Alright, slightly more advanced question here.
Arduino is beginning to throw up errors at me, but this time it looks like it’s not related to the config.
Arduino: 1.8.19 (Windows 10), Board: “Proffieboard V2, Serial + WebUSB, SDCARD (SPI), 80 MHz, Smallest Code”
c:/users/xmetr/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/…/lib/gcc/arm-none-eabi/9.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe:C:\Users\xmetr\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\3.6.0\variants\STM32L433CC-ProffieboardV2/linker_scripts/STM32L433CC_FLASH.ld:224: warning: memory region `SRAM2’ not declared
c:/users/xmetr/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/…/lib/gcc/arm-none-eabi/9.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: warning: changing start of section .bss by 8 bytes
c:/users/xmetr/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/…/lib/gcc/arm-none-eabi/9.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: C:\Users\xmetr\AppData\Local\Temp\arduino_build_616605/ProffieOS.ino.elf section
.text' will not fit in regionFLASH’c:/users/xmetr/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/…/lib/gcc/arm-none-eabi/9.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: warning: changing start of section .bss by 8 bytes
c:/users/xmetr/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/…/lib/gcc/arm-none-eabi/9.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: region `FLASH’ overflowed by 2872 bytes
I’m guessing that means something is too big, but I’m 99% sure it’s not the config, seeing as the flash overflow bytes didn’t change when i saved the config with more/less in it. Ideas? Anyone seen this before?
