I just got the KR Sabers Graflex saber kit and I’m trying to figure out how to install it but I can’t find any resources that go over it.
If anyone knows where to look, or has installed it before please reach out.
Thanks
Thanks
Did you get a chassis with it?
Yeah, I got the eco chassis install kit.
I di not see a guide. It looks fairly straight forward. Let me know any specific questions and I will see what I can do. I have done 2 other graflex, but they are all a bit different.
Unless you need help with just getting started?
Also check YouTube, I have seen quite a few install videos for Graflex(s).
I am even tempted to suggest “Avery Castillo” (I don’t know how to spell his name, sorry) but he has shown many of his installs (not a huge amount of details, but you should get the “gist”).
My main question is where these
Graflex Saber Kit Brass Sync Contacts – The Saber Armory https://share.google/tEiLGndE5rmP9v3Y6
Are installed.
Everything else is straightforward, but I don’t know where those go.
I am subscribed to him already ![]()
His channel gave me the confidence to start installing.
Under the bottom one on each side?
Yes sir. ![]()
Thank you!
This is the manufacturer’s installation guide for the KRGraflex.
If my memory serves me correctly, their Graflex had some screws that were too long and protruded inside the blade holder.
I recommend filing them down before wiring.
All the wiring is done and working but I can’t figure out how I’m gonna install the graflex clamp
If I connect it to the top I won’t be able to access the battery, but if I connect it to the bottom I need it super loose to get around everything.
Any ideas on what to do are appreciated, thank you.
Setting it up in ANH configuration by the way.
If the inside of the clamp interferes with the chassis, trim the protrusion to adjust the height.
If only the bottom moves when tightening the clamp, bend the wings slightly outward to adjust.
Thank you!
