Asked KR for a config of the ECO-HERO basic chassis, was sent ECO_Hero.h (4.9 KB)
After plugging into my config files folder in ProffieOS, flashing my saber (still WIP but is functional enough to run on battery power and have sound) and trying to install on ProffieOS got a HUGE list of errors. Here’s the list. I have no clue what’s wrong, I’m still pretty new to doing serious editing on ProffieOS, and I’ve never done accent LEDS before.
Arduino: 1.8.13 (Windows 10), Board: "Proffieboard V2, Serial, SDCARD (SPI), 80 MHz, Smallest Code"
In file included from C:\Users\orang\Desktop\ProffieOS\ProffieOS.ino:52:
sketch\config/ECOHERO_config.h:74:1: error: 'StylePtr' does not name a type
74 | StylePtr<Layers<Blinking<Green,Black,500,500>,TransitionEffectL<TrConcat<TrInstant,White,TrFade<400>>,EFFECT_BLAST>,LockupTrL<AudioFlickerL<White>,TrInstant,TrFade<500>,SaberBase::LOCKUP_NORMAL>,LockupTrL<AudioFlickerL<White>,TrInstant,TrFade<500>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,TransitionEffectL<TrConcat<TrInstant,White,TrFade<400>>,EFFECT_CLASH>,InOutTrL<TrFade<500>,TrFade<500>,Blinking<Green,Black,500,500>>>>()
In file included from C:\Users\orang\Desktop\ProffieOS\ProffieOS.ino:592:
sketch\config/ECOHERO_config.h:74:1: error: specializing member '::StylePtr<Layers<Layers<Rgb<0, 255, 0>, AlphaL<Rgb<0, 0, 0>, BlinkingF<Int<500>, Int<500> > > >, TransitionEffectL<TrConcat<TrInstant, Rgb<255, 255, 255>, TrFadeX<Int<400> > >, EffectType::EFFECT_BLAST>, LockupTrL<AlphaL<Rgb<255, 255, 255>, NoisySoundLevelCompat>, TrInstant, TrFadeX<Int<500> >, SaberBase::LOCKUP_NORMAL>, LockupTrL<AlphaL<Rgb<255, 255, 255>, NoisySoundLevelCompat>, TrInstant, TrFadeX<Int<500> >, SaberBase::LOCKUP_LIGHTNING_BLOCK>, TransitionEffectL<TrConcat<TrInstant, Rgb<255, 255, 255>, TrFadeX<Int<400> > >, EffectType::EFFECT_CLASH>, InOutTrL<TrFadeX<Int<500> >, TrFadeX<Int<500> >, Layers<Rgb<0, 255, 0>, AlphaL<Rgb<0, 0, 0>, BlinkingF<Int<500>, Int<500> > > >, true> > >' requires 'template<>' syntax
In file included from c:\users\orang\appdata\local\temp\arduino_build_515855\sketch\props\saber_sa22c_buttons.h:82,
from sketch\config/ECOHERO_config.h:23,
from C:\Users\orang\Desktop\ProffieOS\ProffieOS.ino:596:
c:\users\orang\appdata\local\temp\arduino_build_515855\sketch\props\prop_base.h:443:3: error: 'SaveGlobalStateFile' does not name a type; did you mean 'SavePresetStateFile'?
443 | SaveGlobalStateFile saved_global_state;
| SavePresetStateFile
c:\users\orang\appdata\local\temp\arduino_build_515855\sketch\props\prop_base.h: In member function 'void PropBase::SaveVolumeIfNeeded()':
c:\users\orang\appdata\local\temp\arduino_build_515855\sketch\props\prop_base.h:247:39: error: 'saved_global_state' was not declared in this scope; did you mean 'SaveGlobalState'?
247 | if (dynamic_mixer.get_volume() != saved_global_state.volume) {
| SaveGlobalState
c:\users\orang\appdata\local\temp\arduino_build_515855\sketch\props\prop_base.h: In member function 'void PropBase::RestoreGlobalState()':
c:\users\orang\appdata\local\temp\arduino_build_515855\sketch\props\prop_base.h:446:5: error: 'saved_global_state' was not declared in this scope; did you mean 'SaveGlobalState'?
446 | saved_global_state.ReadINIFromDir(NULL, "global");
| SaveGlobalState
c:\users\orang\appdata\local\temp\arduino_build_515855\sketch\props\prop_base.h: In member function 'void PropBase::SaveGlobalState()':
c:\users\orang\appdata\local\temp\arduino_build_515855\sketch\props\prop_base.h:472:5: error: 'saved_global_state' was not declared in this scope; did you mean 'SaveGlobalState'?
472 | saved_global_state.volume = dynamic_mixer.get_volume();
| SaveGlobalState
In file included from C:\Users\orang\Desktop\ProffieOS\ProffieOS.ino:596:
sketch\config/ECOHERO_config.h: At global scope:
In file included from C:\Users\orang\Desktop\ProffieOS\ProffieOS.ino:621:
sketch\buttons/latching_button.h: In member function 'void LatchingButtonTemplate<BASE>::Loop()':
sketch\buttons/latching_button.h:33:7: error: 'prop' was not declared in this scope
33 | prop.Event(button_, EVENT_LATCH_ON);
sketch\buttons/latching_button.h: In member function 'bool LatchingButtonTemplate<BASE>::Parse(const char*, const char*)':
sketch\buttons/latching_button.h:43:9: error: 'prop' was not declared in this scope
43 | prop.Event(button_, EVENT_LATCH_ON);
sketch\buttons/latching_button.h:45:9: error: 'prop' was not declared in this scope
45 | prop.Event(button_, EVENT_LATCH_OFF);
In file included from sketch\buttons/button.h:4,
from C:\Users\orang\Desktop\ProffieOS\ProffieOS.ino:622:
sketch\buttons/button_base.h: In member function 'bool ButtonBase::Send(uint32_t)':
sketch\buttons/button_base.h:51:10: error: 'prop' was not declared in this scope
51 | if (!prop.Event(button_, (EVENT)(event + (EVENT_SECOND_PRESSED - EVENT_FIRST_PRESSED) * press_count_))) {
In file included from C:\Users\orang\Desktop\ProffieOS\ProffieOS.ino:650:
In file included from C:\Users\orang\Desktop\ProffieOS\ProffieOS.ino:658:
sketch\common/sd_test.h:144:3: error: 'SDTestHistogram' does not name a type
144 | SDTestHistogram histogram;
sketch\common/sd_test.h:145:3: error: 'SDTestHistogram' does not name a type
145 | SDTestHistogram open_histogram;
sketch\common/sd_test.h: In member function 'void SDTestHelper::Print()':
sketch\common/sd_test.h:58:5: error: 'open_histogram' was not declared in this scope
58 | open_histogram.print_averages();
sketch\common/sd_test.h:61:5: error: 'histogram' was not declared in this scope
61 | histogram.print_speed();
sketch\common/sd_test.h: In member function 'void SDTestHelper::TestFile(const char*)':
sketch\common/sd_test.h:72:5: error: 'open_histogram' was not declared in this scope
72 | open_histogram.count(micros() - start_open);
sketch\common/sd_test.h:80:7: error: 'histogram' was not declared in this scope
80 | histogram.count(end - start);
In file included from C:\Users\orang\Desktop\ProffieOS\ProffieOS.ino:1660:
sketch\motion/mpu6050.h: In member function 'virtual void MPU6050::Loop()':
sketch\motion/mpu6050.h:243:13: error: 'prop' was not declared in this scope
243 | prop.DoAccel(
sketch\motion/mpu6050.h:251:13: error: 'prop' was not declared in this scope
251 | prop.DoMotion(
In file included from C:\Users\orang\Desktop\ProffieOS\ProffieOS.ino:1661:
sketch\motion/lsm6ds3h.h: In member function 'virtual void LSM6DS3H::Loop()':
sketch\motion/lsm6ds3h.h:149:2: error: 'prop' was not declared in this scope
149 | prop.DoAccel(
In file included from C:\Users\orang\Desktop\ProffieOS\ProffieOS.ino:1662:
sketch\motion/fxos8700.h: In member function 'virtual void FXOS8700::Loop()':
sketch\motion/fxos8700.h:169:6: error: 'prop' was not declared in this scope
169 | prop.DoAccel(
In file included from C:\Users\orang\Desktop\ProffieOS\ProffieOS.ino:1663:
sketch\motion/fxas21002.h: In member function 'virtual void FXAS21002::Loop()':
sketch\motion/fxas21002.h:72:6: error: 'prop' was not declared in this scope
72 | prop.DoMotion(MotionUtil::FromData(databuffer,
In file included from C:\Users\orang\Desktop\ProffieOS\ProffieOS.ino:1683:
sketch\common/booster.h: In member function 'bool Booster::Active()':
sketch\common/booster.h:20:9: error: 'prop' was not declared in this scope
20 | if (prop.NeedsPower()) return true;
C:\Users\orang\Desktop\ProffieOS\ProffieOS.ino: In function 'void setup()':
ProffieOS:1779:3: error: 'prop' was not declared in this scope
1779 | prop.FindBlade();
In file included from C:\Users\orang\Desktop\ProffieOS\ProffieOS.ino:1811:
sketch\common/clock_control.h: In member function 'virtual void ClockControl::Loop()':
sketch\common/clock_control.h:17:5: error: 'prop' was not declared in this scope
17 | || prop.NeedsPower()
