Lukes control box leds
Thanks Matt!
You’re welcome!
Happy to help with anything I can!
I would like to clarify because you mentioned they would be in series earlier in the topic:
If you want them in series you have to remove resistor R1 and bridge the J pads,
If you want parallel what I said previously is correct.
It seems to me that you have a 115 LED long blade that you want to be in series with the 16 LED blade connector.
So you will want to use option 3 for which you need to remove resistor R1 and bridge the J pads and then you would send data to the D2 pad.
Hi Matt, do I have to include the 16 LED blade in my config as a separate blade?
Not if it’s wired in series.
Okay thats good👍
It could be SubBlade’d though, if you want them to be separate.
Sounds like in this case though it’s better to go the simple route first and get that working.
Agreed.
Once it’s wired in series he has the flexibility to do sub blades or leave it be.
Just an update here’s some code that works on the control box, thanks to Khal
from The Saber Armory. No sub blades required. 2 blades.
// led 1 and 2
StylePtr<Gradient<Layers<TransitionLoop<Black,TrConcat<TrDelay<3000>,RotateColorsX<Variation,Red>,TrBoing<2000,5>>>,InOutTrL<TrInstant,TrInstant,TransitionLoop<Black,TrConcat<TrDelay<3000>,RotateColorsX<Variation,Red>,TrBoing<2000,5>>>>>,Layers<TransitionLoop<RotateColorsX<Variation,Green>,TrConcat<TrBoing<3000,9>,Black,TrDelay<2000>>>,InOutTrL<TrInstant,TrInstant,TransitionLoop<RotateColorsX<Variation,Green>,TrConcat<TrBoing<3000,9>,Black,TrDelay<2000>>>>>>>()},
{ 0, WS281XBladePtr<144, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), //Main Blade
	WS281XBladePtr<2, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4> >(), //Switch PCB
	, CONFIGARRAY(presets) },
