My saber is not having smooth swing or motion
my saber is not playing the swing sounds and gestures are not working
Gonna need a lot more information.
I’d start with the SD card, as lag and sound issues can be from a subpar or corrupt SD.
ProffieOS7/8 requires SD card performance to be 1200kbps read speed with 12 simultanenous audio streams. Subpar or poor performing SD cards will cause the saber to lag or freeze.
If you experience lag or slow response you need to run ‘sdtest’ in Serial Monitor. Even if SD is labeled as high performance you should run sdtest to be sure.
  • First, remove DISABLE_DIAGNOSTIC_COMMANDS define from your config.
  • Upload new config (you may temporarily need to remove some presets if exceeding FLASH memory)
  • With saber connected go to Arduino > Tools > Serial Monitor
  • Type ‘sdtest’
  • If you do not have 1200kbps read speed and 12 simulatenous audio streams you will want to replace your SD with a better performing card.
You can also improve SD performance via formatting and file structure, also be sure to ALWAYS ‘Eject’ the SD card anytime it’s mounted to your computer to prevent file corruption.
It could also be a bad configuration, or a bad board.
As Fett263 said: Need more information.
I2C init..
Motion chip … 105 found.
EVENT: Clash millis=1179
EVENT: TwistLeft millis=1241
EVENT MENU TURN LEFT
Unmounting SD Card.
Amplifier off.
Booster off.
EVENT: TwistLeft millis=16034
Battery voltage: 4.07
Battery voltaWelcome to ProffieOS v8.10
SD card is busy, flags= scsi medium
Playing TeensySF/swingh/swingh01.wav
Failed to open!
Playing TeensySF/swingh/swingh02.wav
Failed to open!
Playing TeensySF/swingh/swingh03.wav
Failed to open!
Playing TeensySF/swingh/swingh04.wav
Failed to open!
Playing TeensySF/swingh/swingh05.wav
Failed to open!
Playing TeensySF/swingh/swingh06.wav
Failed to open!
Playing TeensySF/swingh/swingh07.wav
Failed to open!
Playing TeensySF/swingl/swingl01.wav
Failed to open!
Playing TeensySF/swingl/swingl02.wav
Failed to open!
Playing TeensySF/swingl/swingl03.wav
Failed to open!
Playing TeensySF/swingl/swingl04.wav
Failed to open!
Playing TeensySF/swingl/swingl05.wav
Failed to open!
Playing TeensySF/swingl/swingl06.wav
Failed to open!
Playing TeensySF/swingl/swingl07.wav
Failed to open!
Playing TeensySF/swng/swng01.wav
Failed to open!
Playing TeensySF/swng/swng02.wav
Failed to open!
Playing TeensySF/swng/swng03.wav
Failed to open!
Playing TeensySF/swng/swng04.wav
Failed to open!
Playing TeensySF/swng/swng05.wav
Failed to open!
Playing TeensySF/swng/swng06.wav
Failed to open!
Playing TeensySF/swng/swng07.wav
Failed to open!
Playing TeensySF/swng/swng08.wav
Failed to open!
Playing TeensySF/swng/swng09.wav
Failed to open!
Playing TeensySF/swng/swng10.wav
Failed to open!
Playing TeensySF/swng/swng11.wav
Failed to open!
Playing TeensySF/swng/swng12.wav
Failed to open!
Playing TeensySF/swng/swng13.wav
Failed to open!
Playing TeensySF/swng/swng14.wav
Failed to open!
Playing TeensySF/swng/swng15.wav
Failed to open!
Playing TeensySF/swng/swng16.wav
Failed to open!
Playing TeensySF/lock.wav
Failed to open!
Playing TeensySF/out/out01.wav
Failed to open!
Playing TeensySF/out/out02.wav
Failed to open!
Playing TeensySF/out/out03.wav
Failed to open!
Playing TeensySF/out/out04.wav
Failed to open!
Playing TeensySF/out/out05.wav
Failed to open!
Playing TeensySF/in/0001.wav
Failed to open!
Playing TeensySF/in/0002.wav
Failed to open!
Playing TeensySF/clsh/clsh01.wav
Failed to open!
Playing TeensySF/clsh/clsh02.wav
Failed to open!
Playing TeensySF/clsh/clsh03.wav
Failed to open!
Playing TeensySF/clsh/clsh04.wav
Failed to open!
Playing TeensySF/clsh/clsh05.wav
Failed to open!
Playing TeensySF/clsh/clsh06.wav
Failed to open!
Playing TeensySF/clsh/clsh07.wav
Failed to open!
Playing TeensySF/clsh/clsh08.wav
Failed to open!
Playing TeensySF/clsh/clsh09.wav
Failed to open!
Playing TeensySF/clsh/clsh10.wav
Failed to open!
Playing TeensySF/clsh/clsh11.wav
Failed to open!
Playing TeensySF/clsh/clsh12.wav
Failed to open!
Playing TeensySF/clsh/clsh13.wav
Failed to open!
Playing TeensySF/clsh/clsh14.wav
Failed to open!
Playing TeensySF/clsh/clsh15.wav
Failed to open!
Playing TeensySF/clsh/clsh16.wav
Failed to open!
Playing TeensySF/blst/blst01.wav
Failed to open!
Playing TeensySF/blst/blst02.wav
Failed to open!
Playing TeensySF/blst/blst03.wav
Failed to open!
Playing TeensySF/blst/blst04.wav
Failed to open!
Playing TeensySF/force.wav
Failed to open!
Playing TeensySF/hum.wav
Failed to open!
Playing TeensySF/font.wav
Failed to open!
Playing TeensySF/boot.wav
Failed to open!
Time to open files: Average time: 13.95 us
x100us 1 2 3 4 5
0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0
Time to read blocks: Average speed: 0.00 kb/s, 0.00 simultaneous audio streams.
x100us 1 2 3 4 5
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Time to open files: Average time: 41.21 us
x100us 1 2 3 4 5
x100us 1 2 3 4 5
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Failed to open!
Time to open files: Average time: 19.32 us
x100us 1 2 3 4 5
x100us 1 2 3 4 5
Hi welcome to forum.
So that it is easier to read please select the Preformatted text icon </>
This will ensure that it is windowed and can be scrolled within a small note.
As a example.
Testing preformat
Ir seems like something is wrong with the SD card or files. Backup your fonts, reformat your SD and put the files back and see if that fixes. Otherwise you may need a new SD.
