No battery level sound or animation
Hi, Ive got a problem getting battery level to work, the chassis is removable and if you flip it 180 and insert, power and aux switch buttons.
Theres’s accent Leds on the chassis that light up.
I used Fett’s OS7 library for main blade and accents. For the common file used No Sloppy’s awesome Anakin HC sound pack.
When I try battery level there’s no response, the saber won’t respond, and I have to reset the battery to get it working again.
Volume works fine just had to copy volume files to the font folder.
If I try to color change with blade on it will beep and twisting to select color also freezes the saber, is this related?
#define NUM_BLADES 2
#define VOLUME 2500
#define CLASH_THRESHOLD_G 3.0
#define ENABLE_SERIAL
#define MOTION_TIMEOUT 60 * 10 * 1000 // keeps motion chip active for 10 minutes while blade is Off
#define FETT263_THRUST_ON // enables Thrust On Ignition
#define FETT263_SWING_ON // enables Swing On Ignition
#define FETT263_TWIST_ON // enables Twist On Ignition
#define FETT263_TWIST_OFF // enables Twist Off Retraction
#define FETT263_MAX_CLASH 16
#define SAVE_STATE
#include"../props/saber_fett263_buttons.h"
 { "Anakin;common", "Anakin/tracks/temple march.wav",
OS7.14 v3.01p
This Style Contains 16 Unique Combinations
Multi Phase (Original - Color Change) Transition: Smooth Fade, Time: 2000
Default: Hyper Responsive Rotoscope (Prequels) [BaseColorArg]
1: Hyper Responsive Rotoscope (Erratic) [AltColorArg]
Multi Phase Control: use Color Change with COLOR_CHANGE_DIRECT define (to enable click-to-change).
Ignition Effect Options: Default (0): Standard Ignition, 1: SparkTip Ignition, 2: Stack, 3: Cycle Up [Color: IgnitionColorArg]
Retraction Effect Options: Default (0): Standard Retraction, 1: SparkTip Retraction, 2: Unstack, 3: Cycle Down [Color: RetractionColorArg]
Lockup Effect:
0: mainLockMulti0Shape - Begin: Real Clash - Style: Intensity Unstable Ripple - End: Dissipate
[Color: AltColor3Arg]
Lightning Block Effect:
0: mainLBMulti0Shape - Begin: Responsive Impact - Style: Strobing Unstable Flicker - End: Dissipate
Drag Effect:
Melt Effect:
Stab Effect: Normal Stab [Color: AltColor3Arg]
Blast Effect (Randomly Selected): Responsive Blast Wave (Random), Responsive Blast Fade (Sound Based), Responsive Blast Ripple [Color: AltColor3Arg]
Clash Effect: Real Clash V1 [Color: AltColor3Arg]
StylePtr<Layers<
  Black,
  ColorChange<TrSelect<Ifon<Int<1>,Int<0>>,TrInstant,TrDoEffect<TrSmoothFadeX<Int<2000>>,EFFECT_TRANSITION_SOUND>>,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<24000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-1400>,Int<-100>>,RgbArg<BASE_COLOR_ARG,Blue>,RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Blue>>>,RgbArg<BASE_COLOR_ARG,Blue>>,RgbArg<BASE_COLOR_ARG,Blue>>,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,Mix<Scale<IsLessThan<SlowNoise<Int<2000>>,Int<18000>>,Int<0>,Int<32768>>,RgbArg<ALT_COLOR_ARG,Red>,Stripes<12000,-800,RgbArg<ALT_COLOR_ARG,Red>,RgbArg<ALT_COLOR_ARG,Red>,Mix<Int<7710>,Black,RgbArg<ALT_COLOR_ARG,Red>>,RgbArg<ALT_COLOR_ARG,Red>,Mix<Int<16448>,Black,RgbArg<ALT_COLOR_ARG,Red>>>>,RgbArg<ALT_COLOR_ARG,Red>>>,
  TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<ALT_COLOR3_ARG,NavajoWhite>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,
  TransitionEffectL<TrRandom<TrWaveX<RgbArg<ALT_COLOR3_ARG,NavajoWhite>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Scale<WavLen<>,Int<9000>,Int<13000>>>,RgbArg<ALT_COLOR3_ARG,NavajoWhite>,Mix<Int<16384>,Black,RgbArg<ALT_COLOR3_ARG,NavajoWhite>>>,TrFade<300>>,TrConcat<TrInstant,AlphaL<RgbArg<ALT_COLOR3_ARG,NavajoWhite>,Bump<Scale<BladeAngle<>,Int<3000>,Int<29000>>,Int<6000>>>,TrCenterWipeX<Int<100>,Scale<BladeAngle<>,Int<3000>,Int<29000>>>,Remap<CenterDistF<Scale<BladeAngle<>,Int<3000>,Int<29000>>>,Stripes<1600,-2000,RgbArg<ALT_COLOR3_ARG,NavajoWhite>,Mix<Int<2096>,Black,RgbArg<ALT_COLOR3_ARG,NavajoWhite>>>>,TrCenterWipeX<Int<100>,Scale<BladeAngle<>,Int<3000>,Int<29000>>>>>,EFFECT_BLAST>,
  Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<ALT_COLOR3_ARG,NavajoWhite>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<ALT_COLOR3_ARG,NavajoWhite>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,
  LockupTrL<TransitionEffect<AlphaL<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<2000,-3200,RandomPerLEDFlicker<RgbArg<ALT_COLOR3_ARG,NavajoWhite>,Mix<Int<14000>,Black,RgbArg<ALT_COLOR3_ARG,NavajoWhite>>>,Mix<Int<18000>,Black,RgbArg<ALT_COLOR3_ARG,NavajoWhite>>,Mix<Int<8000>,Black,RgbArg<ALT_COLOR3_ARG,NavajoWhite>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<15000>,Int<23000>>>>,AlphaL<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1600,-2600,RandomPerLEDFlicker<RgbArg<ALT_COLOR3_ARG,NavajoWhite>,Mix<Int<14000>,Black,RgbArg<ALT_COLOR3_ARG,NavajoWhite>>>,Mix<Int<18000>,Black,RgbArg<ALT_COLOR3_ARG,NavajoWhite>>,Mix<Int<8000>,Black,RgbArg<ALT_COLOR3_ARG,NavajoWhite>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<15000>,Int<19000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<ALT_COLOR3_ARG,NavajoWhite>,AlphaL<RgbArg<ALT_COLOR3_ARG,NavajoWhite>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaL<RgbArg<ALT_COLOR3_ARG,NavajoWhite>,Int<0>>,TrWaveX<RgbArg<ALT_COLOR3_ARG,NavajoWhite>,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>>,SaberBase::LOCKUP_NORMAL>,
  ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,White>,BrownNoiseFlickerL<RgbArg<LB_COLOR_ARG,White>,Int<300>>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,White>,TrFade<400>>>,
  LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<ALT_COLOR3_ARG,NavajoWhite>>,BrownNoiseFlickerL<RgbArg<ALT_COLOR3_ARG,NavajoWhite>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG>,
  LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<ALT_COLOR3_ARG,NavajoWhite>,RotateColorsX<Int<3000>,RgbArg<ALT_COLOR3_ARG,NavajoWhite>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<ALT_COLOR3_ARG,NavajoWhite>,RotateColorsX<Int<3000>,RgbArg<ALT_COLOR3_ARG,NavajoWhite>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<ALT_COLOR3_ARG,NavajoWhite>,RotateColorsX<Int<3000>,RgbArg<ALT_COLOR3_ARG,NavajoWhite>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<ALT_COLOR3_ARG,NavajoWhite>,RotateColorsX<Int<3000>,RgbArg<ALT_COLOR3_ARG,NavajoWhite>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<ALT_COLOR3_ARG,NavajoWhite>,RotateColorsX<Int<3000>,RgbArg<ALT_COLOR3_ARG,NavajoWhite>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
  InOutTrL<TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrWipeX<BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,White>,BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrConcat<TrInstant,AlphaL<Black,SmoothStep<Int<6554>,Int<0>>>,TrDelayX<Mult<IgnitionTime<0>,Int<8192>>>,AlphaL<Black,SmoothStep<Int<13108>,Int<0>>>,TrDelayX<Mult<IgnitionTime<0>,Int<8192>>>,AlphaL<Black,SmoothStep<Int<19662>,Int<0>>>,TrDelayX<Mult<IgnitionTime<0>,Int<8192>>>,AlphaL<Black,SmoothStep<Int<26216>,Int<0>>>,TrDelayX<Mult<IgnitionTime<0>,Int<8192>>>>,TrColorCycleX<BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeInX<BendTimePowX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInSparkTipX<RotateColorsX<Int<4096>,RgbArg<RETRACTION_COLOR_ARG,White>>,BendTimePowX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,TrConcat<TrInstant,AlphaL<Black,SmoothStep<Int<26216>,Int<0>>>,TrDelayX<Mult<RetractionTime<>,Int<8172>>>,AlphaL<Black,SmoothStep<Int<19662>,Int<0>>>,TrDelayX<Mult<RetractionTime<>,Int<8172>>>,AlphaL<Black,SmoothStep<Int<13108>,Int<0>>>,TrDelayX<Mult<RetractionTime<>,Int<8172>>>,AlphaL<Black,SmoothStep<Int<6554>,Int<0>>>,TrDelayX<Mult<RetractionTime<>,Int<8192>>>>,TrColorCycleX<BendTimePowX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>>>,
  TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<300>>,EFFECT_BATTERY_LEVEL>>>(),
/* copyright Fett263 CustomBlade (Accent LED / PCB) OS7 Style
OS7.14 v3.01p
Multi Phase (Original - Color Change) Transition: Fade, Time: 2000
Off Behavior: Off [Color: OffColorArg]
[Color: DragColorArg]
Melt Effect:
[Color: StabColorArg]
Battery Level: Full Blade (Green to Red)
StylePtr<Layers<
  Black,
  TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<300>>,EFFECT_BATTERY_LEVEL>>>(), "Anakin"},
 { 0, WS281XBladePtr<128, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
    WS281XBladePtr<6, bladePin, Color8::GRB, PowerPINS<bladePowerPin5, bladePowerPin6> >()
  , CONFIGARRAY(presets) },
#endif'''
Thanks
You’re saying the saber freezes?
What files are in your common folder?
Did you run ‘sdtest’ to make sure the SD isn’t corrupted and/or is sufficient?
Hi Fett, the common folder contains all Anakins voice commands, am I missing some files?
Yeah I was wondering if my sd is corrupt
Just ran sdtest it scrolls though all the wav files
Avg speed is 1293.58 kb/s sim. Audio streams
That seems normal, review the controls perhaps?
Ok thanks, Ill take a look🙂
Hi Fett, wow to get it to work I had to put every file in the common folder into the root font directory?? :thinking:
The ‘common’ folder belongs in the root of the SD. If you put it in the font, then it won’t work.
hmm I copied every common file and put it in my Anakin font folder, honestly it worked
Yes, that would work as well but that means those sounds are specific to the font. To have the common folder work correctly it needs to be in the root of the SD, then it uses those sounds for all presets.
having the same issue
You’re gonna need to be more specific on your issue for us to help.
What’s not working, what’s in your config, what’s in your font?
To add to @Fett263 said - perhaps start a new thread.
