emphasized text
Starkiller_V3.h (113.2 KB)
Yes there is:
- replace
"VTS"common"with"VTS;common" - your Galen Marek preset is missing a second blade style
Edit: - your Batt00 is also missing a second blade style - some of your presets have space " " in the name. It may work but it also may cause problems in some cases. I would suggest you replace " " with “_” or “-”
Yes. Some of your tracks are missing
.wav
at the end and you need a couple of semi colons near
common
Start there and try compiling. There’s something else going on I think but start with that. Then post your error message if you get one.
I can only see one missing in the first preset.
That is more accurate ![]()
Pfew, I though my eyesight was decreasing again. ![]()
How would you make it so both blades would be working?
I am sorry but I do not understand what you mean. You will need to give a bit more information. As far as your config is concerned, if you fixed everything from above, both blades should be fine.
The only thing I can think of with your question is:
- solder the wires as defined in your config
- put a battery in it
- turn it on.
What makes you think there might be something wrong with it?
Please provide more information.
*More accurately, how was this config generated and please don’t say “AI”.
no it wasnt AI
Just a few times i tried to verify the file it kept giving me errors
Please provide the errors (the entire compilation output) it makes it much easier to help you.
