I’ve been playing with some pre written styles that came with purchased fonts and am hitting some difficulty cleaning them up (to take less space and removing effects I don’t like)
Is there a way to backwards engineer the huge block of code to explain each line/effect? Like putting the code in a “backwards engineer style editor” and have it populate the options so the user can change effects as they wish with the nice drop down?
Occasionally the style code has been broken down to explain what each line is, but others not.
Is that a function I am missing? The //commented out description, or did the original style designer do that as a courtesy? Yes, the bullet pointed breakdown is up top when using style generator, but not per line.
Secondly, I want to remove something in the style below, but I’m not sure what to change.
It’s a Force Change, which I find incredibly cool and want to use more. OS7 with the sound font change makes me giddy…
I want to remove the “slow fade from deep sky blue to red” after ignition and “slow fade from red to deep sky blue” after ignition. I want the blade to stay the initial ignition color until I tell it to change with Force Effect toggle
See below.
Also if there is something massively overcomplicated that takes up huge code for no good reason, please feel free to edit. I’m trying to streamline. Blaster effects and lockup are not super important, as long as they show up when triggered.
StylePtr<Layers<
//Force effect toggles between Red and Deep Sky Blue. You can still use the color wheel to try out other colors paired together or edit the colors below yourself.
EffectSequence<EFFECT_FORCE,
//Deep Sky Blue
Layers<
//Fett263 Humpflicker
HumpFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,50,120>>,50>,
//Fett263 unstable swing
AlphaL<AudioFlickerL<Stripes<1000,-1500,RandomPerLEDFlicker<RotateColorsX<Variation,Cyan>,Black>,Black,RotateColorsX<Variation,DeepSkyBlue>,Black>>,SwingSpeed<350>>,
//Ripple swing effect using Fett263's scaled responsive swing
AlphaL<AlphaL<Stripes<2000,-2250,RotateColorsX<Variation,Cyan>,RotateColorsX<Variation,Rgb<0,50,40>>,Pulsing<RotateColorsX<Variation,Rgb<0,35,20>>,Black,800>>,HoldPeakF<Scale<IsLessThan<SwingSpeed<850>,Int<13600>>,Scale<SwingSpeed<850>,Int<-19300>,Int<32768>>,Int<0>>,Int<550>,Scale<SwingAcceleration<100>,Int<20000>,Int<10000>>>>,SmoothStep<Scale<Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>,Int<15000>,Int<5000>>,Int<16000>>>,
//Fett263 unstable ignition with slow fade from red to deep sky blue
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-1550,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<3000>,HumpFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>,50>,TrDelay<5000>,HumpFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>,50>,TrFade<5000>>,EFFECT_IGNITION>>,
//Red
Layers<
AlphaL<AudioFlickerL<Stripes<1000,-1500,RandomPerLEDFlicker<RotateColorsX<Variation,DarkOrange>,Black>,Black,RotateColorsX<Variation,Red>,Black>>,SwingSpeed<350>>,
AlphaL<AlphaL<Stripes<2000,-2250,RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<60,30,0>>,Pulsing<RotateColorsX<Variation,Rgb<30,15,0>>,Black,800>>,HoldPeakF<Scale<IsLessThan<SwingSpeed<850>,Int<13600>>,Scale<SwingSpeed<850>,Int<-19300>,Int<32768>>,Int<0>>,Int<550>,Scale<SwingAcceleration<100>,Int<20000>,Int<10000>>>>,SmoothStep<Scale<Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>,Int<15000>,Int<5000>>,Int<16000>>>,
//Fett263 unstable ignition with slow fade from deep sky blue to red
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-1550,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<3000>,HumpFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,50,120>>,50>,TrDelay<5000>,HumpFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,50,120>>,50>,TrFade<5000>>,EFFECT_IGNITION>>>,
//Fett263 unstable force effect with sizzle emitter ending - Toggles the base saber colors between red and blue.
TransitionEffectL<TrConcat<TrInstant,White,TrFade<150>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Magenta>,Black,20>,RotateColorsX<Variation,Rgb<10,0,10>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<255,25,255>>,70>,RotateColorsX<Variation,Rgb<128,0,128>>>,RotateColorsX<Variation,Rgb<80,0,80>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrDelay<1000>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Magenta>,Black,20>,RotateColorsX<Variation,Rgb<10,0,10>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<255,25,255>>,70>,RotateColorsX<Variation,Rgb<128,0,128>>>,RotateColorsX<Variation,Rgb<80,0,80>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrFade<1000>,AlphaL<StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Magenta>,Black,20>,RotateColorsX<Variation,Rgb<10,0,10>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<255,25,255>>,70>,RotateColorsX<Variation,Rgb<128,0,128>>>,RotateColorsX<Variation,Rgb<80,0,80>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,Bump<Int<3500>,Int<23384>>>,TrFade<600>>,EFFECT_FORCE>,
//Fett263 Responsive Intensity Lockup effect with absorb endlock
LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>>,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,White>,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<HumpFlicker<White,Rgb<40,60,60>,50>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>>,TrFade<350>>,SaberBase::LOCKUP_NORMAL>,
//LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>>,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,White>,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>>,SaberBase::LOCKUP_NORMAL>,
//Responsive Stab
//Blast selection based on absorb effect
ColorSelect<WavNum<EFFECT_BLAST>,TrInstant,
//Fett263 Responsive Blast Wave
TransitionEffectL<TrConcat<TrInstant,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,TrDelay<500>>,EFFECT_BLAST>,
//Fett263 Responsive Blast Wave with absorb effect
TransitionEffectL<TrConcat<TrInstant,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,TrFade<500>,AlphaL<HumpFlicker<White,Rgb<40,60,60>,50>,Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>>>,TrFade<350>>,EFFECT_BLAST>>,
//ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,
//OS6 Random Fett263 Responsive Multi-Blast
//ColorSelect<RandomF,TrInstant,ResponsiveBlastL<RgbArg<BLAST_COLOR_ARG,White>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<RgbArg<BLAST_COLOR_ARG,White>,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<RgbArg<BLAST_COLOR_ARG,White>,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<RgbArg<BLAST_COLOR_ARG,White>,200,200>,ResponsiveBlastFadeL<RgbArg<BLAST_COLOR_ARG,White>,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<RgbArg<BLAST_COLOR_ARG,White>,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,
//OS6 Fett263 Random Responsive Blast
//MultiTransitionEffectL<TrRandom<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<28000>,Int<8000>>>,TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<16384>,Int<6000>>>,TrFade<50>,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Int<0>>,TrSparkX<Remap<CenterDistF<EffectPosition<>>,Stripes<2000,-2000,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<2096>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>>,Int<100>,Int<300>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>>,TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<16384>,Int<6000>>>,TrFade<50>,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Int<0>>,TrWaveX<Remap<CenterDistF<EffectPosition<>>,Stripes<1500,-2000,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<2096>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>>,Int<160>,Int<100>,Int<300>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>>,TrConcat<TrInstant,AlphaMixL<Bump<EffectPosition<>,Scale<WavLen<>,Int<9000>,Int<12000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<300>>,TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<000>>,Scale<WavLen<>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<300>>>,EFFECT_BLAST>,
//OS5 Fett263 Multi-Blast, blaster reflect cycles through different responsive effects (I like the look of this one the best even with the new OS6 stuff)
//EffectSequence<EFFECT_BLAST,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<White,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<White,200,200>,ResponsiveBlastFadeL<White,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<White,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,
//Fett263 Real Clash with absorb effect
Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,NavajoWhite>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<300>,Int<200>,Int<940>>>,AlphaL<HumpFlicker<White,Rgb<40,60,60>,50>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>,TrFade<350>>,EFFECT_CLASH>,TransitionEffectL<TrConcat<TrWaveX<RgbArg<CLASH_COLOR_ARG,NavajoWhite>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,AlphaL<HumpFlicker<White,Rgb<40,60,60>,50>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>,TrFade<350>>,EFFECT_CLASH>>,
//Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,
//Fett263 Intensity Drag
//Alternate Responsive Drag
//LockupTrL<AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,White>,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeInX<WavLen<EFFECT_DRAG_BEGIN>>,TrFadeX<WavLen<EFFECT_DRAG_END>>,SaberBase::LOCKUP_DRAG>,
//Fett263 Power Save, if using fett263's prop file hold Aux and click PWR while ON (pointing up) to dim blade in 25% increments.
//Spark tip ignition and cycle down retraction
InOutTrL<TrWipeSparkTip<White,1500>,TrColorCycleX<Int<500>,500>>,
//Force effect toggles between red and deep sky blue
//Deep sky blue glowing emitter retraction with fizzle out post off
TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RotateColorsX<Variation,DeepSkyBlue>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<1500>>,Int<2000>,Int<4500>>,Int<-4000>>>,TrDelayX<WavLen<EFFECT_RETRACTION>>,Black,TrDelay<897>,AlphaL<RandomPerLEDFlicker<RotateColorsX<Variation,DeepSkyBlue>,Black>,Bump<Int<10500>,Int<11500>>>,TrDelay<150>>,EFFECT_RETRACTION>,
//Red glowing emitter retraction with fizzle out post off
TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RotateColorsX<Variation,Red>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<1500>>,Int<2000>,Int<4500>>,Int<-4000>>>,TrDelayX<WavLen<EFFECT_RETRACTION>>,Black,TrDelay<897>,AlphaL<RandomPerLEDFlicker<RotateColorsX<Variation,Red>,Black>,Bump<Int<10500>,Int<11500>>>,TrDelay<150>>,EFFECT_RETRACTION>>,
//Unstable deep sky blue noise responsive post off
TransitionEffectL<TrConcat<TrDelayX<WavLen<EFFECT_RETRACTION>>,AlphaL<BrownNoiseFlicker<Black,RotateColorsX<Variation,DeepSkyBlue>,125>,SmoothStep<Scale<NoisySoundLevel,Int<2500>,Int<15000>>,Int<-4000>>>,TrFadeX<WavLen<EFFECT_POSTOFF>>>,EFFECT_RETRACTION>,
//Unstable red noise responsive post off
TransitionEffectL<TrConcat<TrDelayX<WavLen<EFFECT_RETRACTION>>,AlphaL<BrownNoiseFlicker<Black,RotateColorsX<Variation,Red>,125>,SmoothStep<Scale<NoisySoundLevel,Int<2500>,Int<15000>>,Int<-4000>>>,TrFadeX<WavLen<EFFECT_POSTOFF>>>,EFFECT_RETRACTION>>,
//Fett263 On-Demand Battery Level, if using fett263's prop file Hold AUX and click PWR while OFF, the battery level is represented by the location on the blade; tip = full, hilt = low and color; green = full, yellow = half, red = low
//Optional/alternate Fett263 Passive Battery Monitor (fett263 prop file not required), on boot (1st line) or font change (2nd line) you will get a visual indicator at the emitter of your current battery level. This also works without a blade if you have a lit emitter or blade plug. Green is Full, Red is Low (the color will blend from Green to Red as the battery is depleted), the indicator will fade out after 3000 ms and not display again until powered down and back up or fonts change.
//Red false start preon
TransitionEffectL<TrConcat<TrDelay<500>,Black,TrWaveX<RotateColorsX<Variation,Red>,Int<750>,Int<175>,Int<1575>,Int<-3000>>,Black,TrInstant,AlphaL<RandomPerLEDFlicker<RotateColorsX<Variation,Red>,Black>,Bump<Int<12000>,Int<11500>>>,TrDelay<150>>,EFFECT_PREON>,
//Deep sky blue false start preon
TransitionEffectL<TrConcat<TrDelay<500>,Black,TrWaveX<RotateColorsX<Variation,DeepSkyBlue>,Int<750>,Int<175>,Int<1575>,Int<-3000>>,Black,TrInstant,AlphaL<RandomPerLEDFlicker<RotateColorsX<Variation,DeepSkyBlue>,Black>,Bump<Int<12000>,Int<11500>>>,TrDelay<150>>,EFFECT_PREON>>,
//Noise responsive sparking emitter preon
TransitionEffectL<TrConcat<TrInstant,AlphaL<White,SmoothStep<Scale<NoisySoundLevel,Int<150>,Int<10000>>,Int<-4000>>>,TrDelayX<WavLen<>>>,EFFECT_PREON>>>(),
