No webusb found
I used your script instead of zadig and it worked:
Thank you for the help, MTFBWY.
If by “my script” you mean “proffie-dfu-setup.exe”, then I should point out that it only touches bootloader mode and has no capability of fixing webusb at all, so it’s something else you did that fixed it.
It was crashing every time I uploaded it, I just didn’t see it until I pulled up the output because there was no error message.
May I suggest 1.8.19 for the page?
It’s rock solid,
the interface doesn’t try to cram everything into tabs and same windows,
the upload progress bar is incremental on one line,
the serial monitor allows you to use up arrow to access history,
and I’m sure other things that I feel are better but have forgotten due to how long ago I abandoned trying version 2.x
