No sound with proffieboad
Hey sabers fan I installed a lightsaber with 31mm speaker and proffiboard V3.9 but the sound isnt working so I looked at the serial monitor and when I switch on the lightsaber its wrote
Battery voltage: 0.01
EVENT: Power-Pressed#1 millis=61005
EVENT: Power-Pressed millis=61005
EVENT: Power-Released#1 millis=61125
EVENT: Power-Released millis=61125
EVENT: Power-Shortclick#1 millis=61125
EVENT: Power-Shortclick millis=61125
Ignition.
No sounds found: hum
unit = 0 vol = 0.00, No sounds found: poweron
Audio underflows: 1
Amplifier off.
did someone know what can I do?
This indicates that it hasn’t found any sound files.
Does the “beep” command make a sound?
How can I send command ? But I know that when I power on the kill switch and change the preset it make a distorted sound
The serial monitor has a place to type in commands at the top.
If it makes a distorted sound, then the problem is most likely not the speaker.
If it can’t find any sounds to play, it obviously won’t play them.
What is your font path set to? (Use the “pwd” command to check.)
What files are in those directories on the SD card?
[quote=“Stweez_054, post:6, topic:5593, full:true”]
Battery voltage: 0.02
font0
common
I think its a soundfont problem but there is soundfont (the free one from the SD card)
The folder name where the font resides on the SD card needs to match the font you set in your config. Your config is currently expecting to find a folder named “font0” on your SD card.
You either need to rename the font on your SD to “font0” or you need to update the font for that preset in your config to the correct name and upload the changes.
ok it work thank you
you’re welcome, glad to hear.
