New preset issue - no sound
Hi. Newb here. I recently attempted adding a new Seismic Charge preset on OS7. I am having some issues. 1. the new preset has no sound at all for any effects. 2, the preon I chose doesn’t run. I suspect I have messed up saving the wav files, but am a bit lost.
Basically, we’d need some more info to help figure out what’s going on.
It would help if you posted your config here, or at least copy / paste the preset that’s not working.
The process is very basic.
  • add the font folder to the SD card.
  • add a preset to the config file that uses the exact name of the font.
  • Save the config file and upload to the board.
If it’s not working, you should make sure the font name matches the font folder name on the SD card exactly.
Does the board say “Font Directory Not Found” when you cycle to that preset?
You could also open serial monitor in Arduino and see what it says when you get to that preset and it doesn’t work.
Here is my config.
#define NUM_BLADES 2
#define VOLUME 1800
const unsigned int maxLedsPerStrip = 128;
#define CLASH_THRESHOLD_G 4.5
#define ENABLE_SERIAL
#define FETT263_STAB_ON_NO_BM
#define FETT263_SWING_OFF
#define FETT263_USE_BC_MELT_STAB
#define FETT263_POWER_LOCK
#define FETT263_THRUST_ON
#define FETT263_THRUST_OFF
// #define ENABLE_SSD1306
// // Max 20 characters
// #define BLE_PASSWORD "your password"
// // Max 32 characters.
// #define BLE_NAME "Your Saber Name"
// // Max 9 characters
// #define BLE_SHORTNAME "Saber"
#define MOTION_TIMEOUT 60 * 3 * 800
    { "Seismic Blade;common", "tracks/march.wav",
/* copyright Fett263 WaterBlade (Primary Blade) OS7 Style
https://www.fett263.com/fett263-proffieOS7-style-library.html#WaterBlade
OS7.14 v2.25p
Base Style: Interactive Water Blade
Base Color: BaseColorArg (0)
Interactive Water Blade Interactive Control: Water flows based on blade angle, hard swing upward can temporarily change direction of flow.
Preon Effect: Seismic Charge [Color: IgnitionColorArg]
Ignition Effect: Center Out [Color: IgnitionColorArg]
PowerUp Effect: Power Flash [Color: IgnitionColorArg]
Retraction Effect: Center In [Color: RetractionColorArg]
Lockup Effect:
[Color: LockupColorArg]
Lightning Block Effect:
0: mainLBMulti0Shape - Begin: Responsive Impact - Style: Strobing HumpFlicker - End: Full Blade Absorb
[Color: LBColorArg]
Drag Effect:
[Color: DragColorArg]
Melt Effect:
[Color: StabColorArg]
StylePtr<Layers<StripesX<Scale<IsLessThan<BladeAngle<>,Int<16384>>,Scale<BladeAngle<>,Int<20000>,Int<10000>>,Scale<BladeAngle<>,Int<10000>,Int<20000>>>,Scale<BladeAngle<>,Int<-1000>,Scale<IsGreaterThan<HoldPeakF<SwingAcceleration<>,Scale<HoldPeakF<SwingAcceleration<>,Int<200>,Int<4000>>,Int<100>,Int<600>>,Scale<BladeAngle<>,Int<3000>,Int<6000>>>,Int<16384>>,Int<1000>,Int<-1000>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<25700>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<300>>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_IGNITION>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,HumpFlickerL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,100>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrCenterWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>,Int<16384>>,TrCenterWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>,Int<16384>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<PulsingL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Int<400>>,Bump<Scale<Trigger<EFFECT_PREON,Int<800>,Int<2000>,Int<500>>,Int<0>,Int<16384>>,Int<8000>>>,TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<18432>>>,Mix<Bump<Int<16384>,Int<8000>>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,TrCenterWipeX<Mult<WavLen<EFFECT_PREON>,Int<4096>>,Int<16384>>,Mix<Bump<Int<16384>,Int<8000>>,Black,PulsingL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Int<300>>>,TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<10240>>>>,EFFECT_PREON>>>(),
StylePtr<Layers<StripesX<Scale<IsLessThan<BladeAngle<>,Int<16384>>,Scale<BladeAngle<>,Int<20000>,Int<10000>>,Scale<BladeAngle<>,Int<10000>,Int<20000>>>,Scale<BladeAngle<>,Int<-1000>,Scale<IsGreaterThan<HoldPeakF<SwingAcceleration<>,Scale<HoldPeakF<SwingAcceleration<>,Int<200>,Int<4000>>,Int<100>,Int<600>>,Scale<BladeAngle<>,Int<3000>,Int<6000>>>,Int<16384>>,Int<1000>,Int<-1000>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<25700>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<300>>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_IGNITION>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,HumpFlickerL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,100>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrCenterWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>,Int<16384>>,TrCenterWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>,Int<16384>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<PulsingL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Int<400>>,Bump<Scale<Trigger<EFFECT_PREON,Int<800>,Int<2000>,Int<500>>,Int<0>,Int<16384>>,Int<8000>>>,TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<18432>>>,Mix<Bump<Int<16384>,Int<8000>>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,TrCenterWipeX<Mult<WavLen<EFFECT_PREON>,Int<4096>>,Int<16384>>,Mix<Bump<Int<16384>,Int<8000>>,Black,PulsingL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Int<300>>>,TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<10240>>>>,EFFECT_PREON>>>(), "Seismic Blade"},
   { "AhsokaTM;common", "tracks/mars.wav",
    StylePtr<InOutHelper<EasyBlade<OnSpark<BrownNoiseFlicker<Snow,Blue,50>>,White>,300,800>>(),
    StylePtr<InOutHelper<EasyBlade<OnSpark<BrownNoiseFlicker<Snow,Blue,50>>,White>,300,800>>(), "Ahsoka"},
   { "Ben;common", "tracks/mars.wav",
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<DeepSkyBlue,White>,AudioFlicker<DeepSkyBlue,White>>,White>,300,800>>(),
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<DeepSkyBlue,White>,AudioFlicker<DeepSkyBlue,White>>,White>,300,800>>(), "Ben"},
   { "Dooku;common", "tracks/mars.wav",
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Red,White>,AudioFlicker<Red,White>>,White>,400,800>>(),
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Red,White>,AudioFlicker<Red,White>>,White>,400,800>>(), "Dooku"},
   { "DV3;common", "tracks/mars.wav",
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Red,White>,AudioFlicker<Red,White>>,White>,400,800>>(), "DV3"},
   { "Emperor;common", "tracks/mars.wav",
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Red,White>,AudioFlicker<Red,White>>,White>,400,800>>(), "Emperor"},
   { "Fire;common", "tracks/mars.wav",
    StylePtr<StyleFire<Red,Yellow>>(),
    StylePtr<StyleFire<Red,Yellow>>(), "Fire"},
   { "Graflex;common", "tracks/venus.wav",
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Blue,White>,AudioFlicker<Blue,White>>,White>,300,800>>(),
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Blue,White>,AudioFlicker<Blue,White>>,White>,300,800>>(), "chunblue"},
   { "Luke;common", "tracks/venus.wav",
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Green,White>,AudioFlicker<Green,White>>,White>,400,800>>(),
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Green,White>,AudioFlicker<Green,White>>,White>,400,800>>(), "Luke"},
   { "luke4;common", "tracks/mars.wav",
    StylePtr<InOutHelper<EasyBlade<OnSpark<Gradient<Blue,AudioFlicker<White,Blue>,Red,RandomFlicker<Yellow,Blue>>>,White>,300,800>>(),
    StylePtr<InOutHelper<EasyBlade<OnSpark<Gradient<Blue,AudioFlicker<White,Blue>,Red,RandomFlicker<Yellow,Blue>>>,White>,300,800>>(), "KK"},
   { "luke5;common", "tracks/venus.wav",
    StylePtr<InOutHelper<RandomPerLEDFlicker<Pulsing<Blue,InOutHelper<White,300,800>,800>,Blue>,300,800>>(),
    StylePtr<InOutHelper<RandomPerLEDFlicker<Pulsing<Blue,InOutHelper<White,300,800>,800>,Blue>,300,800>>(), "BLUEFLASH"},
   { "QGJ;common", "tracks/venus.wav",
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Green,White>,AudioFlicker<Green,White>>,White>,300,800>>(),
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Green,White>,AudioFlicker<Green,White>>,White>,300,800>>(), "chungreen"},
   { "Rey;common", "tracks/mars.wav",
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Blue,White>,AudioFlicker<Blue,White>>,White>,300,800>>(), "sparkstar"},
   { "reygold;common", "tracks/mars.wav",
    StylePtr<InOutHelper<EasyBlade<Sparkle<Orange>,White>,300,800>>(),
    StylePtr<InOutHelper<EasyBlade<Sparkle<Orange>,White>,300,800>>(), "sparkstar"},
   { "RgueCmdr;common", "tracks/venus.wav",
    StylePtr<InOutHelper<EasyBlade<OnSpark<TransitionLoop<Red,TrConcat<TrFade<1000>,GreenYellow,TrFade<200>>>>,White>,300,800>>(),
    StylePtr<InOutHelper<EasyBlade<OnSpark<TransitionLoop<Red,TrConcat<TrFade<1000>,GreenYellow,TrFade<200>>>>,White>,300,800>>(), "CC"},
   { "SmthFuzz;common", "tracks/uranus.wav",
    StylePtr<InOutHelper<EasyBlade<OnSpark<Gradient<Cylon<Red,5,20,Red,30,20,1>,GhostWhite,Cylon<Red,5,20,Red,5,20,1>>>,White>,300,800>>(),
    StylePtr<InOutHelper<EasyBlade<OnSpark<Gradient<Cylon<Red,5,20,Red,30,20,1>,GhostWhite,Cylon<Red,5,20,Red,5,20,1>>>,White>,300,800>>(), "Cylonwhite"},
   { "SmthGrey;common", "tracks/mercury.wav",
    StylePtr<InOutHelper<EasyBlade<OnSpark<GhostWhite,Black>,White>,300,800>>(),
    StylePtr<InOutHelper<EasyBlade<OnSpark<GhostWhite,Black>,White>,300,800>>(),"white1"},
   { "SmthJedi;common", "tracks/venus.wav",
    StylePtr<InOutHelper<EasyBlade<OnSpark<InOutTr<Azure,TrColorCycle<3000>,TrFade<500>,Green>>,White>,300,800>>(),
    StylePtr<InOutHelper<EasyBlade<OnSpark<InOutTr<Azure,TrColorCycle<3000>,TrFade<500>,Green>>,White>,300,800>>(), "greenflash"},
   { "Spectral;common", "tracks/venus.wav",
    StylePtr<InOutHelper<EasyBlade<OnSpark<InOutTr<Azure,TrColorCycle<3000>,TrFade<500>,Green>>,White>,300,800>>(), "Spectral"},
   { "TeensySF;common", "tracks/mars.wav",
    StylePtr<InOutHelper<EasyBlade<Stripes<1000,1000,Cyan,Magenta,Yellow,Blue>,White>,300,800>>(),
    StylePtr<InOutHelper<EasyBlade<Stripes<1000,1000,Cyan,Magenta,Yellow,Blue>,White>,300,800>>(), "rainbow"},
   { "TeenysSF;common", "tracks/mars.wav",
    StylePtr<InOutHelper<EasyBlade<OnSpark<HumpFlicker<Green,Magenta,50>>,White>,300,800>>(),
    StylePtr<InOutHelper<EasyBlade<OnSpark<HumpFlicker<Green,Magenta,50>>,White>,300,800>>(), "EE"},
   { "TthCrstl;common", "tracks/venus.wav",
    StylePtr<InOutHelper<EasyBlade<OnSpark<Sparkle<HotPink,Yellow>>,GreenYellow>,300,800>>(),
    StylePtr<InOutHelper<EasyBlade<OnSpark<Sparkle<HotPink,Yellow>>,GreenYellow>,300,800>>(), "PINK"},
   { "Vader;common", "tracks/mars.wav",
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Red,White>,AudioFlicker<Red,White>>,White>,400,800>>(), "chunRed"},
   { "Windu;common", "tracks/uranus.wav",
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Magenta,White>,AudioFlicker<Blue,White>>,White>,300,800>>(),
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Magenta,White>,AudioFlicker<Blue,White>>,White>,300,800>>(), "chunzise"},
   { "Vortex;common", "tracks/uranus.wav",
    StylePtr<Layers<StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<255,0,0>>,Black,20>,RotateColorsX<Variation,Rgb<4,0,8>>,
    BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<115,15,220>>,70>,RotateColorsX<Variation,Rgb<42,0,105>>>,RotateColorsX<Variation,Rgb<30,0,66>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,
    FireConfig<2,3000,0>,FireConfig<2,3000,0>>,AlphaL<Stripes<2500,-3000,Red,Rgb<60,0,0>,Pulsing<Rgb<30,0,0>,Black,800>>,SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,
    Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,
    Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrJoinR<TrWipe<100>,TrWipeIn<100>>,White,TrJoinR<TrWipe<100>,TrWipeIn<100>>>,
    SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,
    HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,SparkleL<White,100,400>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,
    ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
    TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<White>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<White,40>,TrFade<1000>>,
    EFFECT_RETRACTION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,
    SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrConcat<TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<400>,Int<300>,Int<400>,Int<32768>>,
    Mix<SmoothStep<Int<5500>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<350>,Int<300>,Int<350>,Int<32768>>,Mix<SmoothStep<Int<11000>,Int<-2000>>,
    Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<300>,Int<300>,Int<300>,Int<32768>>,Mix<SmoothStep<Int<16500>,Int<-2000>>,
    Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<250>,Int<300>,Int<250>,Int<32768>>,Mix<SmoothStep<Int<22000>,Int<-2000>>,
    Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<200>,Int<300>,Int<200>,Int<32768>>,Mix<SmoothStep<Int<27500>,Int<-2000>>,
    Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWipeIn<200>,Mix<SmoothStep<Int<33000>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrFade<300>>,
    TrConcat<TrWipe<200>,Mix<SmoothStep<Int<27500>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<200>,Int<300>,Int<200>,Int<0>>,
    Mix<SmoothStep<Int<22000>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<250>,Int<300>,Int<250>,Int<0>>,
    Mix<SmoothStep<Int<16500>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<300>,Int<300>,Int<300>,Int<0>>,
    Mix<SmoothStep<Int<11000>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<350>,Int<300>,Int<350>,Int<0>>,
    Mix<SmoothStep<Int<5500>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<400>,Int<300>,Int<400>,Int<0>>,Black,
    TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<400>,Int<300>,Int<400>,Int<0>>,Black,TrInstant>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,Bump<Int<0>,Int<10000>>>,TrFade<3000>,
    AlphaL<Orange,Bump<Int<0>,Int<8000>>>,TrFade<3000>,AlphaL<Red,Bump<Int<0>,Int<6000>>>,TrFade<2000>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrFade<2000>,
    AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<255,0,0>>,10>,Bump<Int<0>,Int<4000>>>,TrFade<2950>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<255,0,0>>,15>,Bump<Int<0>,Int<5000>>>,TrFade<3000>,
    AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<255,0,0>>,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>>>(),
    AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<255,0,0>>,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>>>(),"tsb"},
 { 0, WS281XBladePtr<128, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
    WS281XBladePtr<30, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4, bladePowerPin5> >()
  , CONFIGARRAY(presets) },
Arduino did not give any errors when I verified the config before uploading to the board.
So I have the the board connected and Arduino serial monitor open. How do I use it?
Got it fixed. Thanks for the help!
Great! So what was it, and how’d you fix it?
