I’m having trouble with a NeoPixel install with Shtock V3 adapters (I’ve configured them in V4). I want to handle the connector as a different blade. I also wanted to put Blade detect. What I don’t quite undestand, is if I have to add a 470R resistor to Data2 (for the hilt NeoPixels), and if I have to put any resistor on Data 3 for Blade Present. I put neither. If I do need, I will put them and do some further testing.
Blade Detect does not need a resistor.
The hilt connector has a 330R resistor on the data line for the hilt NPXL. Is that enough, or should I add another 470R resistor on the Data2?
That is enough.
