title mostly says it all like the title says the lightsaber only flashes red for like a second but then goes back to blue but everything else seems to work fine i can always hear the darth vader breathing when it flashes red so idk why it doesn’t stay red any help would be appreciated thx in advance
OK, at the beginning you might have what is called a “pre-on”, a sound and light animation combo that happens before the saber settles into it’s normal blade style and hum.
EDIT: could also just be your “ignition”, which can be changed too
Since Tano and Anakin (not quite Vader mostly) are duel-mates, maybe the idea is a flash of Vader before it settles back into Anakin.
You could use color change to get the blade to be red when it’s full on. Or you can change the blade style and reprogram.
If you like you can post the style from your config file here and we can take a look ![]()
around the 2:45 mark is what its supposed to do but it only flashes red and u can hear vader breathing but it doesnt stay red
It looks like you have three choices there: a light side, a dark side, and an alt font set up that let’s you switch with a special ability.
Did you use the included blade style? Do you want to be able to switch back and forth, or are you keeping the dark and light sides separate?
Maybe an error snuck in to your blade style code. The video implies is an OS7 alt font style, which is not too hard to set up in Fett263’s library.
Post the style/config file for better help.
bladestyle.txt (7.6 KB)
config.ini (2.3 KB)
I’m trying to be able to switch between both light and dark and go back and forth between the 2 seamlessly
This is a Multi-Phase (Special Ability) style from my library using Alt Font. Start off by watching the Recommended videos at the top of the library , they cover how to select and then set up. Then read the Style Information provided by the library at the top of the code, it will include the necessary font set up information to support the style. For Special Ability styles and Alt Fonts, the style code expects the font to be set up a specific way, if it’s not it will not run.
hey sorry where can i find the videos in question and the style information? sorry for the stupid question but todays my first day off in 9 days after working between 60 - 80 hours and im tired af so If i could just trouble u with a direct link to both and I can go from there that would be greatly appreciated and if i have any more questions ill reach out afterwards thanks again
There are multiple Recommended videos at the top of the library that explain all of the new features and set up.
https://www.fett263.com/fett263-proffieOS7-style-library.html
When you generate the style code from the library the top section of the provided code will also include all information on options selected, any required set up and usage of the style you’ve built (this is covered in those videos, so start with them)
