Here’s my config file
Config File
#include "mysaber_aquila.h"
#define NUM_BUTTONS 1
#define VOLUME 1550
#define CLASH_THRESHOLD_G 3.0
#define ENABLE_SERIAL
#define BC_THRUST_ON
#define BC_TWIST_ON
#define BC_TWIST_OFF
#define BC_FORCE_PUSH
#define FEMALE_TALKIE_VOICE
#define VOLUME_MENU_CYCLE
#define SPEAK_BLADE_ID
#include "../props/saber_BC_buttons.h"
{ "Bank01;common", "tracks/TFA_Battle.wav",
StylePtr<InOutHelper<Blast<LocalizedClash<Lockup<TransitionEffect<TransitionEffect<TransitionEffect<TransitionEffect<TransitionEffect<TransitionEffect<TransitionEffect<Mix<SwingSpeed<600>,StyleFire<BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,300>,Rgb<80,0,0>,0,6,FireConfig<10,1000,2>,FireConfig<0,0,0>,FireConfig<2,1000,5>,FireConfig<100,0,5>>,StyleFire<BrownNoiseFlicker<Red,Rgb<25,0,0>,300>,Rgb<128,0,0>,0,8,FireConfig<10,1200,1>,FireConfig<0,0,0>,FireConfig<2,1000,5>,FireConfig<100,0,5>>>,StyleFire<Red,Rgb<150,150,150>,0,6>,TrInstant,TrSmoothFade<800>,EFFECT_IGNITION>,Mix<Bump<Int<32768>,Int<16000>>,StyleFire<BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>,Rgb<80,0,0>,0,6,FireConfig<10,1000,2>,FireConfig<4000,0,0>,FireConfig<2,1000,5>,FireConfig<100,0,5>>,RandomPerLEDFlicker<OrangeRed,White>>,TrConcat<TrWipeIn<600>,Mix<Bump<Int<32768>,Int<16000>>,StyleFire<BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>,Rgb<80,0,0>,0,6,FireConfig<10,1000,2>,FireConfig<4000,0,0>,FireConfig<2,1000,5>,FireConfig<100,0,5>>,RandomPerLEDFlicker<Orange,White>>,TrWipe<600>>,TrInstant,EFFECT_STAB>,BrownNoiseFlicker<White,Red,400>,TrInstant,TrSmoothFade<200>,EFFECT_LOCKUP_BEGIN>,Mix<Bump<Int<32768>,Int<10000>>,StyleFire<BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>,Rgb<80,0,0>,0,6,FireConfig<10,1000,2>,FireConfig<4000,0,0>,FireConfig<2,1000,5>,FireConfig<100,0,5>>,White>,TrInstant,TrFade<200>,EFFECT_DRAG_BEGIN>,Mix<Bump<Int<32768>,Int<10000>>,StyleFire<BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>,Rgb<80,0,0>,0,6,FireConfig<10,1000,2>,FireConfig<4000,0,0>,FireConfig<2,1000,5>,FireConfig<100,0,5>>,White>,TrInstant,TrFade<300>,EFFECT_DRAG_END>,Black,TrConcat<TrInstant,HumpFlicker<White,BrownNoiseFlicker<Red,Rgb<25,0,0>,400>,40>,TrColorCycle<600>>,TrInstant,EFFECT_RETRACTION>,Mix<Bump<Int<0>,Int<44000>>,Mix<Bump<Int<32768>,Int<44000>>,TransitionEffect<Red,White,TrInstant,TrFade<300>,EFFECT_LOCKUP_END>,Stripes<1000,-1500,Red,BrownNoiseFlicker<White,Red,300>>>,Stripes<1000,1500,Red,BrownNoiseFlicker<White,Red,300>>>,TrInstant,TrSmoothFade<800>,EFFECT_LOCKUP_END>,Pulsing<Gradient<BrownNoiseFlicker<Red,Rgb<25,0,0>,400>,BrownNoiseFlicker<White,Strobe<Blue,White,50,1>,100>>,Gradient<BrownNoiseFlicker<White,Strobe<Blue,White,50,1>,100>,BrownNoiseFlicker<Red,Rgb<25,0,0>,400>>,3500>,RandomPerLEDFlicker<BrownNoiseFlicker<Red,Rgb<25,0,0>,400>,White>,Bump<Int<16000>,Int<16000>>,Bump<Int<32768>,Int<10000>>>,White>,White>,150,300,Black>>()},
{ "Bank02;common", "tracks/FinalSteps.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Rgb<180,130,0>>,RotateColorsX<Variation,Rgb<90,65,0>>>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<200>>,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,ResponsiveDragL<BrownNoiseFlickerL<White,Int<300>>,TrWipeIn<400>,TrFade<400>>,ResponsiveMeltL<Mix<TwistAngle<>,Red,Orange>,TrWipeIn<600>,TrSmoothFade<600>>,InOutTrL<TrWipe<500>,TrWipeIn<800>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Green,Bump<Int<0>,Int<1>>>,TrDelay<50>,AlphaL<Green,Bump<Int<0>,Int<1>>>,TrDelay<25>,AlphaL<Green,Bump<Int<0>,Int<1>>>,TrDelay<25>,AlphaL<Green,Bump<Int<0>,Int<1>>>,TrDelay<35>,AlphaL<DeepSkyBlue,Bump<Int<0>,Int<1>>>,TrDelay<25>,AlphaL<DeepSkyBlue,Bump<Int<0>,Int<1>>>,TrDelay<25>,AlphaL<DeepSkyBlue,Bump<Int<0>,Int<1>>>,TrDelay<30>>,EFFECT_PREON>>>()},
{ "Bank03;common", "tracks/LvsV.wav",
StylePtr<Layers<AudioFlicker<BrownNoiseFlicker<Mix<SwingSpeed<400>,RotateColorsX<Variation,White>,RotateColorsX<Variation,White>>,Stripes<5000,-300,RotateColorsX<Variation,White>,RotateColorsX<Variation,Snow>,RotateColorsX<Variation,White>,RotateColorsX<Variation,White>>,300>,RotateColorsX<Variation,Black>>,TransitionEffectL<TrConcat<TrInstant,White,TrFade<800>>,EFFECT_LOCKUP_END>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<200>>,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,LockupTrL<AlphaL<White,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,ResponsiveBlastWaveL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveBlastWaveL<Rgb<50,50,75>,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,EFFECT_CLASH>,TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb<175,175,225>>>,TrFade<1200>>,EFFECT_IGNITION>,ResponsiveStabL<Red>,ResponsiveDragL<BrownNoiseFlickerL<White,Int<300>>,TrWipeIn<400>,TrFade<400>>,ResponsiveMeltL<Mix<TwistAngle<>,Red,Orange>,TrWipeIn<600>,TrSmoothFade<600>>,InOutTrL<TrWipeX<Scale<BladeAngle<>,Int<500>,Int<200>>>,TrWipeInSparkTip<White,500>>,AlphaL<Black,Scale<IsLessThan<BatteryLevel,Int<11000>>,Int<0>,Int<7500>>>>>()},
{ "Bank04;common", "tracks/Ascension.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>,AlphaL<Black,Scale<IsLessThan<BatteryLevel,Int<11000>>,Int<0>,Int<7500>>>>>()},
{ "Bank05;common", "tracks/DOF.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,TransitionEffectL<TrConcat<TrFade<400>,Mix<SwingSpeed<400>,AudioFlickerL<Rgb<150,0,0>>,Red>,TrDelay<30000>,Mix<SwingSpeed<400>,AudioFlickerL<Rgb<150,0,0>>,Red>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Blue,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>,AlphaL<Black,Scale<IsLessThan<BatteryLevel,Int<11000>>,Int<0>,Int<7500>>>>>()},
{ "Bank06;common", "tracks/Traveler.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,TransitionEffectL<TrConcat<TrFade<400>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<Red,Black,20>,Rgb<10,0,0>,BrownNoiseFlicker<Black,Rgb<255,25,25>,70>,Rgb<128,0,0>>,Rgb<80,0,0>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrDelay<1500>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<Red,Black,20>,Rgb<10,0,0>,BrownNoiseFlicker<Black,Rgb<255,25,25>,70>,Rgb<128,0,0>>,Rgb<80,0,0>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Blue,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()},
{ "Bank07;common", "tracks/General.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,128>>>,TransitionEffectL<TrConcat<TrFade<400>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<Blue,Black,20>,Rgb<0,0,10>,BrownNoiseFlicker<Black,Rgb<25,25,255>,70>,Rgb<0,0,128>>,Rgb<0,0,80>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrDelay<1500>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<Blue,Black,20>,Rgb<0,0,10>,BrownNoiseFlicker<Black,Rgb<25,25,255>,70>,Rgb<0,0,128>>,Rgb<0,0,80>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()},
{ "Bank08;common", "tracks/DarkSide.wav",
StylePtr<Layers<StyleFire<Red,StripesX<Int<3000>,Scale<TwistAngle<>,Int<-500>,Int<0>>,Red,Yellow,OrangeRed,Yellow,Red,Tomato>,0,3,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,Rainbow>,Stripes<1500,-2500,White,Rainbow>>,Int<16384>>,TrFade<800>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<16000>>>,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red>,ResponsiveBlastWaveL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,White>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<60,60,60>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,White>,RotateColorsX<Variation,Rgb<60,60,60>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,128,128>>,RotateColorsX<Variation,Rgb<60,60,60>>>>,TrFade<1200>>,EFFECT_IGNITION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Int<200>,Int<800>>>,TrWipeInSparkTip<White,500>>,TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_NEWFONT>,AlphaL<Black,Scale<IsLessThan<BatteryLevel,Int<11000>>,Int<0>,Int<7500>>>>>()},
{ "Bank09;common", "tracks/Duke.wav",
{ "Bank10;common", "tracks/TheBoldOne.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,0,128>>>,TransitionEffectL<TrConcat<TrFade<400>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<Blue,Black,20>,Rgb<0,0,10>,BrownNoiseFlicker<Black,Rgb<25,25,255>,70>,Rgb<0,0,128>>,Rgb<0,0,80>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrDelay<1500>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<Blue,Black,20>,Rgb<0,0,10>,BrownNoiseFlicker<Black,Rgb<25,25,255>,70>,Rgb<0,0,128>>,Rgb<0,0,80>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<White,TrInstant,TrFade<400>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>>>>()},
{ "Bank11;common", "tracks/LvsV.wav",
{ "Bank12;common", "tracks/JFO5.wav",
StylePtr<Layers<Mix<Scale<BladeAngle<>,Int<32768>,Int<0>>,StyleFire<Gradient<RotateColorsX<Variation,Orange>,RotateColorsX<Variation,OrangeRed>,RotateColorsX<Variation,Red>>,RotateColorsX<Variation,Rgb<60,0,0>>,0,4,FireConfig<0,1500,5>,FireConfig<0,1500,5>,FireConfig<0,1500,5>,FireConfig<0,0,0>>,StyleFire<Gradient<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Red>>,Black,0,2,FireConfig<0,1600,30>,FireConfig<0,1600,30>,FireConfig<0,1600,30>,FireConfig<0,0,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,AlphaL<Black,SmoothStep<Scale<BladeAngle<0,16000>,Scale<SwingSpeed<400>,Int<10000>,Int<38000>>,Int<38000>>,Int<20000>>>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()},
{ "Bank13;common", "tracks/TheBoldOne.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Cyan>,RotateColorsX<Variation,Cyan>>,TransitionEffectL<TrConcat<TrFade<400>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<Cyan,Black,20>,Rgb<0,0,10>,BrownNoiseFlicker<Black,Aquamarine,70>,DeepSkyBlue>,Rgb<0,0,80>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrDelay<1500>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<Blue,Black,20>,Rgb<0,0,10>,BrownNoiseFlicker<Black,Rgb<25,25,255>,70>,Rgb<0,0,128>>,Rgb<0,0,80>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Magenta,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<White,TrInstant,TrFade<400>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>>>>()},
{ "Bank14;common", "tracks/JFO1.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Orange>,RotateColorsX<Variation,Coral>>,TransitionEffectL<TrConcat<TrFade<400>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<Blue,Black,20>,Rgb<0,0,10>,BrownNoiseFlicker<Black,Rgb<25,25,255>,70>,OrangeRed>,Red,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrDelay<1500>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<White,Black,20>,Rgb<0,0,10>,BrownNoiseFlicker<Black,Red,70>,OrangeRed>,Red,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,DeepSkyBlue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Yellow>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<White,TrInstant,TrFade<400>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Yellow>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>>>>()},
{ "Bank15;common", "tracks/LvsV.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,0,128>>>,TransitionEffectL<TrConcat<TrFade<400>,RotateColorsX<Variation,Rgb<90,180,255>>,TrDelay<1500>,RotateColorsX<Variation,Rgb<90,180,255>>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()},
{ "Bank16;common", "tracks/RevanSongYT.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Rgb16<40112,395,57353>>,RotateColorsX<Variation,Magenta>>,TransitionEffectL<TrConcat<TrFade<400>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<White,Magenta,20>,Rgb<10,0,0>,BrownNoiseFlicker<Black,Magenta,70>,Rgb16<40112,395,57353>>,Rgb<80,0,0>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrDelay<1500>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<Red,Black,20>,Rgb<10,0,0>,BrownNoiseFlicker<Black,Rgb<255,25,25>,70>,Rgb<128,0,0>>,Rgb<80,0,0>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Blue,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<White,TrInstant,TrFade<400>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>>>>()},
{ "Bank17;common", "tracks/DarkSide.wav",
{ "Bank18;common", "tracks/Ashoka.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,White>,RotateColorsX<Variation,GhostWhite>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,Rgb<100,100,150>>,Stripes<1500,-2500,White,Rgb<100,100,150>>>,Int<16384>>,TrFade<800>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<Red,BrownNoiseFlicker<Red,OrangeRed,300>,50,1>,TrConcat<TrInstant,Red,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<Magenta,AudioFlicker<White,DeepSkyBlue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red>,ResponsiveBlastWaveL<DeepPink,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<Red,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Int<200>,Int<800>>>,TrWipeIn<500>>,TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,White>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>,AlphaL<Black,Scale<IsLessThan<BatteryLevel,Int<11000>>,Int<0>,Int<7500>>>>>()},
{ "Bank19;common", "tracks/Lycan.wav",
StylePtr<Layers<HumpFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<128,34,0>>,50>,TransitionEffectL<TrConcat<TrFade<400>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Red>,Black,20>,AudioFlicker<RotateColorsX<Variation,Rgb<60,0,0>>,RotateColorsX<Variation,Rgb<10,0,0>>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<255,25,25>>,70>,RotateColorsX<Variation,Rgb<128,0,0>>>,Rgb<80,0,0>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrDelay<30000>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Red>,Black,20>,AudioFlicker<RotateColorsX<Variation,Rgb<60,0,0>>,RotateColorsX<Variation,Rgb<10,0,0>>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<255,25,25>>,70>,RotateColorsX<Variation,Rgb<128,0,0>>>,Rgb<80,0,0>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrFade<800>>,EFFECT_FORCE>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,225,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<20000>>>,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,DarkOrange>,Stripes<1500,-2500,White,DarkOrange>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastWaveL<TransitionEffect<White,Yellow,TrInstant,TrFade<100>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<20000>>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<White,40>,TrFade<1000>>,EFFECT_RETRACTION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<250>,TrWipeInSparkTip<White,300>,Black>>>()},
{ "Bank20;common", "tracks/WhiteTrackwav",
{ "Bank21;common", "tracks/CrimsonMenace.wav",
{ "Bank22;common", "tracks/mars.wav",
{ "Bank23;common", "tracks/Darkness.wav",
{ "Bank24;common", "tracks/mercury.wav",
{ "Bank25;common", "tracks/uranus.wav",
{ "Bank26;common", "tracks/venus.wav",
{ "Bank27;common", "tracks/deadlink.wav",
{ "Bank28;common", "tracks/JFO2.wav",
{ "Bank29;common", "tracks/MSV.wav",
{ "Bank30;common", "tracks/Ascension.wav",
{ "Bank31;common", "tracks/TFA_Duel.wav",
{ "Bank32;common", "tracks/Prism.wav",
StylePtr<Layers<StyleFire<Gradient<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Orange>,RotateColorsX<Variation,Yellow>,RotateColorsX<Variation,Green>,RotateColorsX<Variation,Cyan>,RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Magenta>>,Red,0,3,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>,AlphaL<AlphaL<Azure,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,SmoothStep<Scale<Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>,Int<28000>,Int<14000>>,Int<16000>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Sin<Int<10>,Int<10000>,Int<20000>>>>,AlphaL<White,Bump<Sin<Int<10>,Int<10000>,Int<20000>>>>>,TrConcat<TrInstant,TransitionEffect<Azure,White,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrWaveX<TransitionEffect<White,Azure,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,Int<300>,Int<100>,Int<400>,Sin<Int<10>,Int<10000>,Int<20000>>>>,SaberBase::LOCKUP_NORMAL>,LockupTrL<AlphaL<White,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,MultiTransitionEffectL<TrConcat<TrDelay<300>,AlphaL<RandomPerLEDFlickerL<White>,SmoothStep<Int<6000>,Int<-4000>>>,TrDelay<15000>,AlphaL<RandomPerLEDFlickerL<White>,SmoothStep<Int<6000>,Int<-4000>>>,TrFade<500>>,EFFECT_STAB>, AlphaL<Mix<IsLessThan<BladeAngle<>,Int<26000>>,MultiTransitionEffectL<TrConcat<TrWipeIn<200>,BrownNoiseFlickerL<White,Int<200>>,TrWipeIn<200>>,EFFECT_STAB>,MultiTransitionEffectL<TrConcat<TrWipe<200>,BrownNoiseFlickerL<White,Int<200>>,TrWipe<200>>,EFFECT_STAB>>,Int<32768>>,EffectSequence<EFFECT_BLAST,ResponsiveBlastL<TransitionEffect<Azure,White,TrInstant,TrFade<100>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,Layers<ResponsiveBlastFadeL<TransitionEffect<Azure,White,TrInstant,TrFade<100>,EFFECT_BLAST>,Scale<SwingSpeed<200>,Int<10000>,Int<18000>>>,ResponsiveBlastFadeL<TransitionEffect<Azure,White,TrInstant,TrFade<100>,EFFECT_BLAST>,Scale<SwingSpeed<200>,Int<4000>,Int<10000>>>,ResponsiveBlastWaveL<TransitionEffect<Azure,White,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,BlastL<TransitionEffect<Azure,White,TrInstant,TrFade<50>,EFFECT_BLAST>>,ResponsiveBlastL<TransitionEffect<Azure,White,TrInstant,TrFade<50>,EFFECT_BLAST>>>>,LocalizedClashL<TransitionEffect<Azure,White,TrInstant,TrFade<100>,EFFECT_CLASH>>,TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,White>,40>,TrFade<1200>>,EFFECT_RETRACTION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<300>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RotateColorsX<Variation,Rainbow>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,TrDelay<2000>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrFade<2000>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rainbow>,10>,Bump<Int<0>,Int<4000>>>,TrFade<2950>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rainbow>,15>,Bump<Int<0>,Int<5000>>>,TrFade<3000>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rainbow>,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>>>()},
{ "Rainbow;common", "tracks/cantina.wav",
StylePtr<Layers<StyleFire<StripesX<Int<3000>,Scale<TwistAngle<>,Int<-500>,Int<0>>,Red,Orange,Yellow,Green,Blue,Magenta>,StripesX<Int<3000>,Scale<TwistAngle<>,Int<-500>,Int<0>>,Tomato,OrangeRed,Orange,Yellow,SteelBlue,DeepPink>,0,3,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,Rainbow>,Stripes<1500,-2500,White,Rainbow>>,Int<16384>>,TrFade<800>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<16000>>>,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastWaveL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,White>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<60,60,60>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,White>,RotateColorsX<Variation,Rgb<60,60,60>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,128,128>>,RotateColorsX<Variation,Rgb<60,60,60>>>>,TrFade<1200>>,EFFECT_IGNITION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Int<200>,Int<800>>>,TrWipeInSparkTip<White,500>,Black>,TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_NEWFONT>,AlphaL<Black,Scale<IsLessThan<BatteryLevel,Int<11000>>,Int<0>,Int<7500>>>>>()},
{ "Batt00;common", "tracks/cantina.wav",
/* copyright Fett263 Sauron (Primary Blade) OS6 Style
https://fett263.com/fett263-proffieOS6-style-library.html#Sauron
OS6.7 v4.021
Base Style: Eye of Sauron (Blade Angle Position)
Base Color: Rgb<255,97,0> (Color Shift (Swing Inertia))
Color Shift controlled by Swing Inertia. Color Shift controlled by Swing Inertia. Color Shift controlled by Swing Inertia. Color Shift controlled by Swing Inertia.
Preon Effect: Rey TROS Spark
Ignition Effect Options: Default (0): Twin Suns In, 1: Twin Suns Out
PowerUp Effect: Rey TROS Spark
Retraction Effect: SparkTip Retraction
PostOff Effect: Battery Glow (Preon Size)
Melt Effect: Intensity Melt
Stab Effect: Sparking Stab
Clash Effect: Real Clash V1
Swing Effect: Flame Thrower Swing
StylePtr<Layers<Layers<Remap<CenterDistF<Scale<BladeAngle<>,Int<6000>,Int<27000>>>,StaticFire<Gradient<RotateColorsX<Int<800>,Mix<HoldPeakF<SwingSpeed<400>,Scale<SwingAcceleration<>,Int<500>,Int<2000>>,Scale<SwingAcceleration<>,Int<10000>,Int<5000>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>>>,RotateColorsX<Int<1200>,Mix<HoldPeakF<SwingSpeed<400>,Scale<SwingAcceleration<>,Int<500>,Int<2000>>,Scale<SwingAcceleration<>,Int<10000>,Int<5000>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>>>,RotateColorsX<Int<1600>,Mix<HoldPeakF<SwingSpeed<400>,Scale<SwingAcceleration<>,Int<500>,Int<2000>>,Scale<SwingAcceleration<>,Int<10000>,Int<5000>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>>>>,Mix<HoldPeakF<SwingSpeed<400>,Scale<SwingAcceleration<>,Int<500>,Int<2000>>,Scale<SwingAcceleration<>,Int<10000>,Int<5000>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>>,0,2,0,2400,5>>,AlphaL<AudioFlicker<RotateColorsX<Int<200>,Mix<HoldPeakF<SwingSpeed<400>,Scale<SwingAcceleration<>,Int<500>,Int<2000>>,Scale<SwingAcceleration<>,Int<10000>,Int<5000>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>>>,RotateColorsX<Int<600>,Mix<HoldPeakF<SwingSpeed<400>,Scale<SwingAcceleration<>,Int<500>,Int<2000>>,Scale<SwingAcceleration<>,Int<10000>,Int<5000>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>>>>,Bump<Scale<BladeAngle<>,Int<6000>,Int<27000>>,Scale<NoisySoundLevel,Int<16000>,Int<22000>>>>,AlphaL<Black,LinearSectionF<Scale<BladeAngle<>,Int<6000>,Int<27000>>,Scale<NoisySoundLevel,Int<4000>,Int<8000>>>>>,AlphaL<StaticFire<Stripes<12000,-2000,RgbArg<SWING_COLOR_ARG,Rgb<255,0,0>>,RotateColorsX<Int<200>,RgbArg<SWING_COLOR_ARG,Rgb<255,0,0>>>>,Mix<Int<16384>,Black,RgbArg<SWING_COLOR_ARG,Rgb<255,0,0>>>,0,3,2,2000,8>,SmoothStep<Scale<HoldPeakF<Ifon<Scale<IsGreaterThan<SwingSpeed<500>,Int<16000>>,Int<2000>,SwingSpeed<300>>,Int<0>>,Scale<SwingAcceleration<>,Int<100>,Int<600>>,Scale<SwingAcceleration<>,Int<10000>,Int<4000>>>,Int<1000>,Int<40000>>,Int<-4000>>>,TransitionEffectL<TrConcat<TrJoin<TrDelay<200>,TrInstant>,AlphaL<Green,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-500>>>,TrFade<300>,AlphaL<Blue,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-500>>>,TrFade<500>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RandomPerLEDFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<30,60,200>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<191,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<100,100,150>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<100,100,150>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<100,100,150>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<100,100,150>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<100,100,150>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<100,100,150>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<100,100,150>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<100,100,150>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<100,100,150>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<30,60,200>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<30,60,200>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<30,60,200>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<30,60,200>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,14,0>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,14,0>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrConcat<TrInstant,AlphaL<Black,LayerFunctions<LinearSectionF<Int<8192>,Scale<Trigger<EFFECT_IGNITION,IgnitionTime<300>,IgnitionTime<300>,Int<0>>,Int<16384>,Int<0>>>,LinearSectionF<Int<24576>,Scale<Trigger<EFFECT_IGNITION,IgnitionTime<300>,IgnitionTime<300>,Int<0>>,Int<16384>,Int<0>>>>>,TrDelayX<IgnitionTime<300>>>,TrConcat<TrInstant,AlphaL<Black,LayerFunctions<LinearSectionF<Int<0>,Scale<Trigger<EFFECT_IGNITION,IgnitionTime<300>,Int<0>,Int<0>>,Int<16384>,Int<0>>>,LinearSectionF<Int<16384>,Scale<Trigger<EFFECT_IGNITION,IgnitionTime<300>,Int<0>,Int<0>>,Int<16384>,Int<0>>>,LinearSectionF<Int<32768>,Scale<Trigger<EFFECT_IGNITION,IgnitionTime<300>,Int<0>,Int<0>>,Int<16384>,Int<0>>>>>,TrDelayX<IgnitionTime<300>>>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,RetractionTime<3>>,Black>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<Int<100>>,TrInstant>,AlphaL<Green,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-2000>>>,TrWipe<100>,AlphaL<DodgerBlue,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-2000>>>,TrDelayX<Sum<WavLen<EFFECT_PREON>,Int<200>>>>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,Int<0>>,TrJoin<TrDelayX<Int<500>>,TrFade<500>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFade<500>>,EFFECT_POSTOFF>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<300>>,EFFECT_BATTERY_LEVEL>>>(),
{ "Bank34;common", "Bank34/Kylo.wav",
https://fett263.com/fett263-proffieOS7-style-library.html#CustomBlade
OS7.12 v1.017-p
Multi Phase (Original - Color Change)
Default: Hyper Responsive Rotoscope (Original Trilogy) [BaseColorArg]
1: Unstable Rage [AltColorArg]
Multi Phase Control: use Color Change with COLOR_CHANGE_DIRECT define (to enable click-to-change). Kyber Select Interactive Control: While Blade is On, use selected Special Ability to change color (Phase). Requires Alt Font.
*This style REQUIRES Alt Fonts alt000/ to alt001/ to be set up. Uses altchng.wav on change.
PowerUp Effect: Power Burst Forward [Color: IgnitionColorArg]
PostOff Effect: Emitter Cool Off (Emitter Size) [Color: PostOffColorArg]
Lockup Effect: Responsive Lockup, Begin Effect: Real Clash, End Effect: Full Blade Absorb [Color: LockupColorArg]
Drag Effect: Sparking Drag [Color: DragColorArg]
Stab Effect: Sparking Stab [Color: StabColorArg]
Clash Effect: Responsive Clash with Ripple [Color: ClashColorArg]
Swing Effect: Force Boost Aura [Color: SwingColorArg]
Display Volume: Blade Location [Color: StabColorArg]
Power Save: 10% Increment
Special Ability 1: Next Phase
Special Ability 2: Previous Phase
Special Ability 3: Select Random Phase
Special Ability 4: Toggle Swing Change (Random / Party Mode) Uses tr.wav #0 on toggle
{ "Bank33;common", "Quotes/Quote(13).wav",
StylePtr<Layers<Black,ColorChange<TrSelect<Ifon<Int<1>,Int<0>>,TrInstant,TrFadeX<Int<1000>>>,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<244,147,11>>,RgbArg<BASE_COLOR_ARG,Rgb<244,147,11>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<244,147,11>>>,RgbArg<BASE_COLOR_ARG,Rgb<244,147,11>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<244,147,11>>>>,RgbArg<BASE_COLOR_ARG,Rgb<244,147,11>>>,RgbArg<BASE_COLOR_ARG,Rgb<244,147,11>>>,Stripes<3000,-3500,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>>,Black>,BrownNoiseFlicker<RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>,Mix<Int<3855>,Black,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>>,200>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>>,Mix<Int<3855>,Black,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelay<30000>,TrFade<300>>,AudioFlickerL<RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>,TrFade<300>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<300>>,TrInstant>,Stripes<5000,-2500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<1>>,Int<2>>,Int<-1>>,EFFECT_USER1>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<-1>>,Int<2>>,Int<-1>>,EFFECT_USER2>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Scale<RandomF,Int<1>,Int<1>>>,Int<2>>,Int<-1>>,EFFECT_USER3>,TransitionPulseL<TrSelect<IncrementModuloF<EffectPulseF<EFFECT_USER4>,Int<2>>,TrInstant,TrDoEffectX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Scale<RandomF,Int<1>,Int<1>>>,Int<2>>,Int<-1>>>,ThresholdPulseF<SwingSpeed<320>,Int<31000>>>,TransitionEffectL<TrDoEffectX<TrInstant,EFFECT_TRANSITION_SOUND,Int<0>,Int<-1>>,EFFECT_USER4>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RandomPerLEDFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,0,0>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<6000>>>,TrCenterWipeX<Int<100>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,AlphaL<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1400,-2000,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<2096>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<38000>>>,TrJoin<TrSmoothFade<50>,TrCenterWipeX<Int<100>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrWipeIn<200>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,0,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,0,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,0,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,0,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,0,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,0,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,0,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Orange,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Red,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-2000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>>,EFFECT_POSTOFF>,EffectSequence<EFFECT_POWERSAVE,AlphaL<Black,Int<3277>>,AlphaL<Black,Int<6554>>,AlphaL<Black,Int<9831>>,AlphaL<Black,Int<13108>>,AlphaL<Black,Int<16385>>,AlphaL<Black,Int<19662>>,AlphaL<Black,Int<22939>>,AlphaL<Black,Int<26216>>,AlphaL<Black,Int<29493>>,AlphaL<Black,Int<0>>>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<300>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrExtend<2000,TrFade<100>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,0,0>>,Bump<VolumeLevel,Int<8000>>>,TrFade<300>>,EFFECT_VOLUME_LEVEL>>>(),
{ 0, WS281XBladePtr<114, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), CONFIGARRAY(presets) },
