when connecting two leds strips back to back (parallel)
Do you need to edit the config to get more brightness out of them ?
If wired in parallel, they are treated as one single blade.
There’s nothing in the config file to edit to get more brightness out of them just because there are 2.
Brightness is governed by power. If they seem dim, check that you have a fully charged battery, and sufficient gauge wire running power to the strips. That also includes a sufficient amount of pogo pins in a connector. I have seen connectors providing as little as 3 pins which may not be enough to carry up to 10 or 15 amps of power that may sometimes be required.
