No Sound After Downloading Config File onto Sabertrio (Aria)
I just got the new “Aria”-model Sabertrio (small scale, sort of like Yoda’s size), it was working great before I did any customizing. When I did start working on downloading custom fonts onto it, it was nothing I haven’t done a hundred times. Which is why I’m confused why the saber is making absolutely no sound after successfully downloading the config file onto the saber.
I checked the code, and it came out without errors. It gave me the count up to 100% in Arduino and everything seemed very normal. But when it was done, it didn’t make the usual distorted sound when it was done, or when I turned off the kill switch, or when I reconnected the chassis to the hilt.
Does anyone have any idea what might be going on?
Well, first things first did you choose the right board version? Can you connect via serial monitor (or are the lights still working?)
LOL My apologies. I found out I was using the wrong config file :frowning: :stuck_out_tongue:
Everything is good now! MTFBWY
