So this is interesting.
Someone had a config file with the same data pin and power pins assigned to multiple blades:
{ 0, WS281XBladePtr<128, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
WS281XBladePtr<16, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
WS281XBladePtr<1, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin1> >(),
SimpleBladePtr<CH2LED,NoLED,NoLED,NoLED,bladePowerPin4,-1,-1,-1>(),
SimpleBladePtr<CH1LED,NoLED,NoLED,NoLED,bladePowerPin5,-1,-1,-1>(),
WS281XBladePtr<4, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin6> >(),
CONFIGARRAY(presets) },
While of course this is not correct, it compiles and uploads successfully with any combination, but causes a non-responding board and Serial Monitor only under certain conditions.
In testing this further, it seems that the issue arises when 2 of the blades are the same number of pixels. I tested commenting out one blade at a time, ie:
leaving the 128 and one of the 16 blades
// WS281XBladePtr<16, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
This compiles, uploads, and Serial Monitor appears fine (no idea what it’s doing on the blades as this test is just USB-> raw board only, no SD card.)
However, leaving the 2 identical blades:
// WS281XBladePtr<128, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
compiles, uploads, but Serial Monitor is blank and apparently the board is unresponsive.
To confirm the identical blades is the issue, I changed one of them by 1 pixel:
WS281XBladePtr<17, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
which indeed compiles, uploads, and Serial Monitor appears fine again.
TL;DR
Maybe we should have an error generated if this condition exists in the BladeConfig? (if possible to detect)
