Iam just looking to see where people buy a crystal that goes in a lightsaber. One that looks realistic enough and you can illuminate with a neopixle .
Look for bags quartz points on ebay. Get a mixture of sizes and go through to find one that calls to you.
Copy that. Thanks for the info.![]()
Etsy as well they have bulk packages(10-20±up to 1/2 lbs) as well if you looking to do more than one saber or if you fancy having two crystals in the CC, may have to cut them down and sand the outside to give some diffusion.
And Saberbay has them as well
But if they are to long or to clear a dremel is your friend.
Ok ya. Sounds like I got options. I am going to need a variety forsure. If they are too clear the light won’t travel good. So then just rough them up with a Dremel. Like it ![]()
