Hello people! It’s been a long time, unfortunately I was and still am ill. I bought a Cal Kestis Proffie a while ago. The cables to the speaker were badly laid. So (to get to the SD card) I had to push the red and black cables under the board on the right and left. This loosened the board. What glue can I use to stick the proffieboard back on to the casing? It’s only partially attached to the casing, can I also carefully pull it off? Unfortunately, fine soldering is no longer possible for me, I’ve only had one arm for 15 years, otherwise I would have extended the cables. Can someone help me with the glue or what to use to attach the board? Please
You can use E6000 glue, but be careful of the fumes ![]()
Also a thin wrap of Kapton tape is a good way to keep a board steady in a chassis.
And hot glue can be messy, but is harmless and non conductive. Just don’t over do it.
Thank you very much, even if it took a long time. Thank you very much
