If you have multiple preon, in, out, etc files in a sound font does that mean each time you activate the saber it will randomly choose one of those .wav files to play?
Does preon1 have a higher chance of being played than preon2? Or is it completely random? Thanks
By default they are all randomly selected.
If you want a level of control my prop allows for odd/even selection via #define FETT263_DUAL_MODE_SOUND
Info here:
For OS7 there is also “pairing” available for certain sounds available via the font’s config.ini, this would still randomly select but the preon and out would both be the same random numbered file if there are equal numbers of files.
Thanks!
Looks like I’m going down another rabbit hole to setup my perfect config
