My first install!
I’m pretty excited. Here is my first proffie install. Also the first chassis design I did.
I designed it, printed it, wired it up, and on first power up, everything worked! I couldn’t believe it! No issues! Granted it is a fairly simple install with just one hilt pcb, but that’s all I wanted out of it. I learned some things for sure to implement going forward in chassis design.
I have a few things to button up, but its great! Now I need to figure out how to change setting on a 1 button hilt. lol.
Just wanted to share! I have a lot of other designs started, and this sure gave me a boost to get them done. Thanks to everyone here for the continued help to not just me, but any and everyone!
Congrats! You’ve taken your first step into a larger world.
Looks awesome man! Nice and clean, you should be incredibly proud, especially for a first install! :slight_smile:
Thanks! It was fun. Now I need to start a help thread. I cannot figure out how to change fonts.
No problem. Start it up with your config. Which prop are you using?
saber_fett263_buttons
I think I figured it out after reading that. triple click and hold for 1 sec on 4th click.
Kinda cumbersome, but worked. If i accidentally changed a preset (it said some thing as I messed with the button combos), does it reset after power off? I don’t even know what may have changed.
It depends on your defines. I usually use SAVE_STATE which saves the preset I was on, as well as a few other things listed here:
Ah, thank you.
Looks like mine does nothing then!
#define NUM_BUTTONS 1
#define VOLUME 1500
const unsigned int maxLedsPerStrip = 128;
#define CLASH_THRESHOLD_G 4.5
#define ENABLE_SERIAL
#define FETT263_MULTI_PHASE
#define FETT263_TWIST_ON
#define FETT263_STAB_ON_NO_BM
#define FETT263_SWING_OFF
#define FETT263_THRUST_ON
#define FETT263_THRUST_OFF
// #define ENABLE_SSD1306
// // Max 20 characters
// #define BLE_PASSWORD "your password"
// // Max 32 characters.
// #define BLE_NAME "Your Saber Name"
// // Max 9 characters
// #define BLE_SHORTNAME "Saber"
#define MOTION_TIMEOUT 60 * 3 * 800
   { "ESB_Graflex_v2;common", "tracks/venus.wav",
    StylePtr<Layers<RandomFlicker<Stripes<10000,-2600,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(), "esb"},
   { "luke;common", "tracks/venus.wav",
    StylePtr<InOutHelper<OnSpark<Blast<LocalizedClash<Lockup<AudioFlicker<Green,Rgb16<0,38402,0>>,Pulsing<Gradient<AudioFlicker<Green,Rgb16<0,38402,0>>,AudioFlicker<Green,Rgb16<0,38402,0>>,HumpFlicker<OrangeRed,Pink,50>,AudioFlicker<Green,Rgb16<0,38402,0>>,AudioFlicker<Green,Rgb16<0,38402,0>>>,Gradient<AudioFlicker<Green,Rgb16<0,38402,0>>,AudioFlicker<Green,Rgb16<0,38402,0>>,HumpFlicker<OrangeRed,Pink,50>,AudioFlicker<Green,Rgb16<0,38402,0>>,AudioFlicker<Green,Rgb16<0,38402,0>>,AudioFlicker<Green,Rgb16<0,38402,0>>>,3500>,Gradient<AudioFlicker<Cyan,DeepSkyBlue>,AudioFlicker<Cyan,DeepSkyBlue>,HumpFlicker<Pink,OrangeRed,50>>>,Pink>,Pink>,Pink,400>,200,500>>(), "luke"},
   { "Graflex3;common", "tracks/mars.wav",
    StylePtr<InOutHelper<OnSpark<Blast<LocalizedClash<Lockup<AudioFlicker<Blue,DodgerBlue>,Pulsing<Gradient<AudioFlicker<Blue,DodgerBlue>,AudioFlicker<Blue,DodgerBlue>,HumpFlicker<OrangeRed,Pink,50>,AudioFlicker<Blue,DodgerBlue>,AudioFlicker<Blue,DodgerBlue>>,Gradient<AudioFlicker<Blue,DodgerBlue>,AudioFlicker<Blue,DodgerBlue>,HumpFlicker<OrangeRed,Pink,50>,AudioFlicker<Blue,DodgerBlue>,AudioFlicker<Blue,DodgerBlue>,AudioFlicker<Blue,DodgerBlue>>,3500>,Gradient<AudioFlicker<Blue,DodgerBlue>,AudioFlicker<Blue,DodgerBlue>,HumpFlicker<Pink,OrangeRed,50>>>,Pink>,Pink>,Pink,400>,200,500>>(),  "G3"},
   { "Graflex4;common", "tracks/mars.wav",
    StylePtr<InOutHelper<OnSpark<Blast<LocalizedClash<Lockup<AudioFlicker<Green,Rgb16<0,38402,0>>,Pulsing<Gradient<AudioFlicker<Green,Rgb16<0,38402,0>>,AudioFlicker<Green,Rgb16<0,38402,0>>,HumpFlicker<OrangeRed,Pink,50>,AudioFlicker<Green,Rgb16<0,38402,0>>,AudioFlicker<Green,Rgb16<0,38402,0>>>,Gradient<AudioFlicker<Green,Rgb16<0,38402,0>>,AudioFlicker<Green,Rgb16<0,38402,0>>,HumpFlicker<OrangeRed,Pink,50>,AudioFlicker<Green,Rgb16<0,38402,0>>,AudioFlicker<Green,Rgb16<0,38402,0>>,AudioFlicker<Green,Rgb16<0,38402,0>>>,3500>,Gradient<AudioFlicker<Cyan,DeepSkyBlue>,AudioFlicker<Cyan,DeepSkyBlue>,HumpFlicker<Pink,OrangeRed,50>>>,Pink>,Pink>,Pink,400>,200,500>>(), "G4"},
   { "Graflex8;common", "tracks/venus.wav",
    StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,Blue>,Pulsing<RotateColorsX<Variation,Rgb<0,0,90>>,RotateColorsX<Variation,Blue>,800>,RotateColorsX<Variation,Blue>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,160>>>,TrDelay<30000>,RotateColorsX<Variation,Blue>,TrFade<800>>,EFFECT_FORCE>,AlphaL<StrobeL<Black,Int<20>,Int<1>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(), "G8"},
   { "BLAN;common", "tracks/venus.wav",
    StylePtr<InOutHelper<RandomPerLEDFlicker<Pulsing<Blue,InOutHelper<White,300,800>,800>,Blue>,300,800>>(), "BLUEFLASH"},
   { "SpongeBob;common", "tracks/mars.wav",
    StylePtr<Layers<
  StripesX<Scale<IsLessThan<BladeAngle<>,Int<16384>>,Scale<BladeAngle<>,Int<20000>,Int<10000>>,Scale<BladeAngle<>,Int<10000>,Int<20000>>>,Scale<BladeAngle<>,Int<-1000>,Scale<IsGreaterThan<HoldPeakF<SwingAcceleration<>,Scale<HoldPeakF<SwingAcceleration<>,Int<200>,Int<4000>>,Int<100>,Int<600>>,Scale<BladeAngle<>,Int<3000>,Int<6000>>>,Int<16384>>,Int<1000>,Int<-1000>>>,StripesX<Int<1500>,Scale<SlowNoise<Int<2500>>,Int<-3000>,Int<-5000>>,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>,Mix<Int<2570>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,Mix<Int<16384>,Black,StaticFire<BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,DeepSkyBlue>,RandomPerLEDFlicker<Mix<Int<3213>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>>,300>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,0,6,10,1000,2>>,Mix<Int<10280>,Black,StripesX<Int<1500>,Scale<SlowNoise<Int<2500>>,Int<-3000>,Int<-5000>>,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>,Mix<Int<2570>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>>,Mix<Int<25700>,Black,StaticFire<BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,DeepSkyBlue>,RandomPerLEDFlicker<Mix<Int<3213>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>>,300>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,0,6,10,1000,2>>,Mix<Int<7710>,Black,StripesX<Int<1500>,Scale<SlowNoise<Int<2500>>,Int<-3000>,Int<-5000>>,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>,Mix<Int<2570>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>>>,
  AlphaL<StaticFire<Stripes<12000,-2000,RgbArg<SWING_COLOR_ARG,Rgb<100,100,150>>,RotateColorsX<Int<200>,RgbArg<SWING_COLOR_ARG,Rgb<100,100,150>>>>,Mix<Int<16384>,Black,RgbArg<SWING_COLOR_ARG,Rgb<100,100,150>>>,0,3,2,2000,8>,SmoothStep<Scale<HoldPeakF<Ifon<Scale<IsGreaterThan<SwingSpeed<500>,Int<16000>>,Int<2000>,SwingSpeed<300>>,Int<0>>,Scale<SwingAcceleration<>,Int<100>,Int<600>>,Scale<SwingAcceleration<>,Int<10000>,Int<4000>>>,Int<1000>,Int<40000>>,Int<-4000>>>,
  ColorSelect<IncrementWithReset<EffectPulseF<EFFECT_FORCE>,ThresholdPulseF<IncrementWithReset<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_STAB>>,EffectPulseF<EFFECT_FORCE>,Int<32768>,Scale<ClashImpactF<>,Int<3000>,Int<14000>>>,Int<32600>>,Int<1>>,TrSmoothFadeX<Int<2000>>,AlphaL<RgbArg<BASE_COLOR_ARG,DeepSkyBlue>,Int<0>>,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,
  ColorSelect<IncrementWithReset<EffectPulseF<EFFECT_FORCE>,ThresholdPulseF<IncrementWithReset<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_STAB>>,EffectPulseF<EFFECT_FORCE>,Int<32768>,Scale<ClashImpactF<>,Int<3000>,Int<14000>>>,Int<32600>>,Int<1>>,TrSelect<IncrementWithReset<EffectPulseF<EFFECT_FORCE>,Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_STAB>>,Int<1>>,TrSmoothFadeX<Int<3000>>,TrWipeSparkTipX<BrownNoiseFlicker<RgbArg<SWING_COLOR_ARG,Rgb<100,100,150>>,White,200>,WavLen<EFFECT_FORCE>>>,AlphaL<RgbArg<BASE_COLOR_ARG,DeepSkyBlue>,Int<0>>,StyleFire<StripesX<Int<3000>,Scale<TwistAngle<>,Int<-500>,Int<0>>,Red,Orange,Yellow,Green,Blue,Magenta>,StripesX<Int<3000>,Scale<TwistAngle<>,Int<-500>,Int<0>>,Tomato,OrangeRed,Orange,Yellow,SteelBlue,DeepPink>,0,3,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>>,
  TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<100,100,150>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<100,100,150>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<100,100,150>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<100,100,150>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<100,100,150>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<100,100,150>>>>>,TrFade<800>>,EFFECT_IGNITION>,
  TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<>>,TrInstant>,Stripes<3000,-3500,RgbArg<RETRACTION_COLOR_ARG,Rgb<100,100,150>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<100,100,150>>>,Black>,BrownNoiseFlicker<RgbArg<RETRACTION_COLOR_ARG,Rgb<100,100,150>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<100,100,150>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<100,100,150>>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<100,100,150>>>>>,TrFade<800>>,EFFECT_RETRACTION>,
  SparkleL<Magenta,50>,
  SparkleL<Blue,50>,
  SparkleL<Yellow,50>,
  SparkleL<Green,50>,
  SparkleL<DarkOrange,50>,
  TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,White>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,
  LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,White>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>,RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,White>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,White>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
  LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,White>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,White>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
  LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
  InOutTrL<TrWipeX<IgnitionTime<0>>,TrWipeX<RetractionTime<>>>,
  TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RgbArg<POSTOFF_COLOR_ARG,Rgb<100,100,150>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,IntArg<EMITTER_SIZE_ARG,2000>,Sum<IntArg<EMITTER_SIZE_ARG,2000>,Int<3000>>>,Int<-4000>>>,TrDelayX<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>>>,EFFECT_POSTOFF>>>(), "KK"},
 { 0,
    WS281XBladePtr<128, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
    CONFIGARRAY(presets) },
I don’t have any defined. I suppose “saber_fett263_buttons” defines the button combo for it, and the sound files exist, but it must not be doing anything.
#define FETT263_SWING_OFF and #define FETT263_THRUST_OFF are not real defines, are they? It would make your saber turn on an off a lot. Like enough to make it not work so great.
The controls are all listed if you open the saber_fett263_buttons.h file in a text editor like Sublime Text
It’s not a CFX :grinning: which splits things into “font selection” “spectrum” and “blade profiles”.
I think you want to change presets.
There are on and off controls. For example, a 1 button set up while the saber is OFF
Next Preset = Long Click PWR (parallel or up)
  NEW Control! Previous Preset = Long Click PWR (pointing down)
  NEW! Scroll Presets (using twist menu) = Hold PWR
    Turn Right (Stepped) = Next Preset
      Increment by 5 = Hold PWR + Turn Right
    Turn Left (Stepped) = Previous Preset
      Increment by 5 = Hold PWR + Turn Left
    Click PWR = Select Preset
    NEW! Hold PWR = Select and Ignite Preset
    Long Click PWR = First Preset
Thanks LyleStyle. I use notepadd++ to read and edit h files.
I’m not sure I even know what a preset is or is for? When I change fonts, it changes sound and color, am I missing something?
This particular file started from a successful mod I made to an 89Sabers install that I got working. So, I don’t really know what they were/are doing.
I think I will start a new thread about how to improve this one.
Presets are what you cycle through, what you are calling “fonts”.
A font is just the sounds. A preset is the combination of which sound font, music track (if desired) and blade style.
A super simple preset for a 1 blade saber could look something like this (using placeholder names)
{ "font_name;common", "tracks/track1.wav",
StyplePtr<Red>(),
"my red preset" }
You’ll see them in your config file one after another.
So to “change fonts” is a conflation of terms. What you are doing is changing presets by doing a “next” or “previous” preset button event…
“Changing a font” would be swapping out the sound font assigned to that preset for a different one.
The controls are all listed in the top section of the prop files.
I highly suggest trying a text editor better suited for code other than Notepad++.
Sublime Text, if for no other reason, makes it much easier to read because of the color scheme. It also allows for a multitude of other editing aids, but at minimum the readability once setting the document type to C++ is far superior.
Makes sense?
Yes, I see now. I was mixing the terms. That also means I have been using the saber wrong as well
Yes, i think so. Notepad++ does language highlights as well, but sublime does look better. Looks more like visual studio.
Yes, so if you used fett263 prop and did “change fonts” , that means “on the currently selected preset, choose a new sound font to use for it”.
If you saved that, it’s now written to a saved file on the SD card named presets.ini (and presets.tmp)
So to go back to what you uploaded easily, you can either
  1. Delete the save files from the SD card.
  2. Re-upload, making sure you don’t have
    #define KEEP_SAVE_FILES_WHEN_PROGRAMMING active in your config.
