Kylo Ren Crossguard Blades Not Working
So, I just installed an 89Sabers Kylo Ren Hilt and following the wiring diagram from the generator I added 470OHM resistors to the data lines of the crossguard.
But the blade wouldn’t ignite so I tried removing the resistors and now I get a rainbow effect which says to me that without the resistors I’m getting a lot of noise.
My question is: Why won’t seemingly any data come through while using the resistors but so much noise comes through without them, and how do I resolve this?
Can you post your config file? The resistors should fix problems not cause them.
Is the main blade lighting up, and not the cross blades? How are they wired to the proffie?
Edit for clarity
Config
The main blade lights up normally but the side blades didn’t light up at all with the resistors but light up rainbow without them.
Is it possible that the side blade connectors aren’t receiving enough power from the single MOSFET they each are wired to?
I should probably point out that the data for the NPXL Connectors work fine.
I have 2 data lines per connector and the data line for the onboard LEDs works well.
Is it possible that your quillions use RGBW pixel strips?
I tried changing that in the config while the resistors were still connected and I still got no results.
Should I try it now that the resistors are removed?
It’s a common reason for “rainbow” effects, so yes, you should probably try changing that. (Unless you know what kind of strips they are, then just pick the right kind.) I’m not sure why it didn’t work with resistors though, that doesn’t really make any sense. Although I suppose the resistor(s) could simply be broken.
No dice unfortunately.
Anything else stick out to you that I may have missed?
Try making a video, post it on youtube or google photos and then post the link here.
Sometimes seeing what the problem looks like can make it pretty obvious what’s going on for people who have seen the problem before.
The data is hooked up to the right end of the pixel strip, right?
I’m not quite sure what you mean by this.
If you are referring to the strips in the side blades themselves then I am not sure as I bought them assembled and sadly they glued them.
Here is a video showing the problem.
It’s hard to tell because of all the flickering, but it does look like a RGB/RGBW mixup.
When you tried RGBW, what did your config file look like? And did it make any difference in how the blade looked?
One thing that confuses me a bit is that usually when you have RGBW blades but feed them RGB data, the rainbow effect is very washed out because of all the white, but that doesn’t seem to be the case here? Maybe you have RGB blades but feed them RGBW data? (If so, are you sure that your uploads are working properly?)
Anyways, I would some simple styles with different colors to see if you can figure out what is going on. Like, for instance, what happens if you try StyleNormalPtr<Blue, White, 800, 800>(), ?
It looked like this but to be honest I’m not sure if that’s right.
Its right enough.
If they were RGBW pixels, then the rainbow effect should have stopped.
(It’s possible that the colors would be wrong, in which case you would want RGBW instead of GRBW, but regardless, the rainbow effect should have stopped.)
Let’s check something different: What kind of pogo pin PCBs did you use? How did you wire them?
I used Shtok NPXLs V4 from Saberbay and used the fourth wiring configuration on all of them.
Did the PCBs come with R1 populated? (If so, did you remove it?)
It has the same rainbow colors but static instead of the unstable style it was copying before.
Yes and yes.
