off behavior for the crystal chamber on my lightsaber but I went to test it and there is no effect happening wondering if there is something I did wrong in the config.
// ProffieOS7 Config File
#define NUM_BLADES 4
const unsigned int maxLedsPerStrip = 155;
#define VOLUME 2550
#define CLASH_THRESHOLD_G 4.5
#define AUDIO_CLASH_SUPPRESSION_LEVEL 5
#define ENABLE_SSD1306
#define OLED_FLIP_180
#define KILL_OLD_PLAYERS
#define FILTER_ORDER 8
#define BLADE_DETECT_PIN 6
#define SAVE_PRESET
#define ENABLE_SERIAL
#define FETT263_ENABLE_SPIN_MODE
#define FETT263_BM_CLASH_DETECT 8
#define FETT263_FORCE_PUSH
#define FETT263_TWIST_ON
//#define KEEP_SAVEFILES_WHEN_PROGRAMMING
#define FETT263_DISABLE_MULTI_BLAST
#define FETT263_DISABLE_MULTI_BLAST_TOGGLE
#include "../props/saber_sabertrio_buttons.h"
// #include "../props/saber_fett263_buttons.h"
Preset blade[] = {
{"1-AGGRESSION;common","",
/* copyright Fett263 UnstableBlades (Primary Blade) OS7 Style
https://www.fett263.com/fett263-proffieOS7-style-library.html#UnstableBlades
OS7.15 v3.213p
Base Style: Unstable Anger
Base Color: BaseColorArg (0)
Preon Effect: Faulty Ignition [Color: PreonColorArg]
Ignition Effect: Glitch On [Color: IgnitionColorArg]
PowerUp Effect: Unstable Power Up Forward [Color: IgnitionColorArg]
Retraction Effect: Glitch Off [Color: RetractionColorArg]
CoolDown Effect: Unstable Cool Down Reverse [Color: RetractionColorArg]
Lockup Effect:
0: mainLockMulti0Shape - Begin: Real Clash - Style: Intensity Unstable Ripple - End: Full Blade Absorb
[Color: LockupColorArg]
Lightning Block Effect:
[Color: LBColorArg]
Drag Effect:
[Color: DragColorArg]
Melt Effect:
[Color: StabColorArg]
Blast Effect: Blast Fade (Random) [Color: BlastColorArg]
Emitter Effect: Unstable Flare with Random Pulse [Color: EmitterColorArg]
StylePtr<Layers<Layers<Stripes<2000,-2500,RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>>,Black>,BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>>,200>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>>>>,TransitionLoopL<TrJoin<TrDelayX<Scale<SlowNoise<Int<1500>>,Int<200>,Int<1200>>>,TrWaveX<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>,BrownNoiseFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>>,Black,300>>,Int<400>,Int<100>,Int<200>,Int<0>>>>>,TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<1000>>,Int<300>,Int<3000>>>,AlphaL<RgbArg<EMITTER_COLOR_ARG,Rgb<255,255,0>>,Int<0>>,TrSparkX<RgbArg<EMITTER_COLOR_ARG,Rgb<255,255,0>>,Scale<NoisySoundLevel,Int<200>,Int<600>>,Int<250>,Int<0>>>>,AlphaL<RandomPerLEDFlickerL<RgbArg<EMITTER_COLOR_ARG,Rgb<255,255,0>>>,SmoothStep<Scale<NoisySoundLevel,IntArg<EMITTER_SIZE_ARG,2000>,Sum<IntArg<EMITTER_SIZE_ARG,2000>,Int<6000>>>,Int<-6000>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,97,0>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,97,0>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,97,0>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,97,0>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,97,0>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,97,0>>>>>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,Stripes<3000,3500,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,97,0>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,97,0>>>,Black>,BrownNoiseFlicker<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,97,0>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,97,0>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,97,0>>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,97,0>>>>>,TrFade<800>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrInstant,AlphaMixL<Bump<EffectPosition<EFFECT_BLAST>,Scale<EffectPosition<EFFECT_BLAST>,Int<9000>,Int<12000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<0,0,255>>>>,TrFade<300>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<180,130,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<180,130,0>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<2000,-3200,RandomPerLEDFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<180,130,0>>,Mix<Int<14000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<180,130,0>>>>,Mix<Int<18000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<180,130,0>>>,Mix<Int<8000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<180,130,0>>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1600,-2600,RandomPerLEDFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<180,130,0>>,Mix<Int<14000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<180,130,0>>>>,Mix<Int<18000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<180,130,0>>>,Mix<Int<8000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<180,130,0>>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<180,130,0>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<180,130,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<180,130,0>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<115,15,240>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<115,15,240>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<115,15,240>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<115,15,240>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrConcat<TrJoin<TrDelayX<Mult<IgnitionTime<0>,Int<16384>>>,TrWipeX<Mult<IgnitionTime<0>,Int<16384>>>>,Mix<SmoothStep<NoisySoundLevel,Int<-1>>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,97,0>>>,TrWipeX<Mult<IgnitionTime<0>,Int<16384>>>>,TrConcat<TrJoin<TrDelayX<Mult<RetractionTime<0>,Int<16384>>>,TrWipeInX<Mult<RetractionTime<0>,Int<16384>>>>,Mix<SmoothStep<NoisySoundLevel,Int<-1>>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>>,TrWipeInX<Mult<RetractionTime<0>,Int<16384>>>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Mult<Int<16384>,WavLen<EFFECT_PREON>>,Mult<Int<10922>,WavLen<EFFECT_PREON>>,Mult<Int<5462>,WavLen<EFFECT_PREON>>>,BrownNoiseFlicker<Black,RgbArg<PREON_COLOR_ARG,Rgb<255,68,0>>,100>,RandomPerLEDFlicker<RgbArg<PREON_COLOR_ARG,Rgb<255,68,0>>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RgbArg<PREON_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<4000>,RgbArg<PREON_COLOR_ARG,Rgb<255,68,0>>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,EFFECT_PREON>>>(),
/* copyright Fett263 UnstableBlades (Quillion / Secondary Blade) OS7 Style
OS7.15 v3.213p
0: sideDragMulti0Shape - Begin: Wipe In - Style: Intensity Sparking Drag - End: Wipe Out
Melt Effect:
0: sideMeltMulti0Shape - Begin: Wipe In - Style: Intensity Melt - End: Wipe Out
StylePtr<Layers<Layers<Stripes<2000,-2500,RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>>,Black>,BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>>,200>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>>>>,TransitionLoopL<TrJoin<TrDelayX<Scale<SlowNoise<Int<1500>>,Int<200>,Int<1200>>>,TrWaveX<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>,BrownNoiseFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>>,Black,300>>,Int<400>,Int<100>,Int<200>,Int<0>>>>>,TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<1000>>,Int<300>,Int<3000>>>,AlphaL<RgbArg<EMITTER_COLOR_ARG,Rgb<255,255,0>>,Int<0>>,TrSparkX<RgbArg<EMITTER_COLOR_ARG,Rgb<255,255,0>>,Scale<NoisySoundLevel,Int<200>,Int<600>>,Int<250>,Int<0>>>>,AlphaL<RandomPerLEDFlickerL<RgbArg<EMITTER_COLOR_ARG,Rgb<255,255,0>>>,SmoothStep<Scale<NoisySoundLevel,IntArg<EMITTER_SIZE_ARG,2000>,Sum<IntArg<EMITTER_SIZE_ARG,2000>,Int<6000>>>,Int<-6000>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,97,0>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,97,0>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,97,0>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,97,0>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,97,0>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,97,0>>>>>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,Stripes<3000,3500,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,97,0>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,97,0>>>,Black>,BrownNoiseFlicker<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,97,0>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,97,0>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,97,0>>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,97,0>>>>>,TrFade<800>>,EFFECT_RETRACTION>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrConcat<TrJoin<TrDelayX<Mult<IgnitionTime<0>,Int<16384>>>,TrWipeX<Mult<IgnitionTime<0>,Int<16384>>>>,Mix<SmoothStep<NoisySoundLevel,Int<-1>>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,97,0>>>,TrWipeX<Mult<IgnitionTime<0>,Int<16384>>>>,TrConcat<TrJoin<TrDelayX<Mult<RetractionTime<0>,Int<16384>>>,TrWipeInX<Mult<RetractionTime<0>,Int<16384>>>>,Mix<SmoothStep<NoisySoundLevel,Int<-1>>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>>,TrWipeInX<Mult<RetractionTime<0>,Int<16384>>>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Mult<Int<16384>,WavLen<EFFECT_PREON>>,Mult<Int<10922>,WavLen<EFFECT_PREON>>,Mult<Int<5462>,WavLen<EFFECT_PREON>>>,BrownNoiseFlicker<Black,RgbArg<PREON_COLOR_ARG,Rgb<255,68,0>>,100>,RandomPerLEDFlicker<RgbArg<PREON_COLOR_ARG,Rgb<255,68,0>>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RgbArg<PREON_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<4000>,RgbArg<PREON_COLOR_ARG,Rgb<255,68,0>>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,EFFECT_PREON>>>(),
OS7.15 v3.213p
Melt Effect:
/* copyright Fett263 UnstableBlades (Crystal Chamber) OS7 Style
OS7.15 v3.213p
Off Behavior: Slow Run Forward [Color: OffColorArg]
0: crystalDragMulti0Shape - Begin: Wipe In - Style: Intensity Sparking Drag - End: Wipe Out
Melt Effect:
0: crystalMeltMulti0Shape - Begin: Wipe In - Style: Intensity Melt - End: Wipe Out
Rain Effect: Rain Spark
StylePtr<Layers<Layers<Stripes<2000,-2500,RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>>,Black>,BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>>,200>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>>>>,TransitionLoopL<TrJoin<TrDelayX<Scale<SlowNoise<Int<1500>>,Int<200>,Int<1200>>>,TrWaveX<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>,BrownNoiseFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>>,Black,300>>,Int<400>,Int<100>,Int<200>,Int<0>>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,97,0>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,97,0>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,97,0>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,97,0>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,97,0>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,97,0>>>>>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,Stripes<3000,3500,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,97,0>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,97,0>>>,Black>,BrownNoiseFlicker<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,97,0>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,97,0>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,97,0>>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,97,0>>>>>,TrFade<800>>,EFFECT_RETRACTION>,SparkleL<RgbArg<CLASH_COLOR_ARG,Rgb<180,130,0>>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrConcat<TrJoin<TrDelayX<Mult<IgnitionTime<0>,Int<16384>>>,TrWipeX<Mult<IgnitionTime<0>,Int<16384>>>>,Mix<SmoothStep<NoisySoundLevel,Int<-1>>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,97,0>>>,TrWipeX<Mult<IgnitionTime<0>,Int<16384>>>>,TrConcat<TrJoin<TrDelayX<Mult<RetractionTime<0>,Int<16384>>>,TrWipeInX<Mult<RetractionTime<0>,Int<16384>>>>,Mix<SmoothStep<NoisySoundLevel,Int<-1>>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,25,0>>>,TrWipeInX<Mult<RetractionTime<0>,Int<16384>>>>,TransitionLoop<Black,TrConcat<TrWipe<1000>,RgbArg<OFF_COLOR_ARG,Rgb<255,25,0>>,TrWipe<1000>>>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Mult<Int<16384>,WavLen<EFFECT_PREON>>,Mult<Int<10922>,WavLen<EFFECT_PREON>>,Mult<Int<5462>,WavLen<EFFECT_PREON>>>,BrownNoiseFlicker<Black,RgbArg<PREON_COLOR_ARG,Rgb<255,68,0>>,100>,RandomPerLEDFlicker<RgbArg<PREON_COLOR_ARG,Rgb<255,68,0>>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RgbArg<PREON_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<4000>,RgbArg<PREON_COLOR_ARG,Rgb<255,68,0>>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,EFFECT_PREON>>>(),
"aggression"
{"2-CYAN;common","",
/* copyright Fett263 JediSurvivor (Primary Blade) OS7 Style
https://www.fett263.com/fett263-proffieOS7-style-library.html#JediSurvivor
OS7.15 v3.213p
Base Style: Cal Kestis Survivor Cyan
PowerUp Effect: Power Burst Forward [Color: IgnitionColorArg]
Retraction Effect: SparkTip Retraction [Color: RetractionColorArg]
CoolDown Effect: Power Burst Reverse [Color: RetractionColorArg]
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
StylePtr<Layers<StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<10000>,Int<5000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<-2000>,Int<-3000>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>>,Pulsing<RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>,Mix<Int<8000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>>,1400>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,Stripes<5000,-2500,RgbArg<IGNITION_COLOR_ARG,Rgb<55,255,169>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<55,255,169>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<55,255,169>>>>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,Stripes<5000,2500,RgbArg<RETRACTION_COLOR_ARG,Rgb<55,255,169>>,Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<55,255,169>>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<55,255,169>>>>,TrFade<800>>,EFFECT_RETRACTION>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,0,0>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<108,255,6>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<108,255,6>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<115,15,240>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<115,15,240>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<115,15,240>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<115,15,240>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<55,255,169>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<55,255,169>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<55,255,169>>,BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInSparkTipX<RotateColorsX<Int<4096>,RgbArg<RETRACTION_COLOR_ARG,Rgb<55,255,169>>>,BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
/* copyright Fett263 JediSurvivor (Quillion / Secondary Blade) OS7 Style
OS7.15 v3.213p
Melt Effect:
StylePtr<Layers<StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<10000>,Int<5000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<-2000>,Int<-3000>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>>,Pulsing<RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>,Mix<Int<8000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>>,1400>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,Stripes<5000,-2500,RgbArg<IGNITION_COLOR_ARG,Rgb<55,255,169>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<55,255,169>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<55,255,169>>>>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,Stripes<5000,2500,RgbArg<RETRACTION_COLOR_ARG,Rgb<55,255,169>>,Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<55,255,169>>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<55,255,169>>>>,TrFade<800>>,EFFECT_RETRACTION>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<55,255,169>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<55,255,169>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<55,255,169>>,BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<55,255,169>>,BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
OS7.15 v3.213p
Melt Effect:
/* copyright Fett263 JediSurvivor (Crystal Chamber) OS7 Style
OS7.15 v3.213p
Melt Effect:
StylePtr<Layers<StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<10000>,Int<5000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<-2000>,Int<-3000>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>>,Pulsing<RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>,Mix<Int<8000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>>,1400>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,Stripes<5000,-2500,RgbArg<IGNITION_COLOR_ARG,Rgb<55,255,169>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<55,255,169>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<55,255,169>>>>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,Stripes<5000,2500,RgbArg<RETRACTION_COLOR_ARG,Rgb<55,255,169>>,Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<55,255,169>>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<55,255,169>>>>,TrFade<800>>,EFFECT_RETRACTION>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<55,255,169>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<55,255,169>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<55,255,169>>,BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<55,255,169>>,BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,TransitionLoop<Black,TrConcat<TrWipe<1000>,RgbArg<OFF_COLOR_ARG,Rgb<0,255,255>>,TrWipe<1000>>>>>>(),
"cyan"
{"3-GRAFLEX;common","",
OS7.15 v3.213p
Base Style: Audio Rotoscope - Single Color (Original Trilogy)
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
StylePtr<Layers<AudioFlicker<Stripes<10000,-2600,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,0,0>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,0>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<115,15,240>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<115,15,240>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<115,15,240>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<115,15,240>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<0,135,255>>,BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInSparkTipX<RotateColorsX<Int<4096>,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,255,255>>>,BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
/* copyright Fett263 Rotoscope (Quillion / Secondary Blade) OS7 Style
OS7.15 v3.213p
Melt Effect:
StylePtr<Layers<AudioFlicker<Stripes<10000,-2600,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<0,135,255>>,BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<0,255,255>>,BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
OS7.15 v3.213p
Melt Effect:
/* copyright Fett263 Rotoscope (Crystal Chamber) OS7 Style
OS7.15 v3.213p
Off Behavior: Cylon (Large) [Color: OffColorArg]
Melt Effect:
StylePtr<Layers<AudioFlicker<Stripes<10000,-2600,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<0,135,255>>,BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<0,255,255>>,BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Mix<LinearSectionF<Sin<Int<20>>,Int<8000>>,Black,RgbArg<OFF_COLOR_ARG,Rgb<0,0,255>>>>>>(),
"graflex"
{"4-UNLIGHTSTABLE;common","",
OS7.15 v3.213p
Wave (Stripe) Blade Stripe Width: 10000, Speed Option: Fixed, Speed: -300
Default: Unstable Unleashed [BaseColorArg]
1: Unstable Rage [AltColorArg]
Preon Effect: Erratic (Apocalypse Version) [Color: PreonColorArg]
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
StylePtr<Layers<StripesX<Int<10000>,Int<-300>,StaticFire<Stripes<2500,-5000,BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Black,20>,Mix<Int<1285>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,BrownNoiseFlicker<Black,Mix<Int<3212>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,White>,70>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,0,5,2,3000,0>,Stripes<3000,-3500,RgbArg<ALT_COLOR_ARG,Rgb<255,0,75>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,75>>>,Black>,BrownNoiseFlicker<RgbArg<ALT_COLOR_ARG,Rgb<255,0,75>>,Mix<Int<3855>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,75>>>,200>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,75>>>,Mix<Int<3855>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,75>>>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,85>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,85>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,85>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,85>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,85>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,85>>>>>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,Stripes<3000,3500,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,255,85>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,255,85>>>,Black>,BrownNoiseFlicker<RgbArg<RETRACTION_COLOR_ARG,Rgb<0,255,85>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,255,85>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,255,85>>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,255,85>>>>>,TrFade<800>>,EFFECT_RETRACTION>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<0,0,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<108,255,6>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<108,255,6>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,0,0>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,0,0>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,0,0>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,0,0>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<108,255,6>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<108,255,6>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,85>>,BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInSparkTipX<RotateColorsX<Int<4096>,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,255,85>>>,BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrExtendX<Mult<WavLen<EFFECT_PREON>,Int<16384>>,TrInstant>,Layers<AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RgbArg<PREON_COLOR_ARG,Rgb<255,0,75>>,100>,RandomPerLEDFlicker<RgbArg<PREON_COLOR_ARG,Rgb<255,0,75>>,Mix<Int<8192>,Black,RgbArg<PREON_COLOR_ARG,Rgb<255,0,75>>>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RgbArg<PREON_COLOR_ARG,Rgb<255,0,75>>,RotateColorsX<Int<4000>,RgbArg<PREON_COLOR_ARG,Rgb<255,0,75>>>>,RotateColorsX<Int<1200>,RgbArg<PREON_COLOR_ARG,Rgb<255,0,75>>>,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-1000>,Int<25000>>,Int<-4000>>>,AlphaL<HumpFlickerL<AlphaL<White,Trigger<EFFECT_PREON,Mult<WavLen<EFFECT_PREON>,Int<8176>>,WavLen<EFFECT_PREON>,Mult<WavLen<EFFECT_PREON>,Int<16384>>>>,40>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>>,TrLoopN<10,TrWaveX<RgbArg<PREON_COLOR_ARG,Rgb<255,0,75>>,Int<200>,Int<200>,Scale<Trigger<EFFECT_PREON,Int<0>,Mult<WavLen<EFFECT_PREON>,Int<24576>>,Mult<WavLen<EFFECT_PREON>,Int<8192>>>,Int<400>,Int<100>>,Int<0>>>>,EFFECT_PREON>>>(),
/* copyright Fett263 CustomBlade (Quillion / Secondary Blade) OS7 Style
OS7.15 v3.213p
Melt Effect:
StylePtr<Layers<StripesX<Int<10000>,Int<-300>,StaticFire<Stripes<2500,-5000,BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Black,20>,Mix<Int<1285>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,BrownNoiseFlicker<Black,Mix<Int<3212>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,White>,70>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,0,5,2,3000,0>,Stripes<3000,-3500,RgbArg<ALT_COLOR_ARG,Rgb<255,0,75>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,75>>>,Black>,BrownNoiseFlicker<RgbArg<ALT_COLOR_ARG,Rgb<255,0,75>>,Mix<Int<3855>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,75>>>,200>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,75>>>,Mix<Int<3855>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,75>>>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,85>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,85>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,85>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,85>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,85>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,85>>>>>,TrFade<800>>,EFFECT_IGNITION>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<108,255,6>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<108,255,6>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,85>>,BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<0,255,85>>,BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrExtendX<Mult<WavLen<EFFECT_PREON>,Int<16384>>,TrInstant>,Layers<AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RgbArg<PREON_COLOR_ARG,Rgb<255,0,75>>,100>,RandomPerLEDFlicker<RgbArg<PREON_COLOR_ARG,Rgb<255,0,75>>,Mix<Int<8192>,Black,RgbArg<PREON_COLOR_ARG,Rgb<255,0,75>>>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RgbArg<PREON_COLOR_ARG,Rgb<255,0,75>>,RotateColorsX<Int<4000>,RgbArg<PREON_COLOR_ARG,Rgb<255,0,75>>>>,RotateColorsX<Int<1200>,RgbArg<PREON_COLOR_ARG,Rgb<255,0,75>>>,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-1000>,Int<25000>>,Int<-4000>>>,AlphaL<HumpFlickerL<AlphaL<White,Trigger<EFFECT_PREON,Mult<WavLen<EFFECT_PREON>,Int<8176>>,WavLen<EFFECT_PREON>,Mult<WavLen<EFFECT_PREON>,Int<16384>>>>,40>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>>,TrLoopN<10,TrWaveX<RgbArg<PREON_COLOR_ARG,Rgb<255,0,75>>,Int<200>,Int<200>,Scale<Trigger<EFFECT_PREON,Int<0>,Mult<WavLen<EFFECT_PREON>,Int<24576>>,Mult<WavLen<EFFECT_PREON>,Int<8192>>>,Int<400>,Int<100>>,Int<0>>>>,EFFECT_PREON>>>(),
OS7.15 v3.213p
Melt Effect:
/* copyright Fett263 CustomBlade (Crystal Chamber) OS7 Style
OS7.15 v3.213p
Off Behavior: Fast Pulse Dim-On [Color: OffColorArg (Color Pulse = Shift: 19276, Speed: 20)
Melt Effect:
StylePtr<Layers<StripesX<Int<10000>,Int<-300>,StaticFire<Stripes<2500,-5000,BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Black,20>,Mix<Int<1285>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,BrownNoiseFlicker<Black,Mix<Int<3212>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,White>,70>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,0,5,2,3000,0>,Stripes<3000,-3500,RgbArg<ALT_COLOR_ARG,Rgb<255,0,75>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,75>>>,Black>,BrownNoiseFlicker<RgbArg<ALT_COLOR_ARG,Rgb<255,0,75>>,Mix<Int<3855>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,75>>>,200>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,75>>>,Mix<Int<3855>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,75>>>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,85>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,85>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,85>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,85>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,85>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,85>>>>>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,Stripes<3000,3500,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,255,85>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,255,85>>>,Black>,BrownNoiseFlicker<RgbArg<RETRACTION_COLOR_ARG,Rgb<0,255,85>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,255,85>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,255,85>>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,255,85>>>>>,TrFade<800>>,EFFECT_RETRACTION>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<108,255,6>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<108,255,6>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,85>>,BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<0,255,85>>,BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Pulsing<Mix<Int<8192>,Black,Pulsing<RgbArg<OFF_COLOR_ARG,Rgb<0,255,0>>,RotateColorsX<Int<19276>,RgbArg<OFF_COLOR_ARG,Rgb<0,255,0>>>,2000>>,Pulsing<RgbArg<OFF_COLOR_ARG,Rgb<0,255,0>>,RotateColorsX<Int<19276>,RgbArg<OFF_COLOR_ARG,Rgb<0,255,0>>>,2000>,2000>>>>(),
"unlightstable"
{"5-TUSKEN;common","",
OS7.15 v3.213p
Base Style: Audio Rotoscope - Single Color (Prequels)
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
StylePtr<Layers<AudioFlicker<Stripes<24000,-1400,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,0,0>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<108,255,6>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<108,255,6>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<108,255,6>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<115,15,240>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<115,15,240>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<115,15,240>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<115,15,240>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<0,135,255>>,BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInSparkTipX<RotateColorsX<Int<4096>,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,255,255>>>,BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
OS7.15 v3.213p
Base Color: BaseColorArg (0)
[Color: DragColorArg]
Melt Effect:
[Color: StabColorArg]
StylePtr<Layers<AudioFlicker<Stripes<24000,-1400,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<0,135,255>>,BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<0,255,255>>,BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
OS7.15 v3.213p
Melt Effect:
OS7.15 v3.213p
Off Behavior: Power Wave Slow [Color: OffColorArg]
Melt Effect:
StylePtr<Layers<AudioFlicker<Stripes<24000,-1400,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<0,135,255>>,BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<0,255,255>>,BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Stripes<16000,-400,RgbArg<OFF_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<8000>,Black,RgbArg<OFF_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<16000>,Black,RgbArg<OFF_COLOR_ARG,Rgb<0,0,255>>>>>>>(),
"tusken"
{ 0,
SubBlade(1, 150, WS281XBladePtr<151, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >()), //Main Blade
SubBlade(0,0, NULL), // Crystal
SubBlade(0, 0, WS281XBladePtr<20, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4,bladePowerPin5, bladePowerPin1> >()), //Switch
SubBlade(1,19, NULL), //Quillons
CONFIGARRAY(blade)
