You have mismatched naming going on.
If you include saber_sa22c_buttons, then all of the gesture defines will start with SA22C.
You have FETT263 in your last post.
You were closest where you posted above after correcting the double underscores, you just need to capitalize SA22C.
The SD card from LGT should have a folder named ‘sdconfig’ on it which should have all the default configs they send out. The one named what your saber is setup as (Neo1switch…somethiing) is likely what you want.
However, there’s a high chance that the version of saber_sa22c_buttons.h is the official ProffieOS 5.9 version, which did not include the gesture additions.
For that, replace the file in /props with this one, setup the defines as you did (but capitalize), and you should be good to go.
