Maybe it’s just the style editor as I have not tried this on blade yet, but is there any reason the zero opacity colors aren’t allowing the under layer of red to show through in this example?
Layers<
Red,
Stripes<1000,1000,Rgb<60,0,255>,AlphaL<Black,Int<0>>>>
https://tinyurl.com/yesbs6z3
Unfortunately it’s complicated to make stripes work with transparent colors. After my first attempt blew up I decided that stripes will just have to live without it for now. I think if you try to compile that in ProffieOS, you might get an error.
On a side note: I wish I could figure out a way to automatically link posted styles to the style editor in this forum… (Or maybe, I can make a onebox, so that if you post a link to a style, it shows up in a pretty way on the forum instead… hmm, that might be simpler…)
Also confirming no flipping direction on StyleFire, right? I mean, even under the hood a bit?
Negative speeds will not work with the fire style.
I suppose that could be fixed, but right now it does not work.
I’m unchecking the solution, because it’s a solution to something different than the topic.
