So I am using the MultiPhase Blade Style from Fett263 and Am trying to figure out how to add the alt font to the config that it says it needs.( I am also using his config tool) I am not sure if I have to have two seperate fonts, one font with the Hero and a second with the Villan on the SD Card; Or if I can have it all in One Folder. Any help would be greatly appreciated as I really want to be able to use these dual phase Fonts.
Apologies if I wasn’t too clear on with my question, like I stated I am new and don’t know very much especially the terminology. Please also forgive me if I am posting in the wrong area, I did get a Proffie V 2.2 so I figured this would be the best place to post this question for getting these fonts and styles programed correctly in the config.
You’ll need to have everything in one folder, try reading this and see if helps:
The recommended videos at the top of the library will also help ;-).
I failed to see those…sorry and thank you for the doc made a lot more sense
Quick Question,
I have everything set-up for the Al;t-Fonts, just one question about the quotes.
Can I just put the quotes into a common folder or do I have to have a quotes folder in each alt font?
Quotes need to be named quote01.wav, quote02.wav, etc.
You only need to put sounds in an altNNN/ folder if you want them to be different with the Alt Font, if they are shared they can just go in the root of the font.
So ‘font/quote/quote01.wav’ works for all Alts, ‘font/alt000/quote/quote01.wav’ is for Alt0 ( you then then need exact same number of quotes in all altNNN folders) and ‘common/quote/quote01.wav’ is shared for all presets, unless the font contains its own quote folder.
Awsome! Thanks For the help I almost had it just have to fix that real fast. Really appreciate the help!!
So I know I posted about this a little while ago, but I finally have my favor, called up and running read all the documentation got everything in the folder and picks up everything except my blaster. You guys know how the glass I set up my regular blaster at my blaster, but I get no blast or sound effects at all, I set it up in alt 000 and alt 001 With the same name for the folders and the same Number of files in The folder but no still for the blaster is there something I did wrong? Any help would be greatly appreciated.
If you mean the blast effect, did you name the sounds correctly?
blst01.wav
Yes sir I’m not sure what I missed but will go over everything in detail once I get home again because for some reason my Crystal wouldn’t change color either even though it’s supposed to in the blade style it goes from blue to red but that’s another issue which I’m going to address later by looking at my config and probably redoing some of it.
Could it possibly be within the config. I’m using the multi phase blade style and special abilities to change to the alt font.
If you could explain this a little better, it might help.
I apologize I was speaking into my phone when I posted that I’m not sure exactly what that’s supposed to say lol. But I believe it was about the youngling blasters on the Chosen One Font (Villan) I had set up the alt fonts and made my folder within. They have the same number of files and labeled correctly just not sure why I’m not getting any blaster sounds when I use the special ability to switch to my alt font. Used the Multi Phase blade style. All my other sounds work when I switch to the alt font. For example him.wav works exactly as it should just not sure what I did with my blst.wav when I get home I’m triple checking everything the going to the config to see if I might’ve put the wrong file pathway or something. Because somehow when I was check on my switch issue I changed something with the color on my config for part of my CC accent.
Temporarily remove “DISABLE_DIAGNOSTIC_COMMANDS” from your config
Upload and leave saber connected to the computer
Go Arduino > Tools > Serial Monitor
Type ‘effects’ (make sure you’re on the preset in question)
It should print out what files it found if blst is no showing you’ll need to check the font, you can post here if necessary.
Will definitely check this out. And update tomorrow, it’s my 10th anniversary today so I’m going to be away today. Appreciate it @Fett263
Happy anniversary.
Thanks for the well wishes. And the help. Everything is working great now. I guess something was acting up my SD card or computer when I was disconnecting it from the computer and removing it it was somehow booting what I just uploaded so I just reformatted to make sure nothing was corrupted and to make sure my computer was uploading to the card properly. Weird gremlin but everything is working good and proper now.
