Hi everyone,
I am using the fett263 configurator page and I’m noticing that the post off extends beyond the emitter and would like to have the preon glitching resized so that its contained within the the emitter.
StylePtr<Layers<Mix<IsLessThan<TwistAngle<1>,Int<16384>>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<42,0,105>>,RotateColorsX<Variation,Rgb<21,0,52>>>,300>,RotateColorsX<Variation,Rgb<10,0,26>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,Stripes<5000,-1500,RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<60,17,0>>,RotateColorsX<Variation,Rgb<255,140,40>>,RotateColorsX<Variation,Rgb<128,34,0>>>>,TransitionEffectL<TrConcat<TrFade<400>,AudioFlickerL<RotateColorsX<Variation,Rgb<160,60,255>>>,TrDelay<30000>,AudioFlickerL<RotateColorsX<Variation,Rgb<160,60,255>>>,TrFade<800>>,EFFECT_FORCE>,AlphaL<RandomBlinkL<Int<1000>,Black>,SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,150,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<Moccasin,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<Green,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb<160,60,255>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<21,0,52>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<160,60,255>>,RotateColorsX<Variation,Rgb<21,0,52>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<42,0,105>>,RotateColorsX<Variation,Rgb<21,0,52>>>>,TrFade<1200>>,EFFECT_IGNITION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrConcat<TrWipe<200>,Mix<IsLessThan<TwistAngle<1>,Int<16384>>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<42,0,105>>,RotateColorsX<Variation,Rgb<21,0,52>>>,300>,RotateColorsX<Variation,Rgb<10,0,26>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,Stripes<5000,-1500,RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<60,17,0>>,RotateColorsX<Variation,Rgb<255,140,40>>,RotateColorsX<Variation,Rgb<128,34,0>>>>,TrWipe<100>,Black,TrBoing<300,3>>,TrWipeInX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Int<300>,Int<800>>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,Bump<Int<0>,Int<10000>>>,TrFade<3000>,AlphaL<Orange,Bump<Int<0>,Int<8000>>>,TrFade<3000>,AlphaL<Red,Bump<Int<0>,Int<6000>>>,TrFade<2000>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Int<4000>,Int<-4000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Int<4000>,Int<4000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrFade<2000>,AlphaL<HumpFlickerL<Rgb<120,120,165>,10>,Bump<Int<0>,Int<4000>>>,TrFade<2950>,AlphaL<HumpFlickerL<Rgb<120,120,165>,15>,Bump<Int<0>,Int<5000>>>,TrFade<3000>,AlphaL<HumpFlickerL<Rgb<120,120,165>,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>,AlphaL<Black,Scale<IsLessThan<BatteryLevel,Int<10000>>,Int<0>,Scale<BatteryLevel,Int<16384>,Int<7500>>>>>>()
I believe the I need to adjust the bump sizing I checked the blade length finder and it was 7 length, if I am correct I need to find what 7 is of the full length(128).
so that is 5.4%
so the INT total is 32768
so the inside should 1769 right?
yes, so that worked.
awesome, now I configure the preon and post office just the way I like it.
