Hi guys,
I recently received a Pach Store saber and I am unable to get ProffieOS working.
I first installed proffieOS as normal and it all worked as intended. I then tried installing a new sound font which did not work so I tried to go back to normal settings. But now when i turn on the saber, it only has one colour and no sound. I am unable to cycle through the various fonts.
I have tried the boot and reset buttons and reinstalled the driver to no avail.
The SD card works fine as i moved it to an identical saber which works as intended.
When i try to reupload Proffie OS i get this;
` c:/users/thomas reed/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/…/lib/gcc/arm-none-eabi/4.8.3/…/…/…/…/arm-none-eabi/bin/ld.exe: warning: changing start of section .bss by 24 bytes
Sketch uses 217544 bytes (88%) of program storage space. Maximum is 245760 bytes.
dfu-util 0.9
Opening DFU capable USB device…
ID 0483:df11
Claiming USB DFU Interface…
Setting Alternate Setting #0 …
dfuERROR, clearing status
dfuIDLE, continuing
Downloading to address = 0x08000000, size = 217552
Download [=========================] 100% 217552 bytes
Download done.
File downloaded successfully
Transitioning to dfuMANIFEST state `
Any help you can offer would be much appreciated
