Hello! I am trying to get my ProffieOS to work without any issues before adding a real config to my saber, so all I have been attempting so far is verifying the sample config “default_proffieboard_config.h” that comes included in the config folder inside of ProffieOS. After seeing a youtube tutorial that does exactly this and has it working fine has me scratching my head.
Here’s the error I get:
Arduino: 1.8.19 (Mac OS X), Board: "Proffieboard V2, Serial + Mass Storage + WebUSB, SDCARD (SPI), 80 MHz, Smallest Code"
fork/exec /Users/pleasefunk/Library/Arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/arm-none-eabi-g++: no such file or directory
Hopefully I formatted that correctly.
Please tell me if there is more information I need to provide!
Hello, that is simply re-entering the URL into the Additional Boards Manager URLs right?
I tried to do so and it gave me the same error again:
Arduino: 1.8.19 (Mac OS X), Board: "Proffieboard V2, Serial, SDCARD (SPI), 80 MHz, Smallest Code"
Not quite. The URL is telling it where it can go find the plugin. You need to go into the list of available plugins and actually install/update to the latest version 3.6.0.
Follow this page, you should be up to doing step 6 next:
That did work! I get another error now though, stating warning: “memory region `SRAM2’ not declared” when I try to verify the same “default_proffieboard_config.h”. What am I missing?
/Users/lars/Library/Arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld:/Users/lars/Library/Arduino15/packages/proffieboard/hardware/stm32l4/3.6.0/variants/STM32L433CC-ProffieboardV2/linker_scripts/STM32L433CC_FLASH.ld:224: warning: memory region `SRAM2' not declared
/Users/lars/Library/Arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld: warning: changing start of section .bss by 8 bytes
Sketch uses 210064 bytes (80%) of program storage space. Maximum is 262144 bytes.
