Well, I’m not sure what’s going on here.
It seems like the pixels are getting power and data, and that should make them light up if they work.
I think I would recommend getting some other neopixels and see if they will work or not. The only other option I can think of would be to use a logic analyzer or an oscilloscope to check that the data signal actually looks correct.
Further to this Fredrik, Aaron_Blue has confirmed that during the installation of his parts, he held the main blade connector manually to his blade and applied power. I believe a short has occured.
A similiar issue to what occured on this thread here: Red Light on PCB
I did want to mention that this red light only came on when I tried to hold the blade to the connector bcs I thought that is what the “blades” mean in the power/data/fet test.
Method: I remove the battery, physically held it to the connectors (without moving when on/off cause it may be issue). Then i put the battery in and turned the kill switch off (to allow power) and then turned the blade/chassis on with the on button.
When turning off I then powered off kill switch (disconnect connect the power) and removed battery. Then i removed the blade.
I held the blade steady while my dad did the other steps. no smoke or short wires/sparks.
Ultimately we don’t know what the problem is.
It could have been holding the blade in place, it could have been something that happened earlier, or possibly just bad luck and static electricity.
My point is that we don’t even really know if it’s the pixels that are damaged, or the board, or both. Getting a few extra neopixels (not a whole new blade) seems like a the cheapest way to test this. If the new pixels work, then the old pixels must be damaged, if the new pixels don’t work, then the problem must be in the board, or the wiring.
“Pixels” is an LED with a built-in controller. Usually they are capable of displaying any color, and controlled with the WS2811 protocol. (WS2811 is the name of the original chip which used this protocol, the protocol itself doesn’t actually have a name.) Adafruit calls these sort of LED “neopixels”. Neopixels is a good name, but it’s trademarked by Adafruit, so I usually just call them “pixels”.
“pixels” comes in many shapes and packages, adafruit has lots of choices:
I would order a couple of single pixels in some shape that’s easy to work with, like flora, or the diffused through-hole ones. Then you just have to wire one of these up and see what happens.
They are also handy to have around when building a crystal chamber or something.
Hi Fred, hope you are doing well!
I got back the saber fixed and it works well,
Unfortunately after so much cost I accidnetly messed up the button switche LEDS by plugging the battery in reverse. Only one led worked after smoke came from only that one led top switch. Is the fett controlling led 3,6 working still bcs it does make the button led light up but other is broken. I hope reverse polarity protection worked even though i did not connect the blade. Any clues?
The accents leds on top were working and Neo pixel. I did not plug in a blade at all luckily! But u can see the lights perfectly. so the reverse polarity protection was working indeed.
when putting chassis in the hilt, it did not go all the way, so when I took it out, it suddenly came out not working. Idk where but I feel the chases may have hit the metal and this causedthe accent led to short circuit and then as Neo pixel hilt side pcb data wire is connected in series to accent led, It made the Neo pcb not light up too.
Is the profit board broken too now or just the accent led? I would think since it survived the reverse polarity protection then touching the metal hilt where on/ignited would not destroy the board. It could destroy the accent leds since that has no resistor and my saber smith noticed they break easily.
Also how can just the pixel connectors accidentally touching the metal hilt while on (with power, blade not ignited) cause such a circuit to blow the accent LEDS (which I believe is the case?)
I only saw smoke from the button LEDS and not accent leds or the proffie board.
Unfortunately my pitiful situation means I can’t test with multimeter as I need to buy all the equipment where I stay. It is only just getting replacement parts and then fixing with a solderer near me. If the board is broken I may need to abandon project for a while.
the accent led and board. as far as I can see, board is fine and wires are connected well in the accent led. I just had a doubt maybe the wire came out but that seems not likely.
On closer inspection it seems i broke the one led on the top while trying to put in the hilt. I am not even sure how bcs it is so dark inside.
Since this are series it seems that 1 broken led physical may cause the whole circuit to fail but i thought it is fine so long as it is fine internally.
V2 and V2 proffieboards have reverse polarity protection, however that protection only protects the board itself. Other connected components might not be so lucky, and neopixels in particular tends to die when you give them reverse current. (Although WS2813 pixels supposedly have their own reverse polarity protection and should be fine.)
No idea. A random short like that may do nothing, or it may damange everything. You would need to test it to find out.
Generally speaking it shouldn’t, unless one of two things happens:
something else is also connected to the metal hilt, like batt+ or batt- causing a short.
There was some major static electricity in the room, causing a spark
Anyways… without testing equipment, there is still some tests you can do, like:
Does your board make sounds when hooked up to a speaker?
Does your board show up when hooked up to a computer?
1,2 both yes. I didn’t notice, see or hear any sparks. It just magically came out not working. Though it did work a few times in hilt. The accent led is very loose.
Actually I even just had a quick look, based on the accent led image, I think we can see that the accent led is physically broken bcs 1 led got chipped when inserting due to massive lack of space.
Not sure if this is main cause but it mostly likely is bcs even after the button leds broke, accents/blade still worked.
Right now just 1 button led works. Speakers, sound, programming in arduino, adding new fonts, the buttons as buttons themselves all work fine . All seem perfect.
Even that one single working led seems to mimic the behaviour on code perfectly.
This all seems reasonable. It seems likely that fixing the one LED will put you back to where it was after inserting the battery backwards. (most things working, but not the button LEDs)
Yes. Thanks as well. I really hope it works, too expensive so far
Buttons i saw them get fried with my eyes. One button is on led 2 and other button and hilt side pcb are on 4.5.6. Since 4,5 weere working before I guess the button fried internally since i did not see smoke on the other button.
The accent leds dont work but that makes sense. Not short circuit for that but it got physical destroyed in hilt. Elf saber hilts sometimes
