So i just finished installing my graflex with proffie v2.2
I have 2 issues
1: When i press my ignition switch it goes on fine BUT a soon as i start moving the saver it makes a SECOND ignition…
2:When i close the saber with the ignition switch it closes but makes a SECOND boot sound again…
Here is my config ! Thanks
#define NUM_BLADES 4
#define VOLUME 1750
#define CLASH_THRESHOLD_G 3.4
#define MOTION_TIMEOUT 60101000
#define IDLE_OFF_TIME 60101000
#define SAVE_STATE
#define FETT263_MAX_CLASH 16
#define FETT263_TWIST_ON
#define COLORWHEEL ZOOM
#define SHARED_POWER_PINS
#define ENABLE_SSD1306
#define BLADE_DETECT_PIN 17
{ “1-REY;common”, “common/tracks/rey.wav”,
StylePtr<Layers<HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,60>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<191,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<300>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,RetractionTime<0>>,Black>>>(),
StylePtr<Layers<HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,60>,InOutTrL<TrInstant,TrInstant,Black>>>(),
StylePtr<Layers<TransitionLoop<Black,TrConcat<TrWipe<200>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,75>>,TrWipe<200>>>,InOutTrL<TrInstant,TrInstant,TransitionLoop<Black,TrConcat<TrCenterWipe<500>,RgbArg<OFF_COLOR_ARG,Rgb<0,255,0>>,TrCenterWipe<500>>>>>>(),
StylePtr<Layers<Stripes<5000,-2500,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,InOutTrL<TrInstant,TrInstant,Pulsing<Mix<Int<8192>,Black,RgbArg<OFF_COLOR_ARG,Rgb<2,72,255>>>,RgbArg<OFF_COLOR_ARG,Rgb<2,72,255>>,2000>>>>(),
“REY”},
{ 0, WS281XBladePtr<136, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
WS281XBladePtr<16, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
WS281XBladePtr<6, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin4, bladePowerPin5> >(),
WS281XBladePtr<2, blade4Pin, Color8::GRB, PowerPINS >()
, CONFIGARRAY(presets) },
