Kill Switch Reboot Time
I’m working on a blaster, and I wanted to make sure this behavior is expected or if I should be concerned before proceeding further. When turning the kill switch on, the board boots up, plays the boot sound, shows the pulsing green board LED indicator, and we’re good to pew-pew. When cutting the power via the kill switch, waiting just a second or two, and then switching it back on, the LED indicator is a steady green, the OLED screen shows its last display, but otherwise the board is unresponsive. If I cut power again and wait a few more seconds (at least 5-10), then power on, everything works again.
If that is working as intended that’s fine by me - I don’t plan on constantly cycling the power via the kill switch. I just wanted verification before securing the board and making it harder to access the wiring :slight_smile:
So, this isn’t “as intended”, but it’s not particularly surprising either.
There are lots of capacitors and stuff which hold a charge for a small amount of time after power is turned off, for most people these discharge within milliseconds after cutting the power. Having it last seconds is unusual, but not really an indication that anything is wrong.
