Lots of Error Messages / Verifying Custom Fonts / Only one font compiles
I’m trying to put some custom fonts on my new Sabertrio, and I’m running into some really long error messages when I click Verify in Arduino. If anyone can make sense of the following, I’d really appreciate it:
This is the error message: https://drive.google.com/file/d/1KGu5Htf9otvjMVdDyQS9CxCoGI9HsWiM/
This is my config file:
I apologize for the length of these files but I honestly am pretty much lost.
Since you have a very long config, if an error is detected at the beginning, multiple false errors will be created. At the end the error code is so long that the beginning will be missing (which is the case here).
If I may suggest, you remove all but the first preset. Try to compile, if it does then add the next one and so on until you find the offending preset. Probably you have a missing comma, semi-colon, }, ), > somewhere. Or an error in one of the styles.
The “real” error is usually in the first 5 errors which are not shown in your long error list.
That was a good idea, although I’m still not sure what the problem is. I deleted each font, one at a time, until all I had left was the first one, and it compiled normally. This is what I have:
// Sabertrio Proffie Saber - Blade & Sound Font Configuration
#define NUM_BLADES 4
#define VOLUME 250
#define CLASH_THRESHOLD_G 3.4
#define ENABLE_SSD1306
#define IDLE_OFF_TIME 60*2*1000
#define MOTION_TIMEOUT 60*10*1000
#define SHARED_POWER_PINS
#define BLADE_DETECT_PIN 17
#define SAVE_PRESET
#include"../props/s3button_config.h"
Preset no_blade[] = {
   { "0-NO_BLADE","",
    StylePtr<Black>(),
	StylePtr<Black>(),
	StylePtr<Black>(),
	StylePtr<Pulsing<White,Black,1200>>()
   Preset blade[] = {
	  { "1-Assassin;common", "common/tracks/mars.wav",
    StylePtr<Layers<
  HumpFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>,50>,
  //Green humpflicker
  AlphaL<Stripes<2500,-2750,RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<25,60,0>>,Pulsing<RotateColorsX<Variation,Rgb<0,30,0>>,Black,800>>,SwingSpeed<375>>,
  //Swing effect, rippling green
  LockupTrL<Layers<
    AlphaL<AudioFlickerL<Rgb<255,240,80>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
    AlphaL<LemonChiffon,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
  //Responsive lockup
  //Responsive lightning block
  AlphaL<RotateColorsX<Variation,Rgb16<21301,65535,0>>,SmoothStep<Scale<SlowNoise<Int<2500>>,Int<1000>,Int<3000>>,Int<-4000>>>,
  //Sparking emitter flare
  ResponsiveStabL<Red>,
  //Responsive stab
  //Responsive clash
  TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb16<38402,65535,3934>>,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb16<38402,65535,3934>>,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<500>>,EFFECT_IGNITION>,
  //Unstable ignition
  TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb16<54757,65535,0>>>,TrFade<1000>>,EFFECT_RETRACTION>,
  //Bright retraction
  //Drag
  //Responsive melt
  InOutTrL<TrWipeSparkTip<White,250>,TrWipeInSparkTip<White,656>>,
  //Spark tip ignition and retraction
  TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>
 { 0, WS281XBladePtr<115, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
  WS281XBladePtr<20, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4> >(),
    WS281XBladePtr<20, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin5> >(),
    SimpleBladePtr<CreeXPE2WhiteTemplate<550>, NoLED, NoLED, NoLED, bladePowerPin1, -1, -1, -1>()
  , CONFIGARRAY(blade) },
 { NO_BLADE, WS281XBladePtr<115, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
  , CONFIGARRAY(no_blade) },
Can you tell what might be wrong with this one that is screwing up all the others?
Your config above compiles fine for me under the Sabertrio ProffieOS version.
You need to post the error you’re getting.
I posted the error in my OP. Here it is again:
That error message isn’t caused by the blade style in the version of the config you posted last. Everything in that is fine.
One of the other presets that you removed must contain a style that contains that LockupTrL layer.
If the error is showing the complete layer, then it’s missing the rest of the template after the lockup COLOR.
LockupTrL<
AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,
Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,
Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,
Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,
Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,
BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,White>,Int<200>>,
StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,
 Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>,RgbArg<LOCKUP_COLOR_ARG,White>,
 Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>>,
is incomplete. It’s missing all this at the end of it (some default values shown):
TrFade<100>,TrFade<100>,SaberBase::LOCKUP_MELT>
You’ll have to forgive my inexperience, because I don’t quite understand where that small strip of code is supposed to go.
The larger chunk of code you listed shows up in the fonts 2, 3, 5, and 7. It doesn’t show in the first font. So where do I paste TrFade<100>,TrFade<100>,SaberBase::LOCKUP_MELT> ? I tried putting it in the second font but I just get a whole crap load of new error message.
Again, sorry if I’m not following, this is just very complicated.
I don’t think you understood what I wrote.
So you have the first font that works, great, now add a second one. If you can compile with it, than add the third. If you get an error from font 2, post that error and do not add font 3. You add one at a time and try to compile until it doesn’t compile anymore.
We can’t help you with the stuff that woks, because it is working and you don’t need help with it.
You need to find the one that doesn’t work, than we can help you to make it work.
Does this makes sense? I can also try to explain in French (en Français - only because of the colors of your avatar/icone, the colors reminds me of the French flag, witch makes me think you might be French?) if you prefer?
P.S. I know nothing about blade styles errors, I can only help you find the problematic one(s). Some of the other guys here are really good/great at blade styles errors.
Ah okay, I understand. (and no, I’m not French, LOL. The avatar is the Commodore64 logo, my first computer) I’m American :wink:
Anyway, the first font compiles fine. I added the second one, and I got this error:
You should also post the config that causes that error.
Looks like you’re just missing a comma, but can’t see where without the config.
For info, I am not French either, but my mother tongue is French. I know my thoughts don’t always get translated perfectly from “brain to keyboard”. I am glad you understood me. :partying_face:
I knew I recognized it from somewhere. :grin:
Just like @NoSloppy said, post the config that caused that error.
:wink:
Right, sorry, I wasn’t thinking about the config file, :stuck_out_tongue:
It would figure if it was just a comma misplace :roll_eyes:
Here ya go:
#define VOLUME 250
#define SAVE_PRESET
   { "0-NO_BLADE","",
    StylePtr<Black>(),
	StylePtr<Black>(),
	StylePtr<Black>(),
   Preset blade[] = {
    StylePtr<Layers<
  //Green humpflicker
  LockupTrL<Layers<
  //Responsive lockup
  //Responsive stab
  //Responsive clash
  //Unstable ignition
  //Bright retraction
  //Drag
  //Responsive melt
   { "2-Defect;common", "common/tracks/mercury.wav",
    StylePtr<Layers<
  //Fett263 HumpFlicker with Erratic Swing
  Mix<SwingSpeed<400>,HumpFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>,50>,HumpFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<128,0,0>>,30>>,
  //Ripple swing effect using Fett263's scaled responsive swing
  AlphaL<AlphaL<Stripes<2000,-2250,RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<60,30,0>>,Pulsing<RotateColorsX<Variation,Rgb<30,15,0>>,Black,800>>,HoldPeakF<Scale<IsLessThan<SwingSpeed<850>,Int<13600>>,Scale<SwingSpeed<850>,Int<-19300>,Int<32768>>,Int<0>>,Int<550>,Scale<SwingAcceleration<100>,Int<20000>,Int<10000>>>>,SmoothStep<Scale<Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>,Int<15000>,Int<5000>>,Int<-16000>>>,
  //Fett263 Unstable Ignition
  TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-1550,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFadeX<Percentage<WavLen<EFFECT_IGNITION>,15>>>,EFFECT_IGNITION>,
  //HumpFlicker Bright Retraction
  TransitionEffectL<TrConcat<TrFadeX<WavLen<EFFECT_RETRACTION>>,HumpFlicker<RotateColorsX<Variation,Rgb16<65535,42753,42753>>,RotateColorsX<Variation,White>,50>,TrInstant>,EFFECT_RETRACTION>,
  //Fett263 Responsive Intensity Lockup with Unstable End
  TrConcat<TrInstant,White,TrFade<650>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb16<65535,11439,0>>,Black,300>,TrFade<1000>,AudioFlickerL<BrownNoiseFlicker<RotateColorsX<Variation,Red>,Black,300>>,TrFade<1200>>,SaberBase::LOCKUP_NORMAL>,
  //Fett263 Responsive flame emitter effect, point the blade up to speed up the flame
  AlphaL<Mix<Scale<BladeAngle<19000>,Int<32768>,Int<0>>,StyleFire<Gradient<RotateColorsX<Variation,White>,RotateColorsX<Variation,Rgb16<65535,42753,42753>>,RotateColorsX<Variation,Rgb16<65535,42753,42753>>,RotateColorsX<Variation,Rgb16<65535,42753,42753>>>,RotateColorsX<Variation,Rgb<30,30,30>>,0,2,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>,StyleFire<Gradient<RotateColorsX<Variation,Rgb16<65535,42753,42753>>,RotateColorsX<Variation,White>,RotateColorsX<Variation,White>,RotateColorsX<Variation,White>>,RotateColorsX<Variation,Rgb<30,30,30>>,0,1,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>>,SmoothStep<Scale<SlowNoise<Int<3000>>,Int<1750>,Int<4125>>,Int<-3500>>>,
  //Responsive Stab
  //Fett263 Real Clash
  //Fett263 Intensity Drag
  //Fett263 Spark Tip Ignition and Retraction
  InOutTrL<TrJoin<TrWipeX<Percentage<WavLen<EFFECT_IGNITION>,5>>,TrSparkX<White,Int<400>,Percentage<WavLen<EFFECT_IGNITION>,5>,Int<0>>>,TrJoin<TrWipeInX<WavLen<EFFECT_RETRACTION>>,TrSparkX<White,Int<400>,WavLen<EFFECT_RETRACTION>,Int<32768>>>>,
  //Noise Responsive Sparky Hilt Postoff
  TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb16<65535,42753,42753>>,150>,SmoothStep<Scale<NoisySoundLevel,Int<-1000>,Int<9500>>,Int<-7000>>>,TrFadeX<WavLen<EFFECT_POSTOFF>>>,EFFECT_POSTOFF>,
  //Ripple Out Preon
  TransitionEffectL<TrConcat<TrFadeX<Percentage<WavLen<EFFECT_PREON>,10>>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb16<65535,42753,42753>>,Int<125>,Int<350>,Int<315>,Int<0>>>,TrDelayX<Percentage<WavLen<EFFECT_PREON>,90>>>,EFFECT_PREON>,
  //Noise Responsive Charge Up Preon
  TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb16<65535,42753,42753>>,150>,SmoothStep<Scale<NoisySoundLevel,Int<-1500>,Trigger<EFFECT_PREON,WavLen<EFFECT_PREON>,Int<0>,Int<0>>>,Int<-8000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,EFFECT_PREON>
That’s giving you an error?
still compiling fine for me.
You are not trying to use it with official ProffieOS, right?
You have a Sabertrio config and it’s designed to work with the modified OS and prop file.
You need to use the ProffieOS that comes in their “preconfiguration”.
Yeah, I’m using the ProffieOS and the config file that came with the saber.
It seems that no matter what font I put into the config file, it doesn’t compile correctly for me. I replace that first font with others, and I get all those error messages again. If I put any other font in after that first one, I get the same error messages. The only font that seems to work just fine is the “Assassin” font. Is it possible there’s something wrong with the code above the fonts?
I just can’t figure out what I’m doing wrong. I’ve added custom fonts to probably 20 other Sabertrios and never had this problem. Just as an example, this is another config I did for a Sabertrio that uses similar fonts that compiles just fine:
We should really be sending you to Sabertrio for support since they decided to modify ProffieOS and sent customers on their merry way.
If you zip up your ProffieOS file and share it via Goodle Drive or Dropbox or something,
I’ll download and see what the issue is.
Should just be something stupid, but i can’t fully troubleshoot if you’re above Preconfiguration 2.0, as that’s all I have to test with.
Just a random guess.
I had a font one time that worked just fine & could get it to compile & upload.
Turns out it had something to do with name of the font.
Maybe try taking the font, replacing another one that already works with that one, & deleting the one that wasn’t working. See if that changes anything, & if it does then it’s just a problem with the font name, like a problem with the sound track…
