Menu lightsaber sound
Hi people do someone know if i can go inside the menu with no lightsaber sound or with a low volume to ear really fine the voice menu
Could you say that a little differently? Not understanding what you mean.
ok sorry when i press the 2 button to go in the (edit mode) (Enter Edit Mode = While Off, Hold AUX + Hold PWR ) the lightsaber can talk but i ear the sound of the lightsaber a decided to edit because he turn on( Ignite Saber) at the same time and i dont really enderstand what the voice say because the light saber make noise (i just want the voice when i edit a lightsaber) or make the volume turn down when the edit mode open
I understand.
The menu is accessible only when the saber is on, so the hum is drowning out the voice prompt.
A new ducking feature in ProffieOS8 will be able to help with this, but currently that’s the way the edit mode works with the fett263 prop file.
If you don’t need the hum for the settings you are changing, you could temporarily work around this by removing the hum.wav from the font, doing the edits, then restoring the hum file.
allright thank you
