I am trying to make the blade styles and i am getting this error , it didnt happen before
Did you generate from my library? Post the style code as well.
yes , I used to have it and it was working before , my computer was dead and had to reset it , and lost all my files ![]()
That style compiles fine for me, maybe paste this version into your config. If it persists post your full config, perhaps something else is causing.
still not . i dont know what could it be .
What version of ProffieOS do you have?
(If it’s not 7.15 (or newer) I suggest updating…)
its 7.12 cause its sabertrio
other wise my settinmg dont work
The problem seems to be that there is a transparent color in a stripes<> somewhere.
The error message in the top post is cut off, so I can’t tell where exactly.
I think using transparent colors in stripes is fixed in OS8. Was this style designed for OS8?
I am not sure ,. i dont know that , but i am using this ProffieOS7 Style Library Phase 4 ([v7.15]
but the sabertrio folder is os 7.12 , i tried to update but then it doesnt work the switch
Update to 7.15 and you need to use my prop, this style uses Special Abilities, which are only supported via my prop.
No, the OS7 library style runs fine for me in OS7, it’s not for OS8.
As far as I can tell, there are no differences between 7.12 and 7.15 that could cause the error shown in the top post.
Maybe it’s just a bad paste or something?
The config you posted verifies fine for me (with my prop enabled), are you sure it’s the one you’re trying to upload?
I would introduce some random text at the top of the config, like “I’m testing my config”, if the random text isn’t in the error message, then you’re uploading a different config than you thought. If it does show up, remove it, save the file (enable my prop) and try again. I don’t see anything that wouldn’t work.
“No, none of that worked, but instead of using the pre-made blade style, I used Blade Builder’s Multiphase Special Abilities. Thank you so much for all your time and help :)”
