I’ve seen others do something similar, but I want to make sure I’ve got it right. I want to run just a single positive and negative 22awg wire from the hilt NPXL adapter. The NPXL manual suggests running 2 positive and two negative.
If I go with just one negative and one positive, does it matter which negative and positive pads I use on the hilt adapter? I plan to bridge the data1 and data2 pads on the proffie board and then then run the single NPXL negative line to that. Please see attached diagram. Top picture is the recommended NPXL wiring, bottom pic is my proposed.
