Just started playing around with ProffieOS7 the other day. I installed ProffieOs7.11 into a couple of my LGT lightsabers and loaded them with basic and complex blade styles, but nothing overly complicated. I borrowed one of the sample config files to create my own config, with some modifications. This is the first part without the blade styles:
#define NUM_BUTTONS 1
#define VOLUME 1550
#define CLASH_THRESHOLD_G 3.0
#define FETT263_TWIST_ON
#define IDLE_OFF_TIME 5 * 60 * 1000
#define FETT263_MULTI_PHASE
#define FETT263_MAX_CLASH 16
//#define FETT263_SAVE_CHOREOGRAPHY
Mostly everything works as expected; however, blade lockup hardly registers unless I stab the wall or something. Melt sometimes works, and sometimes doesn’t. Clash also barely registers for a couple of my sound fonts.
I also initially had #define ENABLE_ALL_EDIT_OPTIONS in my config, but after I inadvertently screwed up a couple blade styles (which required reflashing the proffieboard to fix it), I deleted that line of code to disable the editing option.
So I guess my question is two-fold: Do I need to tweak the clash settings to fix the blade lockup and clash issues? And are there any instructions about the edit function? All I saw was how to access it by pressing the power button 4 times. I don’t anticipate using the edit function at all, but would still like to know how it works.
I also just saw that ProffieOS7.12 was * just* released; would that help with my current issues?
