Recently purchased this Anakin EP2 Font: Desert Slayer Proffie Edition 2023 Update-JS-DesertSlayerPr
I opened it up and the font was there but I can’t find the config file for the blade style.
The Config selected does not seem to be a typical config file
That’s a font config file. Which is very different from the overall proffieOS config.
Most sound fonts do not come with bladestyles, if they do they’re typically in a text file with nothing but the bladestyle and a little message, not a complete config.
I was just looking for the blade style config but I guess there isn’t one. Should I just make one in Fett263’s blade style maker?
The short answer is yes. It’s generally assumed with sound fonts that you’re paying purely for the sounds and the bladestyle is your responsibility.
Fett’s library would be a good place to go to create one if you don’t have one.
Ok thank you, this is the second font I have downloaded and the first one came with a blade style so I was a bit confused.0
