Music playing when selecting fonts that use the special ability of proffie OS7
Its not really a big deal, I just dunno how it happened or why
I made 3 blade styles that use the special ability feature, all of them use multi phase and I have them change lightsaber color and sound when phase changing
in these fonts, whenever they are selected a little music plays along with the font sound
for example, when the anakin sound font is selected ashoka says “anakin” and in the background at the same time there is a cute little music playing
Connect to Serial Monitor and see what’s playing. That will help determine which sound you’re hearing.
Arduino > Tools > Serial Monitor
oh I didn’t know about this, this is amazingly useful, based on my output, I did something wrong with the alt folders and files, but I still missed why the music plays
Scanning sound font: AnakinAhsokaDark done
Scanning sound font: common done
WARNING: This font seems to be missing some files!!
Found out files: 1-4 in subdirs SOME FILES ARE MISSING! 8 != 12 in AnakinAhsokaDark
Found in files: 1-2 in subdirs SOME FILES ARE MISSING! 4 != 6 in AnakinAhsokaDark
Found hum files: one unnumbered file SOME FILES ARE MISSING! 2 != 3 in AnakinAhsokaDark
Activating polyphonic font.
Activating SmoothSwing V2
Accent Swings Enabled.
Polyphonic swings: 16
Monophonic swings: 0
Accent Slashes NOT Detected:
DISPLAY: AnakinAhsokaDark
unit = 0 vol = 0.50, Playing AnakinAhsokaDark/font.wav
Amplifier off.
Unmounting SD Card.
Battery voltage: 0.34
Booster off.
Battery voltage: 0.27
Remove DISABLE_DIAGNOSTIC_COMMANDS define, upload, then go back into Serial Monitor and type ‘effects’, it will show you what is causing errors.
Then see what sound file plays when you hear this “music” so we can determine what it is.
Are you sure it’s not just the font.wav with the spoken line “Anakin” that has music in the background of it?
Did you listen to the sounds on your computer?
yeah, Im sure, it also plays on another soundfont and when I switch fonts the musics keeps on playing even tho I switch the font already
Sorry for the long break but I figured it out, following Fett’s orientation I realized my alt folders were poorly organized, lots of files miss matches, after watching his multi-phase yt again and following it more carefully I realized my mistake. After fixing the folders the little music is gone, I still don’t really know where it comes from, but if you don’t mess up the alt folders, you won’t have issues
ty everyone for the help, hope you guys have a wonderful week
You’re welcome, glad to hear.
