My first diy lightsaber wiring diagram install. I tried to do most research on my own, working with wiring manuals and resources directly from the saber seller (The Saber Armory). The hilt and chassis is for the KR and ELF sabers Knight RVN, with the eco crystal chamber chassis. If there is any inaccurate information or a wire that goes to the wrong place, please help and give me feedback. Since this is my first install, I am also fairly new to this reddit as well as knowing what information to give more on the saber. If there is any information which needs expanding on, or confusion about the diagram itself, I will try to respond swiftly to clear up the details. Thank you for your time. May the force be with you!
It’s usually recommended to wire the high amp draw blade connector directly to battery. I wire everything but the proffie direct to batt+, and the switch only breaks the power to the proffie.
Do the small boards have pixels? That wiring could be simplified some, but looks ok to me as is.
Thank you! I’ll change it up to wire everything but the proffie to the battery. The small boards are switches with pixels.
The circuit diagram looks like it would work.
It can be simplified a bit if desired though:
- You can skip the second black wire from battery- to GND
- Using subblade, you can connect the two button things (and possibly the accent LED) into one string, if that is easier.
Also, I’m not familiar with the display PCB you’re using, is it a SSD1306-based 128x32 oled?
Here is an updated version. I wired everything but the proffie directly to batt+. The small boards do have pixels. I cut out the second black wire to ground. I’m not entirely sure what you mean with subblade and connecting it all with a string? Is there a guide somewhere I could read about it? The PCB is the KR 128x32 OLED Display Module from the Saber Armory.
Ignore the yellow dots around the speaker.
Yup.
The picture is of the back of a small form-factor OLED display, 128x32. I think it’s the TCSS version:
TCSS/KR 128x32 OLED Screen – Saberbay
There is also a KR version availabe through TSA:
KR 128x32 OLED Display Module - Blue or White – The Saber Armory
It is the second one.
