#define NUM_BUTTONS 1
#define VOLUME 1550
#define CLASH_THRESHOLD_G 3.0
#define ENABLE_SERIAL
#define BC_THRUST_ON
#define BC_TWIST_ON
#define BC_TWIST_OFF
#define BC_FORCE_PUSH
#define FEMALE_TALKIE_VOICE
#define VOLUME_MENU_CYCLE
#define SPEAK_BLADE_ID
#include "../props/saber_BC_buttons.h"
{ "OB4", "tracks/Force_Theme.wav",}
StylePtr<InOutHelper<SimpleClash<Lockup<Blast<AudioFlicker<DeepSkyBlue,SteelBlue>,White>,Pulsing<Gradient<AudioFlicker<DeepSkyBlue,SteelBlue>,AudioFlicker<DeepSkyBlue,SteelBlue>,BrownNoiseFlicker<White,Strobe<Red,White,50,1>,100>,AudioFlicker<DeepSkyBlue,SteelBlue>,AudioFlicker<DeepSkyBlue,SteelBlue>,AudioFlicker<DeepSkyBlue,SteelBlue>>,Gradient<AudioFlicker<DeepSkyBlue,SteelBlue>,AudioFlicker<DeepSkyBlue,SteelBlue>,BrownNoiseFlicker<White,Strobe<Red,White,50,1>,100>,AudioFlicker<DeepSkyBlue,SteelBlue>,AudioFlicker<DeepSkyBlue,SteelBlue>>,3500>,AudioFlicker<White,DeepSkyBlue>>,White>,180,500>>(), "blue"},
{"vader" " tracks/vader1.wav",}
StylePtr<InOutHelper<LocalizedClash<Lockup<Blast<AudioFlicker<Red,Rgb<120,0,0>>,DeepSkyBlue>,Pulsing<Gradient<AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>,BrownNoiseFlicker<White,Strobe<SteelBlue,White,50,1>,100>,AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>>,Gradient<AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>,BrownNoiseFlicker<White,Strobe<SteelBlue,White,50,1>,100>,AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>>,3500>,AudioFlicker<Red,White>>,White,80>,800,500,InOutHelper<LocalizedClash<Lockup<Blast<AudioFlicker<Red,Rgb<120,0,0>>,DeepSkyBlue>,Pulsing<Gradient<AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>,BrownNoiseFlicker<White,Strobe<SteelBlue,White,50,1>,100>,AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>>,Gradient<AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>,BrownNoiseFlicker<White,Strobe<SteelBlue,White,50,1>,100>,AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>>,3500>,AudioFlicker<Red,White>>,White,80>,800,500>>
{ "ANI" " tracks/ANI.wav",}
StylePtr<InOutHelper<SimpleClash<Lockup<Blast<AudioFlicker<DeepSkyBlue,SteelBlue>,White,200,100,400>,Pulsing<Gradient<AudioFlicker<DeepSkyBlue,SteelBlue>,AudioFlicker<DeepSkyBlue,SteelBlue>,BrownNoiseFlicker<White,Strobe<Red,White,50,1>,100>,AudioFlicker<DeepSkyBlue,SteelBlue>,AudioFlicker<DeepSkyBlue,SteelBlue>,AudioFlicker<DeepSkyBlue,SteelBlue>>,Gradient<AudioFlicker<DeepSkyBlue,SteelBlue>,AudioFlicker<DeepSkyBlue,SteelBlue>,BrownNoiseFlicker<White,Strobe<Red,White,50,1>,100>,AudioFlicker<DeepSkyBlue,SteelBlue>,AudioFlicker<DeepSkyBlue,SteelBlue>>,3500>,AudioFlicker<White,DeepSkyBlue>>,White,40>,180,500,Black>
{ "Rainbow;common", "tracks/cantina.wav",}
StylePtr<Layers<StyleFire<StripesX<Int<3000>,Scale<TwistAngle<>,Int<-500>,Int<0>>,Red,Orange,Yellow,Green,Blue,Magenta>,StripesX<Int<3000>,Scale<TwistAngle<>,Int<-500>,Int<0>>,Tomato,OrangeRed,Orange,Yellow,SteelBlue,DeepPink>,0,3,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,Rainbow>,Stripes<1500,-2500,White,Rainbow>>,Int<16384>>,TrFade<800>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<16000>>>,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastWaveL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,White>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<60,60,60>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,White>,RotateColorsX<Variation,Rgb<60,60,60>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,128,128>>,RotateColorsX<Variation,Rgb<60,60,60>>>>,TrFade<1200>>,EFFECT_IGNITION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Int<200>,Int<800>>>,TrWipeInSparkTip<White,500>,Black>,TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_NEWFONT>,AlphaL<Black,Scale<IsLessThan<BatteryLevel,Int<11000>>,Int<0>,Int<7500>>>>>()},
"SmthGrey", "tracks/mercury.wav",
&style_pov, "POV",
{ 0, WS281XBladePtr<145, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), CONFIGARRAY(presets) },
No, there are several syntax errors.
Please read:
I wish China would stop adding #include "../sound/sound_library.h"
to the config files.
What does it even do?
EDIT: I wonder if we should just offer a caveated clean file for download based on those standard LGT oned? Maybe a sticky on the forum? I can do it if someone provides the files.
