Hello. I did search, and I’ll bet the answer is there, but I couldn’t find it. I had multi-blast mode working fine in my OS6 saber, but I can’t seem to trigger it in OS7. I’m guessing I have something wrong in my CONFIG_TOP. I’ve included it here. I don’t want Battle Mode with this saber. I would be ok triggering it from special abilities, but none of those mention multi-blast mode. Thank you for your help.
#define NUM_BLADES 3
#define EXTRA_COLOR_BUFFER_SPACE 30
#define VOLUME 2300
//#define BOOT_VOLUME 2300
#define CLASH_THRESHOLD_G 1.5
#define ENABLE_SPINS
#define FILTER_CUTOFF_FREQUENCY 80
#define FILTER_ORDER 8
#define SHARED_POWER_PINS
#define FETT263_MAX_CLASH 16
#define FETT263_SAY_BATTERY_VOLTS
//#define FETT263_QUOTE_PLAYER_START_ON
//#define FETT263_DISABLE_MULTI_BLAST_TOGGLE
#define FETT263_DISABLE_QUOTE_PLAYER
#define FETT263_RANDOMIZE_QUOTE_PLAYER
