I have a Sabertrio saber (with an OLED screen) that is giving me some error messages that all reference a “MENU” problem that I don’t understand. Specifically, it says “Compilation error: ‘MENU_COLOR’ was not declared in this scope; did you mean ‘MENU_TOP’?” Here is the code:
// ProffieOS7 Config File
#define NUM_BLADES 2
#define VOLUME 250
#define CLASH_THRESHOLD_G 4.5
#define AUDIO_CLASH_SUPPRESSION_LEVEL 5
#define ENABLE_SSD1306
#define OLED_FLIP_180
#define KILL_OLD_PLAYERS
#define FILTER_ORDER 8
#define BLADE_DETECT_PIN 17
#define SAVE_PRESET
#define FETT263_ENABLE_SPIN_MODE
#define FETT263_BM_CLASH_DETECT 8
#define FETT263_FORCE_PUSH
#define FETT263_TWIST_ON
//#define KEEP_SAVEFILES_WHEN_PROGRAMMING
#define FETT263_DISABLE_MULTI_BLAST
#define FETT263_DISABLE_MULTI_BLAST_TOGGLE
#include "../props/saber_sabertrio_buttons.h"
//#include "../props/saber_fett263_buttons.h"
Preset blade[] = {
{ "1-Binary;common", "common/tracks/mars.wav",
StylePtr<Layers<
//Fett263 Humpflicker
HumpFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>,50>,
//Fett263 unstable swing
AlphaL<AudioFlickerL<Stripes<1000,-1500,RandomPerLEDFlicker<RotateColorsX<Variation,DarkOrange>,Black>,Black,RotateColorsX<Variation,Red>,Black>>,SwingSpeed<350>>,
//Ripple swing effect using Fett263's scaled responsive swing
AlphaL<AlphaL<Stripes<2000,-2250,RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<60,30,0>>,Pulsing<RotateColorsX<Variation,Rgb<30,15,0>>,Black,800>>,HoldPeakF<Scale<IsLessThan<SwingSpeed<850>,Int<13600>>,Scale<SwingSpeed<850>,Int<-19300>,Int<32768>>,Int<0>>,Int<550>,Scale<SwingAcceleration<100>,Int<20000>,Int<10000>>>>,SmoothStep<Scale<Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>,Int<15000>,Int<5000>>,Int<16000>>>,
//Fett263 unstable ignition
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-1550,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<3000>>,EFFECT_IGNITION>,
//Fett263 unstable force effect with sizzle emitter ending
TransitionEffectL<TrConcat<TrInstant,White,TrFade<150>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Magenta>,Black,20>,RotateColorsX<Variation,Rgb<10,0,10>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<255,25,255>>,70>,RotateColorsX<Variation,Rgb<128,0,128>>>,RotateColorsX<Variation,Rgb<80,0,80>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrDelay<1000>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Magenta>,Black,20>,RotateColorsX<Variation,Rgb<10,0,10>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<255,25,255>>,70>,RotateColorsX<Variation,Rgb<128,0,128>>>,RotateColorsX<Variation,Rgb<80,0,80>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrFade<1000>,AlphaL<StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Magenta>,Black,20>,RotateColorsX<Variation,Rgb<10,0,10>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<255,25,255>>,70>,RotateColorsX<Variation,Rgb<128,0,128>>>,RotateColorsX<Variation,Rgb<80,0,80>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,Bump<Int<3500>,Int<23384>>>,TrFade<600>>,EFFECT_FORCE>,
//Fett263 Responsive Intensity Lockup effect with absorb endlock
LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>>,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,White>,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<HumpFlicker<White,Rgb<40,60,60>,50>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>>,TrFade<350>>,SaberBase::LOCKUP_NORMAL>,
//LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>>,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,White>,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>>,SaberBase::LOCKUP_NORMAL>,
//Responsive Stab
//Blast selection based on absorb effect
ColorSelect<WavNum<EFFECT_BLAST>,TrInstant,
//Fett263 Responsive Blast Wave
TransitionEffectL<TrConcat<TrInstant,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,TrDelay<500>>,EFFECT_BLAST>,
//Fett263 Responsive Blast Wave with absorb effect
TransitionEffectL<TrConcat<TrInstant,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,TrFade<500>,AlphaL<HumpFlicker<White,Rgb<40,60,60>,50>,Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>>>,TrFade<350>>,EFFECT_BLAST>>,
//ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,
//OS6 Random Fett263 Responsive Multi-Blast
//ColorSelect<RandomF,TrInstant,ResponsiveBlastL<RgbArg<BLAST_COLOR_ARG,White>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<RgbArg<BLAST_COLOR_ARG,White>,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<RgbArg<BLAST_COLOR_ARG,White>,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<RgbArg<BLAST_COLOR_ARG,White>,200,200>,ResponsiveBlastFadeL<RgbArg<BLAST_COLOR_ARG,White>,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<RgbArg<BLAST_COLOR_ARG,White>,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,
//OS6 Fett263 Random Responsive Blast
//MultiTransitionEffectL<TrRandom<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<28000>,Int<8000>>>,TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<16384>,Int<6000>>>,TrFade<50>,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Int<0>>,TrSparkX<Remap<CenterDistF<EffectPosition<>>,Stripes<2000,-2000,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<2096>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>>,Int<100>,Int<300>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>>,TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<16384>,Int<6000>>>,TrFade<50>,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Int<0>>,TrWaveX<Remap<CenterDistF<EffectPosition<>>,Stripes<1500,-2000,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<2096>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>>,Int<160>,Int<100>,Int<300>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>>,TrConcat<TrInstant,AlphaMixL<Bump<EffectPosition<>,Scale<WavLen<>,Int<9000>,Int<12000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<300>>,TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<000>>,Scale<WavLen<>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<300>>>,EFFECT_BLAST>,
//OS5 Fett263 Multi-Blast, blaster reflect cycles through different responsive effects (I like the look of this one the best even with the new OS6 stuff)
//EffectSequence<EFFECT_BLAST,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<White,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<White,200,200>,ResponsiveBlastFadeL<White,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<White,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,
//Fett263 Real Clash with absorb effect
Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,NavajoWhite>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<300>,Int<200>,Int<940>>>,AlphaL<HumpFlicker<White,Rgb<40,60,60>,50>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>,TrFade<350>>,EFFECT_CLASH>,TransitionEffectL<TrConcat<TrWaveX<RgbArg<CLASH_COLOR_ARG,NavajoWhite>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,AlphaL<HumpFlicker<White,Rgb<40,60,60>,50>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>,TrFade<350>>,EFFECT_CLASH>>,
//Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,
//Fett263 Intensity Drag
//Alternate Responsive Drag
//LockupTrL<AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,White>,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeInX<WavLen<EFFECT_DRAG_BEGIN>>,TrFadeX<WavLen<EFFECT_DRAG_END>>,SaberBase::LOCKUP_DRAG>,
//Fett263 Power Save, if using fett263's prop file hold Aux and click PWR while ON (pointing up) to dim blade in 25% increments.
//Spark tip ignition and cycle down retraction
InOutTrL<TrWipeSparkTip<White,1500>,TrColorCycleX<Int<500>,500>>,
//Glowing emitter retraction with fizzle out post off
TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RotateColorsX<Variation,Red>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<1500>>,Int<2000>,Int<4500>>,Int<-4000>>>,TrDelayX<WavLen<EFFECT_RETRACTION>>,Black,TrDelay<897>,AlphaL<RandomPerLEDFlicker<RotateColorsX<Variation,Red>,Black>,Bump<Int<10500>,Int<11500>>>,TrDelay<150>>,EFFECT_RETRACTION>,
//Unstable noise responsive post off
TransitionEffectL<TrConcat<TrDelayX<WavLen<EFFECT_RETRACTION>>,AlphaL<BrownNoiseFlicker<Black,RotateColorsX<Variation,Red>,125>,SmoothStep<Scale<NoisySoundLevel,Int<2500>,Int<15000>>,Int<-4000>>>,TrFadeX<WavLen<EFFECT_POSTOFF>>>,EFFECT_RETRACTION>,
//Fett263 On-Demand Battery Level, if using fett263's prop file Hold AUX and click PWR while OFF, the battery level is represented by the location on the blade; tip = full, hilt = low and color; green = full, yellow = half, red = low
//Optional/alternate Fett263 Passive Battery Monitor (fett263 prop file not required), on boot (1st line) or font change (2nd line) you will get a visual indicator at the emitter of your current battery level. This also works without a blade if you have a lit emitter or blade plug. Green is Full, Red is Low (the color will blend from Green to Red as the battery is depleted), the indicator will fade out after 3000 ms and not display again until powered down and back up or fonts change.
//False start preon
TransitionEffectL<TrConcat<TrDelay<500>,Black,TrWaveX<RotateColorsX<Variation,Red>,Int<750>,Int<175>,Int<1575>,Int<-3000>>,Black,TrInstant,AlphaL<RandomPerLEDFlicker<RotateColorsX<Variation,Red>,Black>,Bump<Int<12000>,Int<11500>>>,TrDelay<150>>,EFFECT_PREON>,
//Noise responsive sparking emitter preon
TransitionEffectL<TrConcat<TrInstant,AlphaL<White,SmoothStep<Scale<NoisySoundLevel,Int<150>,Int<10000>>,Int<-4000>>>,TrDelayX<WavLen<>>>,EFFECT_PREON>
>>(), "binary"},
{ "2-Defect;common", "common/tracks/mercury.wav",
StylePtr<Layers<
//Fett263 HumpFlicker with Erratic Swing
Mix<SwingSpeed<400>,HumpFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>,50>,HumpFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<128,0,0>>,30>>,
AlphaL<AlphaL<Stripes<2000,-2250,RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<60,30,0>>,Pulsing<RotateColorsX<Variation,Rgb<30,15,0>>,Black,800>>,HoldPeakF<Scale<IsLessThan<SwingSpeed<850>,Int<13600>>,Scale<SwingSpeed<850>,Int<-19300>,Int<32768>>,Int<0>>,Int<550>,Scale<SwingAcceleration<100>,Int<20000>,Int<10000>>>>,SmoothStep<Scale<Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>,Int<15000>,Int<5000>>,Int<-16000>>>,
//Fett263 Unstable Ignition
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-1550,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFadeX<Percentage<WavLen<EFFECT_IGNITION>,15>>>,EFFECT_IGNITION>,
//HumpFlicker Bright Retraction
TransitionEffectL<TrConcat<TrFadeX<WavLen<EFFECT_RETRACTION>>,HumpFlicker<RotateColorsX<Variation,Rgb16<65535,42753,42753>>,RotateColorsX<Variation,White>,50>,TrInstant>,EFFECT_RETRACTION>,
//Fett263 Responsive Intensity Lockup with Unstable End
TrConcat<TrInstant,White,TrFade<650>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb16<65535,11439,0>>,Black,300>,TrFade<1000>,AudioFlickerL<BrownNoiseFlicker<RotateColorsX<Variation,Red>,Black,300>>,TrFade<1200>>,SaberBase::LOCKUP_NORMAL>,
//Fett263 Responsive flame emitter effect, point the blade up to speed up the flame
AlphaL<Mix<Scale<BladeAngle<19000>,Int<32768>,Int<0>>,StyleFire<Gradient<RotateColorsX<Variation,White>,RotateColorsX<Variation,Rgb16<65535,42753,42753>>,RotateColorsX<Variation,Rgb16<65535,42753,42753>>,RotateColorsX<Variation,Rgb16<65535,42753,42753>>>,RotateColorsX<Variation,Rgb<30,30,30>>,0,2,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>,StyleFire<Gradient<RotateColorsX<Variation,Rgb16<65535,42753,42753>>,RotateColorsX<Variation,White>,RotateColorsX<Variation,White>,RotateColorsX<Variation,White>>,RotateColorsX<Variation,Rgb<30,30,30>>,0,1,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>>,SmoothStep<Scale<SlowNoise<Int<3000>>,Int<1750>,Int<4125>>,Int<-3500>>>,
//Responsive Stab
//Fett263 Spark Tip Ignition and Retraction
InOutTrL<TrJoin<TrWipeX<Percentage<WavLen<EFFECT_IGNITION>,5>>,TrSparkX<White,Int<400>,Percentage<WavLen<EFFECT_IGNITION>,5>,Int<0>>>,TrJoin<TrWipeInX<WavLen<EFFECT_RETRACTION>>,TrSparkX<White,Int<400>,WavLen<EFFECT_RETRACTION>,Int<32768>>>>,
//Noise Responsive Sparky Hilt Postoff
TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb16<65535,42753,42753>>,150>,SmoothStep<Scale<NoisySoundLevel,Int<-1000>,Int<9500>>,Int<-7000>>>,TrFadeX<WavLen<EFFECT_POSTOFF>>>,EFFECT_POSTOFF>,
//Ripple Out Preon
TransitionEffectL<TrConcat<TrFadeX<Percentage<WavLen<EFFECT_PREON>,10>>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb16<65535,42753,42753>>,Int<125>,Int<350>,Int<315>,Int<0>>>,TrDelayX<Percentage<WavLen<EFFECT_PREON>,90>>>,EFFECT_PREON>,
//Noise Responsive Charge Up Preon
TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb16<65535,42753,42753>>,150>,SmoothStep<Scale<NoisySoundLevel,Int<-1500>,Trigger<EFFECT_PREON,WavLen<EFFECT_PREON>,Int<0>,Int<0>>>,Int<-8000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,EFFECT_PREON>
>>(), "defect"},
{ "3-Eruption;common", "common/tracks/mars.wav",
StylePtr<Layers<
AudioFlicker<RotateColorsX<Variation,Rgb16<65535,0,0>>,RotateColorsX<Variation,Rgb<0,0,0>>>,
AlphaL<HumpFlicker<RotateColorsX<Variation,Rgb16<64000,64000,64000>>,RotateColorsX<Variation,Rgb16<64000,64000,64000>>,50>,SwingSpeed<365>>,
TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,White>,TrFadeX<Percentage<WavLen<EFFECT_LOCKUP_END>,85>>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveStabL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Magenta>>,TrWipeInX<Percentage<WavLen<EFFECT_STAB>,50>>,TrFadeX<Percentage<WavLen<EFFECT_STAB>,50>>>,
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-2500,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<2950>>,EFFECT_IGNITION>,
TransitionEffectL<TrConcat<TrInstant,HumpFlicker<RotateColorsX<Variation,Rgb<125,85,175>>,RotateColorsX<Variation,Rgb16<24485,13179,65535>>,50>,TrFadeX<WavLen<EFFECT_RETRACTION>>>,EFFECT_RETRACTION>,
InOutTrL<TrJoin<TrWipeX<Percentage<WavLen<EFFECT_IGNITION>,4>>,TrSparkX<White,Int<400>,Percentage<WavLen<EFFECT_IGNITION>,4>,Int<0>>>,TrJoin<TrWipeInX<WavLen<EFFECT_RETRACTION>>,TrSparkX<White,Int<400>,WavLen<EFFECT_RETRACTION>,Int<32768>>>>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Percentage<WavLen<EFFECT_PREON>,33>,Percentage<WavLen<EFFECT_PREON>,34>,Percentage<WavLen<EFFECT_PREON>,33>>,StyleFire<Gradient<RotateColorsX<Variation,Rgb16<65535,65535,65535>>,RotateColorsX<Variation,White>,RotateColorsX<Variation,White>,RotateColorsX<Variation,Rgb16<65535,65535,65535>>>,RotateColorsX<Variation,Rgb<255,255,255>>,0,1,FireConfig<2000,0,0>,FireConfig<2000,0,0>,FireConfig<2000,0,0>,FireConfig<2000,0,0>>,RandomPerLEDFlicker<RotateColorsX<Variation,White>,RotateColorsX<Variation,Rgb16<65535,65535,65535>>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,White>,100>>,SmoothStep<Scale<NoisySoundLevel,Int<-1000>,Int<25000>>,Int<-4000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrDelayX<Percentage<WavLen<EFFECT_PREON>,65>>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb16<65535,0,0>>,Int<115>,Int<375>,Int<250>,Int<0>>>,TrDelayX<Percentage<WavLen<EFFECT_PREON>,35>>>,EFFECT_PREON>
>>(), "eruption"},
{ "4-Master;common", "common/tracks/mars.wav",
StylePtr<Layers<
Stripes<15000,-300,RotateColorsX<Variation,DarkOrange>,Pulsing<RotateColorsX<Variation,Rgb<255,111,30>>,RotateColorsX<Variation,DarkOrange>,800>,RotateColorsX<Variation,DarkOrange>>,
TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,DarkOrange>>,TrDelay<30000>,RotateColorsX<Variation,Orange>,TrFade<800>>,EFFECT_FORCE>,
AlphaL<RotateColorsX<Variation,DarkOrange>,Scale<IsLessThan<SwingSpeed<300>,Int<13600>>,Scale<SwingSpeed<300>,Int<-19300>,Int<32768>>,Int<0>>>,
LockupTrL<Layers<
AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Orange,Moccasin,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,Red,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Orange>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,
AlphaL<RotateColorsX<Variation,Snow>,Bump<Int<0>,Int<8000>>>,
ResponsiveStabL<Red>,
ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb<230,180,80>>>,TrFade<1200>>,EFFECT_IGNITION>,
LockupTrL<AlphaL<Mix<TwistAngle<>,Red,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,
InOutTrL<TrWipeSparkTip<White,300,40>,TrWipeIn<1400>>,
TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>>>(),
"master"},
{ "5-Null;common", "common/tracks/mars.wav",
StylePtr<Layers<
//'Heartbeat Pulse' (based on Fett263's Unstable Pulse Silver/Purple)
StripesX<Int<10000>,Scale<SlowNoise<Int<50000>>,Int<-50>,Int<-1000>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,240>>,RandomPerLEDFlicker<Mix<Int<20000>,White,RgbArg<BASE_COLOR_ARG,Rgb<100,50,240>>>,Mix<Int<20000>,White,RgbArg<BASE_COLOR_ARG,Rgb<100,50,240>>>>,BrownNoiseFlicker<Mix<Int<1285>,White,RgbArg<BASE_COLOR_ARG,Rgb<100,50,240>>>,Mix<Int<16448>,White,RgbArg<BASE_COLOR_ARG,Rgb<100,50,240>>>,300>,RgbArg<BASE_COLOR_ARG,Rgb<100,50,240>>,RandomPerLEDFlicker<White,Mix<Int<16448>,White,RgbArg<BASE_COLOR_ARG,Rgb<100,100,240>>>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,240>>>,
//Fett263 Silver Purple Humpflicker Swing
AlphaL<HumpFlicker<RotateColorsX<Variation,Rgb16<64000,8000,0>>,RotateColorsX<Variation,Rgb16<12000,1818,0>>,50>,SwingSpeed<365>>,
//Responsive Stab
//Fett263 White Unstable Ignition Effect
//Bright Humpflicker Retraction Effect
TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb16<65535,42753,42753>>,150>,SmoothStep<Scale<NoisySoundLevel,Int<-1500>,Trigger<EFFECT_PREON,WavLen<EFFECT_PREON>,Int<0>,Int<0>>>,Int<-8000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,EFFECT_PREON>>>(),
"null" },
{ "6-Fire;common", "Fire/tracks/track1.wav",
"fire"
{ "7-Protostar;common", "common/tracks/venus.wav",
StylePtr<Layers<
//Base Fett263 Dark Orange Audioflicker
AudioFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<128,34,0>>>,
//Unstable Orange-Red Audioflicker Swing Effect
AlphaL<AudioFlicker<BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,Black,300>,RotateColorsX<Variation,Orange>>,SwingSpeed<285>>,
//Fett263 Bright Ripple Hard Swing
AlphaL<Stripes<2000,-3250,RotateColorsX<Variation,Orange>,RotateColorsX<Variation,Rgb<60,36,0>>,Pulsing<RotateColorsX<Variation,Rgb<30,17,0>>,Black,800>>,Scale<IsLessThan<SwingSpeed<675>,Int<13600>>,Scale<SwingSpeed<675>,Int<-19300>,Int<32768>>,Int<0>>>,
//Fett263 Bright Sparking Emitter Flare
AlphaL<RotateColorsX<Variation,Rgb16<65535,52226,0>>,SmoothStep<Scale<SlowNoise<Int<2500>>,Int<1500>,Int<4500>>,Int<-6000>>>,
TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,White>,TrFade<1950>>,SaberBase::LOCKUP_NORMAL>,
//Responsive Stab
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-2500,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<2400>>,EFFECT_IGNITION>,
//Bright Retraction Effect
TransitionEffectL<TrConcat<TrFadeX<WavLen<EFFECT_RETRACTION>>,AudioFlickerL<RotateColorsX<Variation,Rgb16<65535,52226,0>>>,TrInstant>,EFFECT_RETRACTION>,
//Fett263 Dual Mode White Spark Tip Ignition and Retraction - Hold above horizontal for fast ignition or below horizontal for slow ignition.
InOutTrL<TrJoin<TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Percentage<WavLen<EFFECT_IGNITION>,5>,Percentage<WavLen<EFFECT_IGNITION>,50>>>,TrWaveX<White,Scale<IsLessThan<BladeAngle<>,Int<16000>>,Percentage<WavLen<EFFECT_IGNITION>,15>,Percentage<WavLen<EFFECT_IGNITION>,75>>,Int<400>,Scale<IsLessThan<BladeAngle<>,Int<16000>>,Percentage<WavLen<EFFECT_IGNITION>,5>,Percentage<WavLen<EFFECT_IGNITION>,50>>,Int<0>>>,TrJoin<TrWipeInX<WavLen<EFFECT_RETRACTION>>,TrWaveX<White,Percentage<WavLen<EFFECT_RETRACTION>,200>,Int<400>,WavLen<EFFECT_RETRACTION>,Int<32768>>>>,
//Audio responsive charge-up preon effect
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Percentage<WavLen<EFFECT_PREON>,33>,Percentage<WavLen<EFFECT_PREON>,34>,Percentage<WavLen<EFFECT_PREON>,33>>,StyleFire<Gradient<RotateColorsX<Variation,Rgb16<65535,11439,0>>,RotateColorsX<Variation,Orange>,RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb16<65535,52226,0>>>,RotateColorsX<Variation,Rgb<60,30,0>>,0,1,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>,RandomPerLEDFlicker<RotateColorsX<Variation,Orange>,RotateColorsX<Variation,Rgb16<14386,7000,0>>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Orange>,100>>,SmoothStep<Scale<NoisySoundLevel,Int<-1000>,Int<25000>>,Int<-4000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,EFFECT_PREON>,
//Ripple-Out Preon Effect
TransitionEffectL<TrConcat<TrDelayX<Percentage<WavLen<EFFECT_PREON>,65>>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb16<65535,52226,0>>,Int<115>,Int<375>,Int<250>,Int<0>>>,TrDelayX<Percentage<WavLen<EFFECT_PREON>,35>>>,EFFECT_PREON>
>>(),"protostar"
{ "8-Magnet;common", "common/tracks/venus.wav",
StylePtr<Layers<
AudioFlicker<StripesX<Sin<Int<4>,Int<3000>,Int<6000>>,Scale<TwistAngle<>,Int<-50>,Int<-100>>,StripesX<Sin<Int<3>,Int<1000>,Int<3000>>,Scale<TwistAngle<>,Int<25>,Int<80>>,Pulsing<RotateColorsX<Variation,Rgb16<0,65535,52226>>,RotateColorsX<Variation,Rgb16<0,33908,20693>>,3000>,Mix<Sin<Int<2>>,RotateColorsX<Variation,Rgb<0,63,200>>,RotateColorsX<Variation,Rgb<0,7,8>>>>,RotateColorsX<Variation,Rgb<0,39,40>>,Pulsing<RotateColorsX<Variation,Rgb<0,36,30>>,StripesX<Sin<Int<2>,Int<2000>,Int<4000>>,Sin<Int<2>,Int<25>,Int<75>>,Mix<Sin<Int<4>>,RotateColorsX<Variation,Cyan>,RotateColorsX<Variation,Rgb<50,130,255>>>,RotateColorsX<Variation,Rgb<0,70,56>>>,2000>,Pulsing<RotateColorsX<Variation,Rgb<0,40,128>>,RotateColorsX<Variation,Rgb<0,38,30>>,3000>>,AlphaL<StripesX<Sin<Int<8>,Int<3000>,Int<6000>>,Scale<TwistAngle<>,Int<60>,Int<140>>,StripesX<Sin<Int<6>,Int<1000>,Int<3000>>,Scale<TwistAngle<>,Int<-25>,Int<-80>>,Pulsing<Mix<Sin<Int<4>>,RotateColorsX<Variation,Cyan>,RotateColorsX<Variation,Rgb<50,130,255>>>,RotateColorsX<Variation,Rgb<0,12,14>>,4000>,Mix<Sin<Int<2>>,RotateColorsX<Variation,Rgb<50,130,255>>,Black>>,RotateColorsX<Variation,Rgb<0,39,40>>,Pulsing<RotateColorsX<Variation,Rgb<0,26,40>>,StripesX<Sin<Int<2>,Int<2000>,Int<4000>>,Sin<Int<2>,Int<-25>,Int<-75>>,Mix<Sin<Int<4>>,RotateColorsX<Variation,Cyan>,RotateColorsX<Variation,Rgb16<1899,49276,65535>>>,RotateColorsX<Variation,Rgb<0,30,96>>>,2000>,Pulsing<RotateColorsX<Variation,Rgb<0,40,128>>,RotateColorsX<Variation,Rgb<0,16,50>>,3000>>,Int<10000>>>,
//Blue audioflicker lava lamp
AlphaL<AudioFlickerL<AlphaL<Mix<Trigger<EFFECT_FORCE,Int<4000>,Int<3800>,Int<200>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb16<33124,0,65535>>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb16<43654,0,65535>>,RotateColorsX<Variation,Rgb16<9500,0,14386>>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Rgb16<0,65535,52226>>,RotateColorsX<Int<4000>,RotateColorsX<Variation,DeepSkyBlue>>>,RotateColorsX<Variation,Rgb16<43654,0,65535>>,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>>,SwingSpeed<450>>,
//Unstable, audio responsive swing. Force effect triggers a brief "charge up" effect while swinging which works well with the overcharged smooth swing
LockupTrL<Layers<
AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
//Responsive lockup
//Responsive lightning block
AlphaL<RotateColorsX<Variation,Rgb16<11366,0,65535>>,SmoothStep<Scale<SlowNoise<Int<2500>>,Int<1000>,Int<4000>>,Int<-4000>>>,
//Sparking emitter flare
ResponsiveStabL<Orange>,
//Responsive stab
ResponsiveClashL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
//Responsive clash
TransitionEffectL<TrConcat<TrFade<1040>,RotateColorsX<Variation,Rgb16<2521,681,18076>>,TrInstant,RotateColorsX<Variation,Rgb16<0,65535,52226>>,TrFade<550>>,EFFECT_IGNITION>,
//Charge up ignition effect
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb16<40546,3350,65535>>>,TrFade<1000>>,EFFECT_RETRACTION>,
//Purple retraction
//Drag
LockupTrL<AlphaL<Mix<TwistAngle<>,Orange,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,
//Responsive melt
InOutTrL<TrColorCycle<1040,5500,2000>,TrWipeInSparkTip<White,875>>,
//Color cycle ignition, spark tip retraction
//InOutTrL<TrWipeInSparkTip<White,1040>,TrWipeInSparkTip<White,875>>,
//Alternate spark tip in ignition and retraction
//TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Orange,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>,
//TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Orange,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_NEWFONT>,
//Optional/alternate passive battery monitor, on boot (1st line) or font change (2nd line) you will get a visual indicator at the emitter of your current battery level. This also works without a blade if you have a lit emitter or blade plug. Green is Full, Orange is Low (the color will blend from Green to Orange as the battery is depleted), the indicator will fade out after 3000 ms and not display again until poweOrange down and back up or fonts change.
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Orange,Green>,Bump<BatteryLevel,Int<10000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Orange,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>
//On demand battery level, if using fett263's prop file Hold AUX and click PWR while OFF, the battery level is represented by the location on the blade; tip = full, hilt = low and color; green = full, yellow = half, Orange = low
"magnet"
{ "9-Coda;common", "tracks/venus.wav",
StylePtr<Layers<
Mix<Sin<Int<3>>,AudioFlicker<RotateColorsX<Variation,DodgerBlue>,Stripes<5000,-90,RotateColorsX<Variation,Rgb<0,55,165>>,RotateColorsX<Variation,Rgb<0,85,115>>,RotateColorsX<Variation,Rgb<0,65,145>>,RotateColorsX<Variation,Rgb<0,30,185>>>>,AudioFlicker<RotateColorsX<Variation,Rgb<0,155,255>>,Stripes<5000,-90,RotateColorsX<Variation,Rgb<0,95,170>>,RotateColorsX<Variation,Rgb<0,115,215>>,RotateColorsX<Variation,Rgb<0,145,145>>,RotateColorsX<Variation,Rgb<0,65,225>>>>>,
//Rotates ^3 times per minute between DodgerBlue and DeepSkyBlue with subtle Cyan/Blue audioflicker
//AudioFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,95,195>>>,
//Alternate DeepSkyBlue with very subtle audioflicker
AlphaL<BrownNoiseFlicker<RotateColorsX<Variation,DeepSkyBlue>,Black,300>,SwingSpeed<400>>,
//Unstable swing
AlphaL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Variation,DeepSkyBlue>,Black>,Black,RotateColorsX<Variation,DeepSkyBlue>,Black>,SwingSpeed<525>>,
//Unstable ripple swing
LockupTrL<Layers<
AlphaL<AudioFlickerL<Rgb<255,240,80>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
AlphaL<LemonChiffon,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<875>>,SaberBase::LOCKUP_NORMAL>,
//Responsive lockup effect with screeching humpflicker endlock
//LockupTrL<Layers<
//AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
//AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<4000>>,SaberBase::LOCKUP_NORMAL>,
//Alternate standard lockup
ResponsiveStabL<RotateColorsX<Variation,Yellow>>,
//Responsive stab
//ResponsiveStabL<Red>,
//Alternate responsive stab, no color change
//ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
//Alternate responsive blast
//Responsive Clash
//ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
//Alternate white clash
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb<90,180,255>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<0,26,60>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<90,180,255>>,RotateColorsX<Variation,Rgb<0,26,60>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<0,42,128>>,RotateColorsX<Variation,Rgb<0,26,60>>>>,TrFade<400>,Stripes<3000,-3500,RotateColorsX<Variation,Rgb<90,180,255>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<0,26,60>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<90,180,255>>,RotateColorsX<Variation,Rgb<0,26,60>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<0,42,128>>,RotateColorsX<Variation,Rgb<0,26,60>>>>,TrFade<450>,HumpFlickerL<AlphaL<RotateColorsX<Variation,Rgb<90,180,255>>,Int<19000>>,25>,TrFade<2875>>,EFFECT_IGNITION>,
//Stabilize ignition effect
TransitionEffectL<TrConcat<TrFade<1125>,RotateColorsX<Variation,Rgb<90,180,255>>,TrInstant>,EFFECT_RETRACTION>,
//Slow brighten retraction effect
//Drag
//Responsive melt
InOutTrL<TrWipe<500>,TrWipeIn<1125>>,
//Standard ignition/retraction
TransitionEffectL<TrConcat<TrFade<450>,AlphaL<HumpFlickerL<RotateColorsX<Variation,DeepSkyBlue>,10>,Bump<Int<0>,Int<3000>>>,TrFade<350>,AlphaL<HumpFlickerL<RotateColorsX<Variation,DeepSkyBlue>,15>,Bump<Int<0>,Int<5000>>>,TrFade<450>,AlphaL<HumpFlickerL<RotateColorsX<Variation,DeepSkyBlue>,20>,Bump<Int<0>,Int<7000>>>,TrFade<500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,DeepSkyBlue>,25>,Bump<Int<0>,Int<10500>>>,TrBoing<150,1>>,EFFECT_PREON>
//Overload preon effect
"coda"
{ "10-Training;common", "common/tracks/venus.wav",
StylePtr<Layers<Mix<SwingSpeed<400>,AudioFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,RotateColorsX<Variation,Rgb<35,35,150>>>,Mix<SwingSpeed<600>,RotateColorsX<Variation,Rgb<100,100,150>>,RotateColorsX<Variation,Rgb<200,200,250>>>>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(), "training"},
{ "11-Flashlight;common", "common/tracks/venus.wav",
StylePtr<InOutTr<Layers<Mix<SwingSpeed<400>,AudioFlicker<RotateColorsX<Variation,Rgb<206,113,32>>,RotateColorsX<Variation,Rgb<84,60,0>>>,Mix<SwingSpeed<600>,RotateColorsX<Variation,Rgb<206,113,32>>,RotateColorsX<Variation,BlanchedAlmond>>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<AudioFlicker<Blue,SteelBlue>,Bump<Int<0>,Int<9000>>>,TrFade<600>>,EFFECT_IGNITION>,ResponsiveBlastL<White>,ResponsiveClashL<White,TrInstant,TrFade<400>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<200>>,TrFade<400>>,ResponsiveDragL<BrownNoiseFlickerL<White,Int<300>>,TrWipeIn<400>,TrFade<400>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveMeltL<Mix<TwistAngle<>,OrangeRed,Orange>,TrWipeIn<600>,TrSmoothFade<600>>>,TrWipe<150>,TrWipeIn<300>,Black>>(),
"flashlight"},
SimpleBladePtr<CreeXPE2WhiteTemplate<550>, NoLED, NoLED, NoLED, bladePowerPin1, -1, -1, -1>(),
CONFIGARRAY(blade)
/* Generated with Fett263 Config Helper v2.0 */
This is essentially the same saber (same model anyway) that I referenced here: Sabertrio Senza Saber (Customizing OLED Display Errors) For some reason I’m running into a completely different problem though.
Anyone know what I did wrong? Thanks in advance
