In file included from E:\Proffie V2.2\ProffieOS\ProffieOS.ino:563:
E:\Proffie V2.2\ProffieOS\config\Dooku_config.h:67:2: error: expected '}' before ';' token
67 | };
E:\Proffie V2.2\ProffieOS\config\Dooku_config.h:60:4: note: to match this '{'
60 | { "Bank09;common", "tracks/Ashoka.wav",
67 | };
E:\Proffie V2.2\ProffieOS\config\Dooku_config.h:57:4: note: to match this '{'
57 | { "Bank08;common", "tracks/Supreme_Leader_Kylo.wav",
67 | };
E:\Proffie V2.2\ProffieOS\config\Dooku_config.h:54:4: note: to match this '{'
54 | { "Bank07;common", "tracks/LvsV.wav",
67 | };
E:\Proffie V2.2\ProffieOS\config\Dooku_config.h:51:4: note: to match this '{'
51 | { "Bank06;common", "tracks/SithStalker.wav",
67 | };
E:\Proffie V2.2\ProffieOS\config\Dooku_config.h:48:4: note: to match this '{'
48 | { "Bank05;common", "tracks/Trilla.wav",
67 | };
E:\Proffie V2.2\ProffieOS\config\Dooku_config.h:45:4: note: to match this '{'
45 | { "Bank04;common", "tracks/CrimsonMenace.wav",
67 | };
E:\Proffie V2.2\ProffieOS\config\Dooku_config.h:42:4: note: to match this '{'
42 | { "Bank03;common", "tracks/AnakinVSObi.wav",
67 | };
E:\Proffie V2.2\ProffieOS\config\Dooku_config.h:39:4: note: to match this '{'
39 | { "Bank02;common", "tracks/HelpUs.wav",
67 | };
E:\Proffie V2.2\ProffieOS\config\Dooku_config.h:36:4: note: to match this '{'
36 | { "Bank01;common", "tracks/Track1_Short.wav",
67 | };
E:\Proffie V2.2\ProffieOS\config\Dooku_config.h:35:20: note: to match this '{'
35 | Preset presets[] = {
E:\Proffie V2.2\ProffieOS\config\Dooku_config.h:67:2: error: cannot convert '<brace-enclosed initializer list>' to 'const char*' in initialization
67 | };
Compilation error: expected '}' before ';' token
We would need to see your config file to tell you what the problem is.
#ifdef CONFIG_TOP#include "proffieboard_v2_config.h"#define NUM_BLADES 1#d - Pastebin.com Right here. There is just too much to learn from 0 to 100 and its just too much information and overwhelming, could really use some help from the expert, thanks.
You are missing a closing bracket and comma “},” to close each preset.
The syntax for a preset is:
StylePtr<...>(),
"name"
So you need to close each of your presets to fix the error.
Thanks i’ll try that. Appreciate the help.
